    MMM-Moon module - how to resize?
    9 Posts 3 Posters 1.1k Views 3 Watching
      cricket @sdetweil
      I will have a further look at that link and try to figure it out, but it may be over my head. Thanks again for your help.
        sdetweil @cricket
        @cricket well, it doesnt work, so yeh.
        css is
        selector_clause {
             styles to apply
        there are three main selector clause types
        starts w dot, means classname, class=“module”
        .module
        starts w pound sign, means id, id=“idstring”
        #idstring
        no prefix, means an html tag , p, h2, table, div, span, …
        for class if there is NO space between the descriptors
        like your .region.bottom_left
        it means applies ONLY to elements with ALL classes specified on that same element at the same time
        there are multiple operators that can help define exactly which element in a content tree you are targeting
        the selector clause selects elements the styles between the {}
        will be applied to. the selector clause ALWAYS selects ALL elements in the document ( web page) that match
        i use this cheatsheet to help me remember
        it used to be one page, but they have broken it out by family now
        https://www.w3schools.com/cssref/css_selectors.php
        many styles are NOT inherited by nested elements
        (width, height)
          sdetweil @cricket
          @cricket understood. i am trying to teach you how to do it, so you dont have to wait on anyone! ( over and over)
          there are 1200 modules that do it all differently.
          i’m am just the moderator here. most of the module authors are not active, so we have to figure it out ourselves.
          asking google
          how do i change the size of an image on a web page with css,
          should at least give you the style names you
          might need to use (in dev window and custom.css)
            cricket @sdetweil
            Many thanks for this, - you are a scholar and a gentleman. I will sort through this at some point soon.
              rkorell @cricket
              @cricket said in MMM-Moon module - how to resize?:
              It appears there is no size option in the module itself. I
              I’ve had the same issue not with size but with alignment and had resolved this within the middle-center region and have used:
              .region.middle.center {
                width: 45%;
              in custom.css.
              This works for me to position the moon nicely above earth in my implementation.
              Regards,
              Ralf
                cricket @rkorell
                @rkorell Thansk for this!
