    Wayland question
    10 Posts 3 Posters 1.2k Views 3 Watching
    • G Offline
      gonzonia
      I know this has been fixed (at least I think it has) I just can’t find what the fix is. My SD got corrupted so I’m re-installing. Clean install of PiOS on a Pi4b. Used @sdetweil script to install.
      Starting with npm run start:wayland seems to work but when I reboot and it tries to start it doesn’t work.
      What do I need to change?
        sdetweil @gonzonia
        @gonzonia no. I use ssh all the time, never real keyboard
        The start:Wayland says
        If WAYLAND_DISPLAY is set, use it, else set it to wayland-1
        But
        Maybe it needs to be wayland-0
        So add
        export WAYLAND_DISPLAY=wayland-0
        Before the npm run start:Wayland line
        And try that
          sdetweil @gonzonia
          @gonzonia MagicMirror/installers/mm.sh
          But the latest should handle that
          Where you do
          npm run
          Now
          Do env
          And look for WAYLAND_DISPLAY
          What is its value?
          G 2 Replies Last reply Reply Quote 0
          • G Offline
            gonzonia @sdetweil
            • G Offline
              gonzonia @sdetweil
              @sdetweil said in Wayland question:
              I have a theory…I did the install via ssh and not directly on the pi. Maybe that broke it?
                sdetweil @gonzonia
                But
                So add
                And try that
                • G Offline
                  gonzonia @sdetweil
                  @sdetweil I think that worked. I was able to start it with pm2.
                    sdetweil @gonzonia
                    @gonzonia cool
                      I’ll see if I can mod the script, not til Monday
                        schlomm @sdetweil
                        Hi @sdetweil
                        I have tested your updated script and it works flawlessly. Exporting the needed WAYLAND environment variable was exactly what I was looking for.
                        Since I install MagicMirror via an Ansible playbook, the required environment variables are not set in the used .pm2/dump.pm2 file - my previous approach was to restore a prepared dump.pm2 file, but with your approach it is much more convenient :)
                          sdetweil @schlomm
                          @schlomm awesome, thanks for the feedback
