    Non-Typical Setup, MM Stops Showing New Pictures (ImagesPhotos module)
    18 Posts 2 Posters 4.4k Views 2 Watching
      sdetweil @ember1205
      @ember1205 this is socket by module
      specifically the
      socketNotificationReceived   no longer fires
      the socket timed out, and was disconnected… the node helper sends, but the socket is disconnected and the data is tossed (WITH NO NOTIFICATION)
      the module STARTS the connection on the 1st sendSocketNotification(), but NEVER again
      (the module sent a request to the helper, but the helper didn’t response (hasnt responded ‘yet’ 2 hours later… finger tapping… still waiting!)
      another way to ‘test’ if this is impacting, is to refresh the MM page, ctrl-r, and see if the data shows up this time.
      we have seen it repeatedly on the calendar module, the old timeout is 5 seconds. (default)…
      but list of pics could fall into the same ‘long’ response time issue
      I think they ‘fixed’ a socket.io bug in some lib refresh which suddenly surfaces the issue… we also ‘cleaned’ up how we setup sockets a few releases ago
      • E Offline
        ember1205 @sdetweil
        @sdetweil Issue I see now is that the indicated lines to add the lines after do not exist in my versions of server or socketclient…
          sdetweil @ember1205
          @ember1205 what version are you using?
          look at the top of package.json
          • E Offline
            ember1205 @sdetweil
            @sdetweil Version of MM? 2.13
              sdetweil @ember1205
              @ember1205 ok, this fix doesn’t apply all the way back there… 32-13 19 releases/4 = one short of 5 years… wow!
              • E Offline
                ember1205 @sdetweil
                @sdetweil So what you’re saying is that maybe I wanna start by upgrading? lol
                I’m running on a Linux virtual guest, so I can easily snapshot it before I try and upgrade. What’s the best option for me to get current?
                  sdetweil @ember1205
                  @ember1205 if it’s a virtual machine, not docker
                  You will have to upgrade the os too, so don’t touch the existing vm
                  Backup
                  Use my scripts, save to github
                  Create new Vm
                  Use my scripts to install MagicMirror
                  Use my restore to put back config
                  Backup/restore
                  https://github.com/sdetweil/MagicMirror-backup-restore
                  Install/upgrade
                  • E Offline
                    ember1205 @sdetweil
                    @sdetweil I keep the OS updated separately on its own. What kind of updates are you suggesting would be necessary here?
                      sdetweil @ember1205
                      @ember1205 the latest node requires some libraries not available on buster level, some gpio modules need help
                      On bullseye and later
                      Node 22.14 requirement is the last to provide binaries for 32 bit
                      • E Offline
                        ember1205 @sdetweil
                        @sdetweil I’m not running on a Pi or its software… Full install of opensuse linux. And I keep it fully patched and at the current release level.
                          sdetweil @ember1205
                          @ember1205 did you make any progress here?
                          MM is just an app…
                          so you could copy the MagicMirror folder to save it
                          and then run the upgrade script or install a new version (using my install script, and move the current folder instead of copy)
                          • E Offline
                            ember1205
                            Yeah, I actually did more troubleshooting and such over the weekend and ended up doing a full upgrade to the RPi OS and then updating MM on there as well.
                            My troubleshooting was showing that the server side “shouldn’t” have been the issue because launching a browser on just about any other device would result in the continual processing and rotating of photos and such. And, even though the photo processing seemed to be the only piece that would stop updating on the client, the fact that it worked everywhere else led me to take the leap and do all of the updates on the RPi.
                            After doing the full upgrade to the latest version of RaspiOS (Bullseye) and then updating MM to the latest (using your scripts), it seems to be working correctly again and hasn’t stopped rotating the photos since the upgrade.
                              sdetweil @ember1205
                              @ember1205 great feedback, thank you
                              Glad it’s working again
                                sdetweil @ember1205
                                @ember1205 the latest PIOS is bookworm right?
                                • E Offline
                                  ember1205 @sdetweil
                                  @sdetweil Yeah… I should have said I updated to the latest version of Bullseye with all patches. I haven’t made the last step to Bookworm yet…
