    CalendarEXT3 questions
    9 Posts 2 Posters 1.5k Views 2 Watching
      sdetweil @_V_
      @_V_ cw is a bug
      add this to the ext3
                        startDayIndex: 1,
      can you show the default calendar config (xxx out the urls)
      the google tasks are are not exposed in the calendar feed…
      • _ Offline
        _V_
        @sdetweil Yes Sam, I know that theyre not there… I just asked, if theres a possibility to get something done
        Ill share the code tomorrow, thank you
          sdetweil @_V_
          @_V_ one needs a different api… not calendar
          I don’t know what that is across all the calendar sources…
          and ext3 isn’t looking for tasks, so that would be a different thing, cause if u made it a fake cal entry you wouldn’t be able to tell
          • _ Offline
            _V_
            Good morning
            So Ive noticed the color is applying, the CW is not solved, probably cause I put the snipped in the wront place?
             			module: "MMM-CalendarExt3",
              			position: "bottom_bar",
              			title: "",
                			mode: "month",
                			instanceId: "basicCalendar",
                			locale: 'de-DE',
                			maxEventLines: 5,
                			firstDayOfWeek: 1,
                			calendarSet: ['Testkalender', '', ''],
            			refreshInterval: 900000,
            			startDayIndex: 1
              sdetweil @_V_
              @_V_ i needed the config of the default calendar where the colors are defined
              • _ Offline
                _V_
                Like said above, the colors work now…
                The CW counting not, thats why I showed you that part man…
                  sdetweil @_V_
                  @_V_ said in CalendarEXT3 questions:
                  The CW counting not
                  try this
                            minimalDaysOfNewYear: "1",
                  I posted somewhere before (a month ago I think) , but can’t find it…
                  • _ Offline
                    _V_
                    That solved the problem. Thank you sir
                    If anyone cares: “CW” is shown even after correct/different local settings because it´s written as element in the stylesheet from calendarEXT3, so you have to change the term there.
