    Home Dashboard
    13 Posts 7 Posters 13.4k Views 10 Watching
    • uros76U Offline
      uros76 @Hilt
      @Hilt cool stuff, that looks clean.
      Which MM module are you using to display HA as iFrame? Refresh rate 15s is a must, can it be faster refresh rate?
      S H 2 Replies Last reply Reply Quote 1
        stephanvdplas @Hilt
        @Hilt wow it looks great!
          sdetweil @uros76
          @uros76 you can use MMM-HomeAssistantSensors
          No need for iframe. Then you can style them
          uros76U 1 Reply Last reply Reply Quote 0
          • uros76U Offline
            uros76 @sdetweil
            @sdetweil yes I know ha module, I am using it for sensors data without any fancy looks. I’m too lazy and no time to learn styling every detail 😀
            • H Offline
              Hilt @uros76
              @uros76
              Thank you kindly !
              I’m using this older module as it suits my needs i.e. No configurable options for refresh. As the values change in HA, so they change on the mirror
              If you need an option with a lot more configurable options including refresh interval, have a look at this module
                seabass @Hilt
                @Hilt I like the depth of the mirror. Can you tell me what monitor you use? Thanks!
                • H Offline
                  Hilt @seabass
                  @seabass Thank you !
                  I used an old Samsung BX2031.
                  The secret sauce here is that this particular monitor uses an external AC adapter / power brick. That’s how I could keep everything so thin. The AC adapter sits in the cupboard with the Pi . I simply extended the barrel jack side to reach the monitor through the conduit.
                  For video signal, I used a DVI to HDMI converter ( similar to pic below ) on the monitor side , and a 5m HDMI cable back to the Pi.
                  To make space for the power and video connectors, I recessed a wall box ( like those used for your bog standard light switch ) at the end of the cable conduit and lined it all up. So said connectors actually poke back into the wall a fair bit. But the wall box hides that nicely.
                  • F Offline
                    Faiek
                    @Hilt This looking great , fantastic & clean.
                    Being in SA what mirror glass did you use & from where did you get it
                    • H Offline
                      Hilt @Faiek
                      @Faiek
                      Howdy !
                      Initially I looked into real 1-way mirror. But it was just too expensive for the size that I needed in our fair country.
                      So ! First I tried the DIY route. Picked up some 4mm glass, found some mirror tint film online and gave it a bash ! That film promptly ended up in a ball in the bin :S. It’s clear ( vicious pun ) that I’m handy with woodwork but suck at tinting.
                      I then took my sheet of glass to a car window tint business and they did a great job. I ended up going with the most reflective film they had as one step down just looked milky. Sadly that business is no longer in operation. But any car tint spot should do.
                      F 1 Reply Last reply Reply Quote 1
                      • F Offline
                        Faiek @Hilt
                        @Hilt - great thanks for reply- reckon I’ll have to the same
                        • H Hilt referenced this topic on
                          jamesarm
                          What did you use for the frame? That looks like the same trim I use on my paintings but don’t recognize the inner bevel, did you add that onto the frame?
                          • H Offline
                            Hilt @jamesarm
                            @jamesarm
                            It was a regular off the shelf mirror in a frame. I just removed the actual mirror portion from the frame and replaced it with 4mm tinted glass.
