    MMM-JsonTable - error and does not load
    19 Posts 2 Posters 3.4k Views 2 Watching
      sankum
      Hi Sam,
      file:/home/sankum/… loads with 1 slash in the browser. But nhttp://localhost:8080/modules/… does not, same errors as before?
        sdetweil @sankum
        @sankum is MagicMirror configured to port 8080?
        not
        nhttp
        http://
          sankum
          Sam, MagicMirror is configured to port 8080. nhtp was a typo. It is http://…
          As I said the file path and name are correct as I can read it in browser using file:/… (single slash). So not quite sure what is going on?
            sdetweil @sankum
            @sankum what is your address: setting in config.js
              sankum
              Sam,
              address: “localhost”,
                sdetweil @sankum
                @sankum I used the sample from the readme
                  "items": [
                      "name": "Watt",
                      "value": "270 Watt"
                      "name": "Today",
                      "value": "5.85 kWh"
                      "name": "ThisWeek",
                      "value": "5.83 kWh"
                      "name": "ThisMonth",
                      "value": "12.8 kWh"
                      "name": "LastMonth",
                      "value": "246.75 kWh"
                in the module folder
                and this config (from the readme)
                  module: 'MMM-JsonTable',
                  position: 'top_right',
                  classes:'page1',
                  header: 'HouseDB Sevensegment',
                    url: 'http://localhost:8090/modules/MMM-JsonTable/foobar.json', // Required
                    arrayName: 'items' // Required---
                and it displayed as expected
                  sankum
                  Thanks Sam.
                  So do I need port 8090 based on your config?. In my config port definition I have:
                  port: “8080”,
                  Other than that I don’t see any difference. Do I need to change router setting? Any missing package you think? Thanks.
                    sankum
                    Hi Sam,
                    Never mind!! It is port 8080.
                    I copied the json file you have shown and it worked. So it must be my json file. I will try to figure out what is the difference. Thanks for your help.
                      sdetweil @sankum
                      @sankum sorry intended to change that in
                      my post, too early
                        sdetweil @sankum
                        @sankum i use this online to to validate and format json
                        https://codebeautify.org/jsonvalidator
                          sankum
                          Thank you, Sam.
                            sdetweil @sankum
                            @sankum did you get it fixed?
                              sankum
                              Sam, sorry I overlooked your question
                              Yes, I did get it fixed. Thanks.
                                sdetweil @sankum
                                @sankum was it the file contents?
                                  sankum
                                  Sam,
                                  Yes, it was the file content. I had copied it from the git example but obviously did something wrong.
