    MMM-Facial-Recognition cannot sendSocketNotification()
    mmm-facial-recognitionpaviro
    2 Posts 1 Posters 2.1k Views 1 Watching
      stanchan
      I’m trying to get the troubleshoot the MMM-Facial-Recognition module, and I have narrowed it down to the node_helper not being able to sendSocketNotification().
      I added a line to socketNotifcationRecieved() within the node_helper.js file to test this.
        // Subclass socketNotificationReceived received.
          if(notification === 'CONFIG') {
            this.config = payload
            if(!pythonStarted) {
              pythonStarted = true;
      // I ADDED THE FOLLOWING LINE:
              this.sendSocketNotification("Test", "sendSocketNotification to module");
              this.python_start();
      and then I also added a console.log to the MMM-Facial-Recognition.js to print out any received socket Notifications.
      		//For testing purposes
      		console.log(notification)
      However, nothing prints out in the console.
      I am troubleshooting this, because even though the module recognizes my face and logs me in, no alert comes up on the mirror and none of the modules update.
      Note: The module itself is able to sendSocketNotification to the node_helper because the python_shell does start and the recognition python script runs with the correct configuration.
      Thank you in advance for your help.
        stanchan @stanchan
        UPDATE: This, like some other issues I was running into was actually caused by the application freezing when it could not load ‘css/custom.css’.
        This is because the .gitignore does not track custom.css and I, like many others, edit my code on my desktop and then push the changes via git to my RPi.
