    Clock Module - Adjust light time to avoid line break
    8 Posts 3 Posters 1.5k Views 3 Watching
      rkorell @sdetweil
      @sdetweil Dear Sam,
      as always: You’re right! This works.
      Thanks a lot.
      Today in the morning (before reading your post/suggestion) I’ve found
      .clock .module-content span.bright {
      color: yellow;
      Interesting enough a width attribute is not working at this identifier - color works…
      Warmest regards,
      Ralf
        sdetweil @rkorell
        @rkorell you dont need the .module_content
          rkorell @sdetweil
          @sdetweil Dear Sam,
          you are sooo good.
          And so right!
          Thanks again!
          Ralf
            sdetweil @rkorell
            @rkorell span lives inside a div. It does not inherit the div’s size. Good thing else everything would be squished in the div
            Your css says
            For ALL elements with clock as a class (and descendants)
            ALL span elements with the class bright
            Should have the color style set to yellow for the spans text content
              dathbe
              I use the following in my css to solve this:
              .clock .sun {
                white-space: nowrap;
              .clock .fas {
                padding-left: 10px;
              The second part isn’t strictly necessary, but I find it gives some needed space between the elements
                rkorell @dathbe
                @dathbe this is a cool idea!
                Thanks.
                Ralf
