    Electron error? js error? Javascrpt error?
    7 Posts 2 Posters 1.3k Views 2 Watching
      Dayzwell
      Hi i’m training to run MM on a raspberry pi, this is my first trying something like this and seeing this much code, when i tried npm run start i get all of this errors, tried to update things and its giving me the same error, should I just tried a fresh install? thanks for the help guys.
      dayzwell@raspberrypi:~/MagicMirror $ npm run start
      magicmirror@2.31.0 start
      npm run start:x11
      magicmirror@2.31.0 start:x11
      [2025-06-16 12:46:38.249] [ERROR] App threw an error during load
      [2025-06-16 12:46:38.259] [ERROR] ReferenceError: ReadableStream is not defined
      at Object. (/home/dayzwell/MagicMirror/node_modules/undici/lib/web/fetch/webidl.js:471:58)
      at Module._compile (node:internal/modules/cjs/loader:1141:14)
      at Module._extensions…js (node:internal/modules/cjs/loader:1196:10)
      at Module.load (node:internal/modules/cjs/loader:1011:32)
      at Module._load (node:internal/modules/cjs/loader:846:12)
      at f._load (node:electron/js2c/asar_bundle:2:13377)
      at Module.require (node:internal/modules/cjs/loader:1035:19)
      at require (node:internal/modules/cjs/helpers:102:18)
      at Object. (/home/dayzwell/MagicMirror/node_modules/undici/lib/web/fetch/util.js:12:20)
      A JavaScript error occurred in the main process
      Uncaught Exception:
      MESA-LOADER: failed to retrieve device information
      os_same_file_description couldn’t determine if two DRM fds reference the same file description. (Function not implemented)
      Let’s just assume that file descriptors for the same file probablyshare the file description instead. This may cause problems whenthat isn’t the case.
      [4820:0616/114639.047070:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
        sdetweil @Dayzwell
        @Dayzwell I see his instructions left out a step.
        I opened this issue https://github.com/xadamxk/MMM-LOLESPORTS-SCHEDULES/issues/8
        he has updated the instructions
          sdetweil @Dayzwell
          @Dayzwell can you tell us what you did to setup and install MagicMirror. what system and OS this is
            Dayzwell @sdetweil
            @sdetweil Im using a raspberry 3 using Raspberry Pi OS, I install and update the MM and it work until i tried to install this module https://github.com/xadamxk/MMM-LOLESPORTS-SCHEDULES update electron and everething I could find and now its giving me those errors
              sdetweil @Dayzwell
              @Dayzwell ok, so lets start over a little
              for that module in config.js add
              disabled:true,
              after its module: line
              and then do
              git checkout package.json
              rm -rf node_modules
              npm run install-mm
              then try
              npm start
                sdetweil @Dayzwell
                  Dayzwell @sdetweil
                  @sdetweil thak you it works now :)
                    sdetweil @Dayzwell
                    @Dayzwell awesome!!
