    MMM-temp-ds18b20 disable second sensor
    8 Posts 2 Posters 696 Views 2 Watching
      briantogo
      Thanks Sam, that did remove the second sensor, but there is still undefined section above the temp to get rid of, as shown in the attachment. Any suggestions on that?20250630_10h39m23s_grim.jpg
        sdetweil @briantogo
        @briantogo i think that is the header or label option
          briantogo
          Thanks Sam, I had already changed “headers” field to ‘inside’, and I like it’s size and placement. I had removed the field “label” under the sensor field hoping to remove it from the config. Now I have re-added the label field, but left it blank. Now the config.js looks like this;
          sensors:[
          label: “”
          Now, it just displays an extra line above the temp reading. Is there a way to, let’s say, zero out or cancel that field altogether? Is there perhaps a word I could type in between the quotes like Null or Void?
          Here is a screen grab from my mirror;
          Thanks again,
          Brian
          S 3 Replies Last reply Reply Quote 0
            sdetweil @briantogo
            @briantogo i dont know the exact answer, but using the developers window elements tab you can find the element
            and set it to
            display:none;
            in css/custom.css
            see the second link in my signature below for a quick guide on the dev window
              sdetweil @briantogo
              @briantogo or move the header to label with no header
                sdetweil @briantogo
                @briantogo did you get it fixed?
