    Different order in center after Upgrade to 2.32
    21 Posts 2 Posters 2.0k Views 2 Watching
    • F Offline
      falter
      Hi all,
      I have 6 cameras with RTSPtoWeb module in position top_center. Until 2.32 they arranged in a 2x3 order, after upgrade to 2.32 they appear in 1x6 order und do not fit anymore.
      Does anyone know, why is that, and how I can go back to the 2x3 rows?
      Thank you,
      Falter
      S F 2 Replies Last reply Reply Quote 0
        sdetweil @falter
        @falter sounds like someone might have changed the settings of the regions without using custom.css
        • F Offline
          falter @falter
          I haven’t seen anything regarding this in he changelog to 2.32…
            sdetweil @falter
            @falter no. i meant you. we didn’t change that.
            we dont touch custom.css and that is the only other place where layout and style info is provided.
            how fid you upgrade?
            • F Offline
              falter @sdetweil
              @sdetweil ahh, I had that feeling it could be me…
              But I didn’t change anything css-related, as I don’t know css. I have two MM with different setup, only the cams are the same and the problem is with both.
              The upgrade was as always: git pull and npm run install-mm
                sdetweil @falter
                @falter ok, if you had used my upgrade script we would have a log to examine
                can you show the 1st hundred or so message for MagicMirror startup
                if you are using the default calendar, note that our logging messages include the gull url, so blank them or make them unusable from the log messages
                  another thing is to open the developer window elements tab, and capture the html so we can look at it.
                  see the second link in my signature below
                  once you located the html content for the module,
                  tight click and copy
                  then paste somewhere, send to me, same userid at gmail
                  • F Offline
                    falter @sdetweil
                    @sdetweil thank you very much for taking the time!
                    For the logs, do I have to change the loglevel? There is not much in mm-out.log, or where do I have to look?
                    Here is the content of the container from dev-window:
                    <div class="container"><div id="module_0_MMM-RTSPtoWeb" class="module MMM-RTSPtoWeb MMM-RTSPtoWeb" style="order: 0;"><header class="module-header" style="display: none;">undefined</header><div class="module-content"><video class="rtw-video" autoplay="" playsinline="" style="max-width: 100%;"></video></div></div><div id="module_1_MMM-RTSPtoWeb" class="module MMM-RTSPtoWeb MMM-RTSPtoWeb" style="order: 0;"><header class="module-header" style="display: none;">undefined</header><div class="module-content"><video class="rtw-video" autoplay="" playsinline="" style="max-width: 100%;"></video></div></div><div id="module_2_MMM-RTSPtoWeb" class="module MMM-RTSPtoWeb MMM-RTSPtoWeb" style="order: 0;"><header class="module-header" style="display: block;">Nordseite</header><div class="module-content"><video class="rtw-video" autoplay="" playsinline="" style="max-width: 100%;"></video></div></div><div id="module_3_MMM-RTSPtoWeb" class="module MMM-RTSPtoWeb MMM-RTSPtoWeb" style="order: 0;"><header class="module-header" style="display: block;">Terrasse</header><div class="module-content"><video class="rtw-video" autoplay="" playsinline="" style="max-width: 100%;"></video></div></div><div id="module_4_MMM-RTSPtoWeb" class="module MMM-RTSPtoWeb MMM-RTSPtoWeb" style="order: 0;"><header class="module-header" style="display: block;">Garten</header><div class="module-content"><video class="rtw-video" autoplay="" playsinline="" style="max-width: 100%;"></video></div></div><div id="module_5_MMM-RTSPtoWeb" class="module MMM-RTSPtoWeb MMM-RTSPtoWeb" style="order: 0;"><header class="module-header" style="display: block;">Südseite</header><div class="module-content"><video class="rtw-video" autoplay="" playsinline="" style="max-width: 100%;"></video></div></div></div>
                      sdetweil @falter
                      @falter out.log was where
                      here is formatted html
                            </div>
                         </div>
                            </div>
                         </div>
                            </div>
                         </div>
                            </div>
                         </div>
                            </div>
                         </div>
                            </div>
                         </div>
                      </div>
                      so you have 6 instances of module, which will be stacked vertically by default.
                      I see some change was made to container, now in main.css where is wasn’t before…
                      I think this is a side effect to the “order” config option…
                      I don’t know how to fix it at the moment… I am busy most of the day
                      • F Offline
                        falter
                        ok, what do you mean with change now in main.css, container and order config? Was it me? I have this running for years and it could be, some time ago, I script-kiddie’d something in main.css, but I think this would be overwritten by the update?
                        Any hint where I could look?
