    Issue with Outlook recurring events
    26 Posts 2 Posters 5.2k Views 2 Watching
    • W Offline
      WallysWellies
      Hello all.
      I’m having some issues with Outlook calendar events in the default calendar app and I think I have narrowed it down to a daylight savings issue (bug?):
      As you can see above, the recurring rule is expiring the evening before the event so these events do not show in my calendar.
      I realise this is looking like a Microsoft issue but I wondered if anyone had encountered this before and knows how to fix it?
      One thing that appears to work is setting my timezone to UTC then re-saving the event which I guess I can do unless someone has a better idea… Doing this sets the “UNTIL” time to 00:00 on the day of the actual event.
        sdetweil @WallysWellies
        @WallysWellies this fix sets the rrule:until to start of day+1 day for fullday events (tested in LA, Chicago, London and Sydney timezones)
        add three lines
        modules/default/calendarcalendarfetcherutils.js
        					event.start = rule.options.dtstart;  // old code line 294
                                                // insert these three lines
        					if((rule.options.until != undefined) && CalendarFetcherUtils.isFullDayEvent(event)){
        						Log.debug("fixup rrule until")
        						rule.options.until = new Date(new Date(moment(rule.options.until).startOf("day").add(1,"day")).getTime())
        					Log.debug("fix rrule start=", rule.options.dtstart); // old code line 301
          @WallysWellies if the event is a full day event(DTSTART:VALUE=DATE) then the rrule until should also only be date
          also full day events are considered local timezone only
          i dont think the parser (not our code) validates that
          oh, then rrule processes it ( also not our code)
          we call rrule.between() to get the list of events that match the rule between a year ago and an year forward(by default)
            @WallysWellies do you have that full VEVENT so i can look at its processing in both places as i work on both
            • W Offline
              WallysWellies @sdetweil
              @sdetweil Here is a problematic event:
              BEGIN:VEVENT
              DESCRIPTION:\n
              RRULE:FREQ=YEARLY;UNTIL=20250504T230000Z;INTERVAL=1;BYMONTHDAY=5;BYMONTH=5
              UID:040000008200E00074C5B7101A82E00800000000DAEF6ED30D9FDA01000000000000000
               010000000D37F812F0777844A93E97B96AD2D278B
              SUMMARY:Person A's Birthday
              DTSTART;VALUE=DATE:20250505
              DTEND;VALUE=DATE:20250506
              CLASS:PUBLIC
              PRIORITY:5
              DTSTAMP:20250428T133000Z
              TRANSP:TRANSPARENT
              STATUS:CONFIRMED
              SEQUENCE:0
              X-MICROSOFT-CDO-APPT-SEQUENCE:0
              X-MICROSOFT-CDO-BUSYSTATUS:FREE
              X-MICROSOFT-CDO-INTENDEDSTATUS:BUSY
              X-MICROSOFT-CDO-ALLDAYEVENT:TRUE
              X-MICROSOFT-CDO-IMPORTANCE:1
              X-MICROSOFT-CDO-INSTTYPE:1
              X-MICROSOFT-DONOTFORWARDMEETING:FALSE
              X-MICROSOFT-DISALLOW-COUNTER:FALSE
              X-MICROSOFT-REQUESTEDATTENDANCEMODE:DEFAULT
              X-MICROSOFT-ISRESPONSEREQUESTED:FALSE
              END:VEVENT
              And here is a working event:
              BEGIN:VEVENT
              DESCRIPTION:\n
              RRULE:FREQ=YEARLY;UNTIL=20250503T000000Z;INTERVAL=1;BYMONTHDAY=3;BYMONTH=5
              UID:040000008200E00074C5B7101A82E00800000000591C9B3BAA0EDA01000000000000000
               01000000005E6F2F9D20F7947B69F54FBF0794A6D
              SUMMARY:Person B's Birthday
              DTSTART;VALUE=DATE:20250503
              DTEND;VALUE=DATE:20250504
              CLASS:PUBLIC
              PRIORITY:5
              TRANSP:TRANSPARENT
              STATUS:CONFIRMED
              SEQUENCE:0
              END:VEVENT
              Thanks for taking a look.
                @WallysWellies thanks, forgot to ask what timezone you are in
                • W Offline
                  @sdetweil I’m in the UK. Since it’s British summer time I don’t know if that means I’m UTC+1 or something else… GMT, BST… Stupid changing clocks!
                    add three lines
                    • W Offline
                      @sdetweil Thank you - that has fixed my upcoming calendar event 👍
                      S 3 Replies Last reply Reply Quote 1
                        @WallysWellies cool, i will submit as a change for next release
                          @WallysWellies you will need to use my upgrade script and reply no to keeping the changed files
                          see https://github.com/sdetweil/MagicMirror_scripts
                          note upgrade is a two part process
                          test, do nothing (highlight exposed files, if any)
                          do upgrade
                            @WallysWellies I opened issue 3781
                            https://github.com/MagicMirrorOrg/MagicMirror/issues/3781
                            and pushed the fix and testcase for next release
                            • W Offline
                              @sdetweil Thank you!
                                @WallysWellies this was accepted and added to the next release
                                • W Offline
                                  WallysWellies
                                  Hi Sam,
                                  I’m afraid this issue has reoccurred on an event that is not full day but instead is supposed to be the last in a series. I believe it’s the same issue though where the timezone / BST is causing the problem.
                                  Sample ICS data below:
                                  BEGIN:VCALENDAR
                                  METHOD:PUBLISH
                                  PRODID:Microsoft Exchange Server 2010
                                  VERSION:2.0
                                  X-WR-CALNAME:Test Calendar
                                  BEGIN:VTIMEZONE
                                  TZID:GMT Standard Time
                                  BEGIN:STANDARD
                                  DTSTART:16010101T020000
                                  TZOFFSETFROM:+0100
                                  TZOFFSETTO:+0000
                                  RRULE:FREQ=YEARLY;INTERVAL=1;BYDAY=-1SU;BYMONTH=10
                                  END:STANDARD
                                  BEGIN:DAYLIGHT
                                  DTSTART:16010101T010000
                                  TZOFFSETFROM:+0000
                                  TZOFFSETTO:+0100
                                  RRULE:FREQ=YEARLY;INTERVAL=1;BYDAY=-1SU;BYMONTH=3
                                  END:DAYLIGHT
                                  END:VTIMEZONE
                                  BEGIN:VEVENT
                                  RRULE:FREQ=WEEKLY;UNTIL=20250630T173000Z;INTERVAL=1;BYDAY=MO;WKST=MO
                                  UID:040000008200E00074C5B7101A82E00800000000E05582F27408DB01000000000000000
                                   010000000E892CDFA6C0E4E4298E1C987B4791120
                                  SUMMARY:Calendar Event
                                  DTSTART;TZID=GMT Standard Time:20250331T183000
                                  DTEND;TZID=GMT Standard Time:20250331T200000
                                  CLASS:PUBLIC
                                  PRIORITY:5
                                  DTSTAMP:20250630T164141Z
                                  TRANSP:OPAQUE
                                  STATUS:CONFIRMED
                                  SEQUENCE:0
                                  X-MICROSOFT-CDO-BUSYSTATUS:BUSY
                                  X-MICROSOFT-CDO-ALLDAYEVENT:FALSE
                                  END:VEVENT
                                  END:VCALENDAR
                                  I’ve stripped out most of the content other than the event in question and the timezone info.
                                  You’ll see that the DTSTART and DTEND data shows the correct start and end time but the RRULE shows the UNTIL as an hour before the event so the event does not show on the MM calendar module.
                                  The event in Outlook shows the series being every Monday until 1st July.
                                  I’m not sure if this “bug” is a problem with Outlook or MagicMirror.
                                  Happy to start a new thread, or log a bug on GitHub if either of those is preferrable.
                                    @WallysWellies there is a rewrite of the calendar event handler coming in tomorrow’s release .
                                    please check there
                                    • W Offline
                                      WallysWellies
                                      I’m back with more calendar woes.
                                      I’m apparently still having an issue where events in my Outlook calendar can under certain circumstances not appear on my MM. This is again a symptom of the event’s rrule ending prior to the last event in the series. Some ICS code below:
                                      BEGIN:VCALENDAR
                                      METHOD:PUBLISH
                                      VERSION:2.0
                                      X-WR-CALNAME:My Calendar
                                      BEGIN:VTIMEZONE
                                      BEGIN:STANDARD
                                      TZOFFSETFROM:+0100
                                      TZOFFSETTO:+0000
                                      END:STANDARD
                                      BEGIN:DAYLIGHT
                                      TZOFFSETFROM:+0000
                                      TZOFFSETTO:+0100
                                      END:DAYLIGHT
                                      END:VTIMEZONE
                                      BEGIN:VEVENT
                                      RRULE:FREQ=WEEKLY;UNTIL=20251007T164500Z;INTERVAL=1;BYDAY=TU;WKST=MO
                                      EXDATE;TZID=GMT Standard Time:20250930T174500
                                      UID:040000008200E00074C5B7101A82E008000000004ECDB12BC10FDC01000000000000000
                                       010000000012DADF723AF8140B35A2E374506E8D9
                                      SUMMARY:My Event
                                      DTSTART;TZID=GMT Standard Time:20250826T174500
                                      DTEND;TZID=GMT Standard Time:20250826T183000
                                      CLASS:PUBLIC
                                      PRIORITY:5
                                      DTSTAMP:20251006T181942Z
                                      TRANSP:OPAQUE
                                      STATUS:CONFIRMED
                                      SEQUENCE:0
                                      END:VEVENT
                                      END:VCALENDAR
                                      I’m not sure if this is something that can be resolved, or why it happens but I suspect some timezone issue as I’m based in the UK and we have to endure changing the clocks twice a year.
                                      Having said that, the ICS file does not reflect the settings in the calendar for that event:
                                      Anyone got any suggestions? Sorry to be a pest with this one!
                                        @WallysWellies the event looks correct according to the start/end and rrule
                                        But
                                        We do not use the custom timezone configuration in the iCal data
                                        We use the worldwide standard IANA tz names
                                        (Why one needs custom timezones is beyond me)
                                        Because so many users use MS products , I wrote a lookup table 5 years ago for the calendar parser we use, node-iCal
                                        But
                                        GMT Standard Time
                                        Is not in that table (GMT has long been replaced by UTC)
                                        UTC Standard Time
                                        Is in the table
                                        If the tz lookup fails, we use the local system timezone
                                        S W 2 Replies Last reply Reply Quote 0
                                          The calendar automatically adjusts for STD/DST time changes
                                            I don’t know why the rrule until says oct 08:164500, but oct 7 is the last Tuesday in the event cycle
                                            Sept 30 was excluded
                                            So all the iCal entry looks good except for the timezone
                                            • W Offline
                                              @sdetweil the timezone on my Pi is:
                                                             Local time: Mon 2025-10-06 20:26:51 BST
                                                         Universal time: Mon 2025-10-06 19:26:51 UTC
                                                               RTC time: Mon 2025-10-06 19:26:51
                                                              Time zone: Europe/London (BST, +0100)
                                              System clock synchronized: yes
                                                            NTP service: active
                                                        RTC in local TZ: no
                                              Is there something I need to do to try and resolve this? My MS calendar is set to a UTC timezone:
