    MMM-JsonTable - error and does not load
    19 Posts 2 Posters 3.4k Views 2 Watching
      sankum
      Thanks Sam. I changed it to http:// and even tried local IP address instead of localhost and the result is the same. Still the same error, and does not load.?
        sdetweil @sankum
        @sankum if you change to a file url in a browser
        file:///home/userid/MagicMirror/modules/....
        does the file load? this proves the file path and character case
        remember linux is case sensitive
        then replace in front of /modules
        with
        http://localhost:8080
          sankum
          Hi Sam,
          file:/home/sankum/… loads with 1 slash in the browser. But nhttp://localhost:8080/modules/… does not, same errors as before?
            sdetweil @sankum
            @sankum is MagicMirror configured to port 8080?
            not
            nhttp
            http://
              sankum
              Sam, MagicMirror is configured to port 8080. nhtp was a typo. It is http://…
              As I said the file path and name are correct as I can read it in browser using file:/… (single slash). So not quite sure what is going on?
                sdetweil @sankum
                @sankum what is your address: setting in config.js
                  sankum
                  Sam,
                  address: “localhost”,
                    sdetweil @sankum
                    @sankum I used the sample from the readme
                      "items": [
                          "name": "Watt",
                          "value": "270 Watt"
                          "name": "Today",
                          "value": "5.85 kWh"
                          "name": "ThisWeek",
                          "value": "5.83 kWh"
                          "name": "ThisMonth",
                          "value": "12.8 kWh"
                          "name": "LastMonth",
                          "value": "246.75 kWh"
                    in the module folder
                    and this config (from the readme)
                      module: 'MMM-JsonTable',
                      position: 'top_right',
                      classes:'page1',
                      header: 'HouseDB Sevensegment',
                        url: 'http://localhost:8090/modules/MMM-JsonTable/foobar.json', // Required
                        arrayName: 'items' // Required---
                    and it displayed as expected
                      sankum
                      Thanks Sam.
                      So do I need port 8090 based on your config?. In my config port definition I have:
                      port: “8080”,
                      Other than that I don’t see any difference. Do I need to change router setting? Any missing package you think? Thanks.
                        sankum
                        Hi Sam,
                        Never mind!! It is port 8080.
                        I copied the json file you have shown and it worked. So it must be my json file. I will try to figure out what is the difference. Thanks for your help.
                          sdetweil @sankum
                          @sankum sorry intended to change that in
                          my post, too early
                            sdetweil @sankum
                            @sankum i use this online to to validate and format json
                            https://codebeautify.org/jsonvalidator
                              sankum
                              Thank you, Sam.
                                sdetweil @sankum
                                @sankum did you get it fixed?
                                  sankum
                                  Sam, sorry I overlooked your question
                                  Yes, I did get it fixed. Thanks.
                                    sdetweil @sankum
                                    @sankum was it the file contents?
                                      sankum
                                      Sam,
                                      Yes, it was the file content. I had copied it from the git example but obviously did something wrong.
