    Need "correct" version of node-libgpiod ....
    22 Posts 3 Posters 4.2k Views 3 Watching
      @sdetweil Dear Sam,
      thanks for this information.
      Can you please enlighten me?
      I can read what you wrote and I got a light idea - but didn’t understand …
      I definitely have used your install script.
      what is @electron and
      what correlation is between node-libgpiod and @electron ? and what will this
      ../../node_modules/.bin/electron-rebuild
      do?
      Sorry for these questions - I would like to understand, what happens.
      If this is “neccessary” I will try to automate this for others with a postinstall script.
      Thanks for your effort!
      warmest regards,
      Ralf
      S 2 Replies Last reply
        sdetweil @rkorell
        @rkorell javascript is compiled to a byteform by the nodejs engine
        there is one embedded inside electron and one outside,
        nodejs
        the bytecode has a version number.
        the engine needs the proper version to execute it
        like version 21 added a new instruction, but vers 20 engine cant execute it
        i dont know the version differences
        anyhow, the electron-rebuild application will rebuild the parts of the js code used in the node_helper to match the internal/embedded node engine inside electron
        because startup is using the electron app
        in server mode we use the mode app
        you should know if you run
        node serveronly, then the bytecode has to match the nodejs standalone engine version
        this is why we try to keep the nodejs/electron internal node versions the same
        (there is a node rebuild too)
        R 1 Reply Last reply
          sdetweil @rkorell
          @rkorell here is the postinstall i provide for a couple modules
          #!/bin/bash
          base=~/MagicMirror
          logfile=/dev/null
          if [ ! -e $base/node_modules/@electron/rebuild ];  then
              cd $base
              if [ -e $base/node_modules/.bin/electron-rebuild ]; then
          	# remove the old version
                npm uninstall electron-rebuild >>$logfile 2>&1
              fi
              # install the new version
              npm install @electron/rebuild >>$logfile 2>&1
              cd - >/dev/null
          fi
          they changed the name of the npm package
          but as i install it as part of install/upgrade
          its correct most of the time
          and in package.json, in the scripts section add
          "postinstall":"./postinstall"
            OK, thanks.
            It seems that rebuild have corrected the error for the module.
            When I try to run a node-command in the shell (terminal) then I get an similar error message as above.
            Is this caused by your explanation part above?
            Different versions needed for either terminal or inside mirror?
            Can you tell me HOW the magic mirror is started (when I have used your install script)?
            Is there a way to test something which had to run in the mirror (like the module) on commandline?
            To illustrate what I mean:
            I have a very short test-script test-gpiod.js
            // test-gpiod.js , Aug 2025, Dr. Ralf Korell
            const { Chip } = require("node-libgpiod");
            try {
              const chip = new Chip(0);
              console.log("Chip label:", chip.getChipLabel());
            } catch (err) {
              console.error("Error loading chip:", err);
            which I try to run with
            node test-gpiod.js
            But this produces error message:
            /home/pi/MagicMirror/modules/MMM-PresenceScreenControl/node_modules/bindings/bindings.js:121
            throw e;
            Error: The module '/home/pi/MagicMirror/modules/MMM-PresenceScreenControl/node_modules/node-libgpiod/build/Release/node-libgpiod.node'
            was compiled against a different Node.js version using
            NODE_MODULE_VERSION 128. This version of Node.js requires
            NODE_MODULE_VERSION 115. Please try re-compiling or re-installing
            the module (for instance, using `npm rebuild` or `npm install`).
            at Module._extensions..node (node:internal/modules/cjs/loader:1586:18)
            at Module.load (node:internal/modules/cjs/loader:1288:32)
            at Module._load (node:internal/modules/cjs/loader:1104:12)
            at Module.require (node:internal/modules/cjs/loader:1311:19)
            at require (node:internal/modules/helpers:179:18)
            at bindings (/home/pi/MagicMirror/modules/MMM-PresenceScreenControl/node_modules/bindings/bindings.js:112:48)
            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PresenceScreenControl/node_modules/node-libgpiod/lib/misc.js:1:37)
            at Module._compile (node:internal/modules/cjs/loader:1469:14)
            at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
            at Module.load (node:internal/modules/cjs/loader:1288:32) {
            code: 'ERR_DLOPEN_FAILED'
            Node.js v20.18.1
            Thanks for any help!
            Warmest regards,
            Ralf
              sdetweil @rkorell
              @rkorell MM is started by doing node --run or npm start or npm run start
              that matches a script in the scripts section of package.json
              the MagicMirror installed files support 3 different runtimes
              npm start - full using electron
              		"start:x11": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron  js/electron.js",
              npm run server - server mode only , using node engine
              		"server": "node ./serveronly",
              npm run client - UI mode using electron
              node clientonly --address 192.168.1.5 --port 8080
              which does this to launch electron, not it doesn’t use the module node_helpers, as its the UI portion
              only… the server side (under full, or server only) does that
              const child = require("node:child_process").spawn(electron, elecParams, options);
              as I said before, the electron embedded node engines CAN be different than the install standalone nodejs version
              node -v
              will tell you the standalone node js version.
              the problem you have, I mentioned in the prior post, if the node versions don’t match, then
              you MAY have to recompile when switching runtime choices…
              npm rebuild
              will fix the standalone node version
              electron-rebuild
              will fix the electron version
              I believe the current electron version is 22, and the node version we require is 22
              this is because the standalone node version of 24 has dropped support for 32 bit runtimes… and knocks out using the
              32 bit legacy raspi OS images that some use…
              we put out a message to tell the versions when you start MM
              VERSIONS: electron: 36.6.0; used node: 22.15.0; installed node: 22.15.0; npm: 10.9.2; pm2: 6.0.8
              SO… fun times… keeping the node versions synched will avoid the problem you are encountering
                Dear Sam, OK, thanks for this.
                Not fully understood…
                How can I
                1. figure out, how my mirror is started? (looooong ago I‘ve used your install script and (if I remember correctly) I‘ve answered „yes“ to „do you want automatically start your mirror at system startup“ - or something similar. - Never took care about, what is done - it worked (and still works)…)
                2. double check the above „VERSIONS“ - message - is this message in logfile?
                3. can I get „keeping the node versions synched“?
                Thanks for further advise!
                Warmest regards,
                Ralf
                  sdetweil @rkorell
                  @rkorell 1. my pm2 setup uses the file
                  ~/MagicMirror/installers/mm.sh
                  you can see that by using the
                  pm2 info xxxx
                  command, where xxx is the name or number of the app row in
                  pm2 status
                  output, from my desktop , note you CAN setup the SAME NAMED app multiple times,
                  so the pm2 start app_name
                  might be ambiguous
                  so pm2 start 8 would target the app on line 8
                  │ id │ name                │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                  │ 8  │ MagicMirror         │ default     │ 2.32.0… │ fork    │ N/A      │ 0      │ 245… │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
                  │ 7  │ MagicMirror 8       │ default     │ 2.31.0… │ fork    │ N/A      │ 0      │ 8    │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
                  │ 6  │ MagicMirror1        │ default     │ 2.31.0… │ fork    │ N/A      │ 0      │ 13   │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
                  │ 0  │ Smart Mirror        │ default     │ 0.0.30  │ fork    │ N/A      │ 0      │ 31   │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
                  │ 2  │ checkarec           │ default     │ N/A     │ fork    │ 2870     │ 19D    │ 0    │ online    │ 0%       │ 3.4mb    │ sam      │ disabled │
                  │ 5  │ smart-mirror        │ default     │ 0.0.31  │ fork    │ N/A      │ 0      │ 8    │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
                  │ 4  │ smart-mirror ttt    │ default     │ 0.0.30  │ fork    │ N/A      │ 0      │ 10   │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
                  │ 3  │ start_alexa_bk      │ default     │ N/A     │ fork    │ 2871     │ 19D    │ 0    │ online    │ 0%       │ 2.4mb    │ sam      │ disabled │
                  │ 1  │ startspot           │ default     │ N/A     │ fork    │ 6315     │ 19D    │ 439  │ online    │ 0%       │ 2.5mb    │ sam      │ disabled │
                  │ 9  │ testups             │ default     │ N/A     │ fork    │ 2885     │ 19D    │ 0    │ online    │ 0%       │ 3.2mb    │ sam
                  using pm2, you can view the log with
                  pm2 logs yyy --lines=xxxx
                  yyy is the name or number of the app from status above), if not supplied,
                  output from all managed apps is displayed, 1 after the others
                  xxxx is the count of most recent lines to display (default 15)
                  you can also see the files(.out and .err, by app) in the
                  ~/.pm2/logs
                  folder
                  MM puts out a messages at runtime (this from my desktop system)
                  [2025-08-09 09:47:38.743] [INFO]  System information:
                  ### SYSTEM:   manufacturer: System manufacturer; model: System Product Name; virtual: false
                  ### OS:       platform: linux; distro: Ubuntu; release: 22.04.5 LTS; arch: x64; kernel: 5.15.0-144-generic
                  ### VERSIONS: electron: 36.6.0; used node: 22.15.0; installed node: 22.15.0; npm: 10.9.2; pm2: 6.0.8
                  ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
                  notice the versions line
                  keep the node versions synced… yes manually (I use the nodejs version of nvm, called n )
                  if installed this will show the versions installed
                  n list
                  and
                  n
                  will show the list AND the current one, but you have to type q to exit the list
                  (because n updates the /usr/local/bin folder, you have to use sudo to actually install or change the active version)
                  or
                  if you use my install/upgrade script they will make sure the correct standalone version is installed
                  my scripts install and use n if needed to change versions
                    @sdetweil Dear Sam,
                    thanks again for this long explanation!
                    My versions (if I interpret correctly) doesn’t mismatch :-(
                    0|MagicMir | ### SYSTEM:   manufacturer: ; model: ; virtual: false
                    0|MagicMir | ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-2712
                    0|MagicMir | ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
                    0|MagicMir | ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                    So I’m not sure at all, what to do.
                    pi@MagicMirrorPi5:~ $ n list
                    node/20.18.1
                    Does show up exact this version, as well.
                    Where are my problems from ???
                    Thanks a LOT for any idea!
                    Ralf
                      sdetweil @rkorell
                      @rkorell
                      so, if, in the module folder you do
                      npm rebuild
                      it will fix the version to the standalone node engine
                      if you do
                      electron-rebuild
                      it should fix the version to the electron embedded node engine
                      if the engine is the same, only one of those is required
                      R 2 Replies Last reply
                        @sdetweil OK; thanks.
                        I will stop to handle these mismatches.
                        Will try to get the MM-Module runnable .
                        Console/terminal runs with node may not be necessary …
                        Thanks anyway for your kind support!
                        Ralf
                          @sdetweil Dear Sam,
                          just FYI: I’ve just identified that my main problem is NOT the version mismatch but a major change in node-libgpiod’s handling of GPIO-ressources.
                          This was the main reason for mal-function of PIR sensor detection. “Version” was a side effect, not root-cause.
                          I’m nearly done with this and it seems that it will work as intended…
                          Thanks again for your support!
                          Regards,
                          Ralf
                            sdetweil @rkorell
                            @rkorell awesome. yes gpio changes are a pain!!
                              @sdetweil yes, indeed …
                                schlomm @rkorell
                                @rkorell Do have any any resources for your current development? I’m also stucking at a similar problem handling GPIO for buttons using a Raspberry Pi 5.
                                Do you have a Github Repository?
                                  rkorell Module Developer @schlomm
                                  @schlomm I’m absolute beginner …
                                  Had HEAVILY used AI to get this done and have recycled a LOT.
                                  GPIO part is from old (discontinued) module MMM-Pir from Bugsounet.
                                  This is reflected in pirLib.js - sliightly modified for my purposes.
                                  I do have a repository - pushed literally minutes ago …
                                  Feel free to have a look.
                                  Buttons should work with some modification. Essentiall for my purposes I simply query state of a single GPIO pin - to which a PIR sensor is connected. Code must be enhanced to handle more than one pin - if you are talking about “butons” - which signals plural…
                                  As mentioned such modification should be doable with AI as well.
                                  [ EDIT : My system is a raspi5 / bookworm as well - this is main reason for some difficulties. Some procedures simply doesn’t work anymore with new libraries and I had to change implementation…]
                                  Good luck!
                                  Warm regards,
                                  Ralf
                                    @sdetweil Dear Sam,
                                    I was able to get this done - to my big surprise …
                                    As announced, I just have pushed it to git and will post a corresponding message tomorrow.
                                    Do I get it right that it is recommended to edit the modules page as well?
                                    And the 3rd Party Modules page then will populate by itself, right?
                                    Thanks!
                                    Warmest regards,
                                    Ralf
                                      sdetweil @rkorell
                                      @rkorell yes, you edit the wiki page, and then the 3rd party list will pick up those changes on the next refresh (once a day)
                                      • R rkorell has marked this topic as solved on
                                        @sdetweil thx!
                                          schlomm @rkorell
                                          @rkorell Thanks for publishing your great module. I already use it and hell yeah - it’s great :)
                                          I was also able to make the needed modification to my “Buttons”-module using the node-libgpiod package. Main reason why it was not working was the missing postinstall script.
                                          Thanks and “schöne Grüße” :)
                                            @schlomm
                                            This is really cool.
                                            Awesome that it works as designed…
                                            (Was a little bit afraid that especially postinstall will fail and module doesn‘t work as expected…)
                                            So thanks for (first !) confirmation for working module!
                                            Warmest regards,
                                            Ralf
                                            • Schöne Grüße zurück - danke für‘s Kompliment und Danke für‘s „externe“ Testen! :-)
