    Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream
    68 Posts 5 Posters 25.1k Views 4 Watching
      sdetweil @Cr4z33
      @Cr4z33 if you set
      debug:true
      in the MMM-MqttBridge config in config.js
      it will output messages at npm start
      i always recommend not using pm2 while testing
      as you can see the messages from npm start easily
      • mumblebajM
        mumblebaj Module Developer @Cr4z33
        @Cr4z33 said in Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream:
        MMM-RTSPStream
        The position is incorrect. There is no middle\_center position.
        S 2 Replies Last reply
          sdetweil @mumblebaj
          @mumblebaj AND with release 2.30 or higher a message will be sent to the stderr stream that this module will not be loaded
          good catch
            sdetweil @mumblebaj
            @mumblebaj WELL… it turns out this is a false warning as _ is treated as _ in js…
            I changed the position middle_center1 and got
            41:01.108] [ERROR] This module configuration contains errors:
              "module": "MMM-RTSPStream",
              "classes": "page1",
              "position": "middle_center1",
              "disabled": false,
              "config": {
                "autoStart": false,
                "rotateStreams": true,
                "rotateStreamTimeout": 10,
                "moduleWidth": 500,
                "moduleHeight": 281,
                "localPlayer": "vlc",
                "moduleOffset": {
                  "left": -170,
                  "top": -125
                "remotePlayer": "ffmpeg",
                "showSnapWhenPaused": false,
                "remoteSnaps": false,
                "shutdownDelay": 12,
                "stream1": {
                  "name": "Videocitofono",
                  "url": "rtsp://username:password@doorbellip/cam/realmonitor?channel=1&subtype=1#backchannel=0",
                  "frameRate": "undefined",
                  "width": 500,
                  "height": 281,
                  "muted": true,
                  "ffmpegPort": 9999
            position: must be equal to one of the allowed values
              "fullscreen_below",
              "top_bar",
              "top_left",
              "top_center",
              "top_right",
              "upper_third",
              "middle_center",
              "lower_third",
              "bottom_bar",
              "bottom_left",
              "bottom_center",
              "bottom_right",
              "fullscreen_above"
            [2025-04-23 14:41:01.109] [WARN]  Invalid module position found for this configuration:
              "classes": "page1",
              "disabled": false,
              "config": {
                "autoStart": false,
                "moduleWidth": 500,
                "moduleOffset": {
                  "left": -170,
                  "top": -125
                "stream1": {
                  "width": 500,
                  "height": 281,
                  "muted": true,
                  "ffmpegPort": 9999
            Cr4z33C 1 Reply Last reply
            • Cr4z33C
              Cr4z33 @sdetweil
              @sdetweil sorry for being gone for so long time, but I’ve been out of town more than scheduled. 😅
              So back in topic… the typo for the MMM-RTSPStream config section was done in this forum post only.
              Where did you get all those warnings from?
              Looking at npm start output nothing like that was displayed (on my side).
              On the other hand I could see this when I launched that command with MQTTbridge log set to true:
              [29.04.2025 09:57.21.030] [LOG]   [MQTT bridge] Subscribed to the topic: DahuaVTO/Invite/Event
              So the module is somehow doing something, but then as I said nothing happens at button press.
                sdetweil @Cr4z33
                @Cr4z33 as i said the \- in the position is ok,
                i made the position invalid by adding a 1 at the end, then the bad position output is shown from npm start
                still no activity from the button
                two things
                1. the event is not triggering to mqtt
                2. the action in mqttbridge is not what you expected
                i dont know how to debug either one
                • Cr4z33C
                  Cr4z33 @sdetweil
                  @sdetweil it’s OK mate and thanks for having tried to help me. :)
                  Let’s hope someone can come up with a working solution soon.
                    sdetweil @Cr4z33
                    @Cr4z33 looking further at mqttbridge it also logs receipt of the notification from the subscription
                    so that tells me it did not receive info from mqtt
                    • Cr4z33C
                      Cr4z33 @sdetweil
                      @sdetweil I am not quite sure that I understood.
                      Are you saying it’s a module’s bug or is it needed further coding I should add (somewhere)?
                        sdetweil @Cr4z33
                        @Cr4z33 im saying the module will report when it receives the mqtt info. it did not report. sooooo it did not receive the info
                        why i do not know
                        • Cr4z33C
                          Cr4z33 @sdetweil
                          @sdetweil hmmm I see.
                          I wonder if there’s actually another way to see the doorbell stream when the button is pressed?
                          There’s a button sensor entity for it in Home Assistant.
                            sdetweil @Cr4z33
                            @Cr4z33 i dont know, but MQTTBridge was not informed of the button press as you expected
                            is your other bridge code running? you mentioned you had some app talking to the doorbell and publishing the mqtt message
                            is the doorbell an mqtt device , fed thru zigbee2mqtt for homeassistant?
                            or is there a native integration?
                            i would expect the doorbell to NOT publish to mqtt directly
                            it would be a tiny market to add and support that code IN the doorbell firmware
                              @Cr4z33 you could build an HA automation to send the MQTT message on button push
                              • Cr4z33C
                                Cr4z33 @sdetweil
                                @sdetweil said in Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream:
                                But then again nothing would happen.
                                I mean I’ve already DahuaVTO2MQTT in the middle and I used the right line taken from its console, but here we are. 😅
                                  sdetweil @Cr4z33
                                  @Cr4z33 something is not sending the mqtt message
                                  bell -> ha automation -> mqtt -> mqttbridge -> rtsp…
                                  should work
                                  for me, this works
                                  alexa-> nodered -> mqtt > ha automation -> mqtt -> mirror_app -> screen off
                                  • Cr4z33C
                                    Cr4z33 @sdetweil
                                    should work
                                    for me, this works
                                    And you are using this MQTT module on the smart mirror or?
                                      sdetweil @Cr4z33
                                      @Cr4z33 no, i wrote my own code for the mqtt integration
                                      but its fundamentally doing the same thing, receiving an mqtt message and sending a notification to other code to act
                                      • Cr4z33C
                                        Cr4z33 @sdetweil
                                        @sdetweil I see I wish I had the same skills to do ALL by myself lol!
                                        However I wonder if I am the only person in the world having a smart video doorbell and MagicMirror?
                                        I mean I haven’t found any universal solution to this in this forum, but just some modules for certain doorbell hardware like Ring, etc.
                                          sdetweil @Cr4z33
                                          @Cr4z33 and the ring module talks directly to the ring doorbell
                                          you should be able to use HA automation to get to mqttBridge, no fancy coding
                                          automation trigger
                                          device bell button push
                                          action, more, command, mqtt publish
                                          i have ring doorbell, and the module doesnt work for me
                                          doesnt matter, as im hardly ever in front of the smartmirror when the doorbell rings
                                          there is a ring2mqtt docker container, but again it really doesnt add anything useful
                                          • Cr4z33C
                                            Cr4z33 @sdetweil
                                            @sdetweil and how would I get the broadcasting of the doorbell video feed?
                                            Custom coding?
                                            • 1 / 4
