    CalendarEXT3 questions
    9 Posts 2 Posters 1.8k Views 2 Watching
    • _ Offline
      _V_
      Hey again guys
      So right now I got the Cal3 running with a Google calendar. Everythings working good for now, except “CW” is only showint “CW1” in every week. The default calendar is counting correctly. Also I wonder why its showing “CW” instead of “KW” relating to german language. Every possible local setting is put right though.
      Also color in config is not shown - I set it up like in the description.
      Is it possible to somehow put a list additional to the calender? I got some tasks/list points set up in Google but the module obviously is not “asking” for them.
      Thanks a lot
        sdetweil @_V_
        @_V_ said in CalendarEXT3 questions:
        The CW counting not
        try this
                  minimalDaysOfNewYear: "1",
        I posted somewhere before (a month ago I think) , but can’t find it…
          sdetweil @_V_
          @_V_ cw is a bug
          add this to the ext3
                            startDayIndex: 1,
          can you show the default calendar config (xxx out the urls)
          the google tasks are are not exposed in the calendar feed…
          • _ Offline
            _V_
            @sdetweil Yes Sam, I know that theyre not there… I just asked, if theres a possibility to get something done
            Ill share the code tomorrow, thank you
              sdetweil @_V_
              @_V_ one needs a different api… not calendar
              I don’t know what that is across all the calendar sources…
              and ext3 isn’t looking for tasks, so that would be a different thing, cause if u made it a fake cal entry you wouldn’t be able to tell
              • _ Offline
                _V_
                Good morning
                So Ive noticed the color is applying, the CW is not solved, probably cause I put the snipped in the wront place?
                 			module: "MMM-CalendarExt3",
                  			position: "bottom_bar",
                  			title: "",
                    			mode: "month",
                    			instanceId: "basicCalendar",
                    			locale: 'de-DE',
                    			maxEventLines: 5,
                    			firstDayOfWeek: 1,
                    			calendarSet: ['Testkalender', '', ''],
                			refreshInterval: 900000,
                			startDayIndex: 1
                  sdetweil @_V_
                  @_V_ i needed the config of the default calendar where the colors are defined
                  • _ Offline
                    _V_
                    Like said above, the colors work now…
                    The CW counting not, thats why I showed you that part man…
                      sdetweil @_V_
                      The CW counting not
                      try this
                      • _ Offline
                        _V_
                        That solved the problem. Thank you sir
                        If anyone cares: “CW” is shown even after correct/different local settings because it´s written as element in the stylesheet from calendarEXT3, so you have to change the term there.
