    Get MMM-OpenWeatherMapForecast to show Fahrenheit instead of Celsius?
    11 Posts 2 Posters 2.5k Views 2 Watching
      Athlon
      I know this must be a basic question, but I simply cannot find a way to change the reported temperature to Fahrenheit.
        sdetweil @Athlon
        @Athlon module config option units?
          Athlon @sdetweil
          imperial (units) worked, but you knew it would :)
          Thank you!!
            sdetweil @Athlon
            @Athlon you should use my MMM-Config module
            it provides a form for filling in the config options for MagicMirror and all modules found in the modules folder
            is also allows you to open the module readme to understand the options gor each module as you go along
            also provides installation of modules from the 3rd
            party list or others not yet listed
            A 2 Replies Last reply Reply Quote 0
              Athlon @sdetweil
              I’ll definitely try that - Thanks again.
                Athlon @sdetweil
                I’ve installed it - works great!
                The only thing I can’t figure out is how to access it from my desktop. I run MM on an RPi.
                I’ve tried to change the address in the Basic section, but no joy.
                  sdetweil @Athlon
                  @Athlon address:“0.0.0.0”,
                  ipWhitelist:[],
                  then you should be able to access MagicMirror from desktop
                  and then add then extra path, per the doc
                  /configure
                  or
                  /installer
                    Athlon @sdetweil
                    I’ve tried to get it to work from my desktop, but no joy.
                    This is the code at the top of my config.js file:
                    /* Config Sample
                     * see https://docs.magicmirror.builders/configuration/introduction.html
                     * and https://docs.magicmirror.builders/modules/configuration.html
                     * You can use environment variables using a `config.js.template` file instead of `config.js`
                     * which will be converted to `config.js` while starting. For more information
                     * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
                    let config = {
                    	address: "localhost",	// Address to listen on, can be:
                    	port: 8080,
                    	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                    	ipWhitelist: [],	// Set [] to allow all IP addresses
                    	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
                    	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
                    	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
                    	language: "en",
                    	locale: "en-US",   // this variable is provided as a consistent location
                    			   // it is currently only used by 3rd party modules. no MagicMirror code uses this value
                    			   // as we have no usage, we  have no constraints on what this field holds
                    			   // see https://en.wikipedia.org/wiki/Locale_(computer_software) for the possibilities
                    	timeFormat: 24,
                    	units: "metric",
                    This what I’ve tried entering in Firefox on my desktop:
                    http://192.168.50.177:8080/configure
                    http://192.168.50.177:9000/configure
                    0.0.0.0
                    0.0.0.0/configure
                    When using 0.0.0.0, I notice the address changes to “https://127.0.0.1/configure”.
                    In all cases, I get “Unable to Connect”.
                    Here’s the code for the MMM-Config in my config.js file:
                    		module:"MMM-Config",
                    		position:"top_right",
                    			// the QR code (if requested) will appear here
                    		config:{
                    Thank you for hanging in there with me on this. It works fine when I plug a mouse and keyboard into the RPi, by the way.
                      sdetweil @Athlon
                      @Athlon because you have
                      address: “localhost”
                      ONLY localhost can connect
                      http://localhost:8080/configure
                      you cannot use the IP address of this machine even when ON this machine…
                      IF you used
                      address:“0.0.0.0”
                      that means listen on ALL interfaces (localhost AND network adapter, without specifying a specific address)
                      then http://localhost:8080
                      AND
                      would work… if you had wifi and ethernet
                      then localhost, wifi address AND ethernet address would be acceptable
                      because you didn’t specify showQR, it defaults to false,
                      and this would have displayed a message about having to use localhost ONLY
                        Athlon @sdetweil
                        That did it - changed the address to 0.0.0.0 and used “http://192.168.50.177:8080/configure”.
                        Awesome!
                        Thank you!!
                          sdetweil @Athlon
                          @Athlon awesome. i should have added to the above, that localhost ALWAYS means THIS machine, no matter WHERE ITS USED. phone. laptop, desktop , server, nas, pi
