    MMM-EnvCanada stopped working ...
    27 Posts 9 Posters 4.9k Views 9 Watching
      sankum
      Since yesterday MMM-EnvCanada stopped loading, stays on starting …
      I have not made any changes in MM. Does anybody else have this problem? Any pointers? Thanks.
      S R 3 Replies Last reply Reply Quote 0
        sdetweil @sankum
        @sankum we have a provider in weather, does it work ?
        luisestradaL 1 Reply Last reply Reply Quote 0
          sdetweil @sankum
          @sankum there is a new issue on the module github page
            sankum
            Hi Sam,
            Weather module works. It is an issue with MMM-EnvCanada. I opened the issue on github, hoping to get a response from the author of the module. I don’t know how else to get in touch with the author. Thanks.
              ray_mtl @sankum
              @sankum
              I was using EnvCanada as provider in weather module and it does not work either.
              Neither MMM-EnvCanada or Wether using EnvCanada provider works at this time.
                sdetweil @ray_mtl
                @ray_mtl there is an issue open. looks like envcanada has changed their api significantly
                luisestradaL R charlesfC 3 Replies Last reply Reply Quote 2
                • luisestradaL Offline
                  luisestrada @sdetweil
                  @sdetweil said in MMM-EnvCanada stopped working ...:
                  It does not, MMM-Weather using Environment Canada does nor work either, it’s not the first time Environment Canada messes up with the modules
                    A note aside, Home Assistant is working without issues
                      sdetweil @luisestrada
                      @luisestrada so someone there got the change notice
                        sunsetrider @sdetweil
                        I also have a problem with envcanada’s weather data . The MM weather app goes out to get info, but the screen says ‘ loading’, and stays hung there.
