    MMM-Spotify having trouble with authentification
    7 Posts 5 Posters 1.6k Views 5 Watching
    • FoziF Offline
      Fozi Project Sponsor @Jack_Gregorski
      @Jack_Gregorski Are you using a free or premium account? The free account will not work. See https://github.com/skuethe/MMM-Spotify#restrictions
        sdetweil @Jack_Gregorski
        @Jack_Gregorski on the redirect url in the Spotify config did you use http://localhost:8888/callback
        as per the readme?
        that url should show on the error page
          @Jack_Gregorski ok, i see the same thing…
          workaround
          change Spotify.js
          from
          line 249-250
              let file = path.resolve(__dirname, this.config.TOKEN)
              let waitForFileTimeout = 0
          to
              let waitForFileTimeout = 60*1000
          basically the code sets up the server to listen for the callback, but doesn’t wait for you to interact with the web page
          opened issue
          https://github.com/skuethe/MMM-Spotify/issues/192
          • K Offline
            kinggiotai
            @Jack_Gregorski said in MMM-Spotify having trouble with authentification:
            I am trying to install the MMM-Spotify module onto my magic mirror. I follow the steps on the github page and everything seems to be working up until the authentication stage. The Spotify popup opens after I run the node first_auth.js command in the terminal, but when I click allow in the new webpage I get an error, “This site can’t be reached localhost refused to connect.” Any ideas on how to fix this, any help would be appreciated.
              sdetweil @kinggiotai
              @kinggiotai can you tell which module you are using
              git remote -v
              in the module folder will tell the source repository
                @kinggiotai did you setup the spotify.config.json from the
                auth callback example?
                      "USERNAME": "A_NAME_TO_IDENTIFY_YOUR_ACCOUNT",
                      "CLIENT_ID": "PUT_YOUR_SPOTIFY_APP_CLIENT_ID",
                      "CLIENT_SECRET": "PUT_YOUR_SPOTIFY_APP_CLIENT_SECRET",
                      "TOKEN": "./USERNAME_token.json",
                      "AUTH_DOMAIN": "http://YOUR_DEVICES_IP",
                      "AUTH_PORT": "8889"
                I had to do that just now
                the domain/port MUST match the callback address in the spotify app config
                from my app config
                callback
                http://localhost:8100/callback
                json file strings to match
                domain is http://localhost
                port is 8100
