    Nodejs version/update issue
    2 Posts 2 Posters 982 Views 2 Watching
    • L Offline
      lightsaberluke
      When downloading nodejs the version that downloads is 23.11.1 and I cannot get it to update to the required version in order to install MagicMirror. I’m not sure what I am missing becuase I have attempted to update it and reinstall in and get latest and I can’t seem to get it to work. (Note: I am new to this.)
        sdetweil @lightsaberluke
        @lightsaberluke yes, system is tricky sometimes
        if you had used the install or upgrade script it would have handled this problem for you
        see https://github.com/sdetweil/MagicMirror
        but you can use one of the selective node tools
        i recommend n
        do this
        sudo npm install n -g
        sudo n 22.14
        hash -r
        node -v
        you should now have node 22.14 or 22.15
        now
        npm run install-mm
        • B British_Kiwi referenced this topic on
