    Update, unable to connect.
    22 Posts 3 Posters 9.6k Views 3 Watching
      Richard238 @mumblebaj
      @mumblebaj said in Update, unable to connect.:
      npm run config:check
      pi@mmv2:~/MagicMirror $ npm run config:check
      > magicmirror@2.32.0 config:check
      > node js/check_config.js
      [2025-08-17 12:14:16.030] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
      [2025-08-17 12:14:16.285] [ERROR] Your configuration file contains syntax errors :(
      Line 99 column 21: 'Log' is not defined.
      Lines 97/98/99:
                      // Override start method.
                      start: function () {
                          Log.log("Starting module: " + this.name);
        sdetweil @Richard238
        @Richard238 did the
        npm install
        complete?
        do this
        pm2 stop all
        rm -rf node_modules
        npm install
        the start MagicMirror manually
        npm start
          Richard238 @sdetweil
          pi@mmv2:/ $ pm2 stop all
          [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
          [PM2] [MagicMirror](0) â
          ââââââ¬âââââââââââââââââââââ¬âââââââââââ¬âââââââ¬ââââââââââââ¬âââââââââââ¬âââââââââââ
          â id â name               â mode     â ⺠   â status    â cpu      â memory   â
          ââââââ¼âââââââââââââââââââââ¼âââââââââââ¼âââââââ¼ââââââââââââ¼âââââââââââ¼âââââââââââ¤
          â 0  â MagicMirror        â fork     â 300  â stopped   â 0%       â 0b       â
          ââââââ´âââââââââââââââââââââ´âââââââââââ´âââââââ´ââââââââââââ´âââââââââââ´âââââââââââ
          pi@mmv2:/ $ cd ~/MagicMirror
          pi@mmv2:~/MagicMirror $ rm -rf node_modules
          pi@mmv2:~/MagicMirror $ npm install
          npm error code EIO
          npm error syscall read
          npm error errno -5
          npm error EIO: i/o error, read
          npm error A complete log of this run can be found in: /home/pi/.npm/_logs/2025-08-17T11_35_16_106Z-debug-0.log
          pi@mmv2:~/MagicMirror $ npm start
          > magicmirror@2.32.0 start
          > node --run start:x11
          /bin/sh: 1: ./node_modules/.bin/electron: not found
            @Richard238 of course you dont need to do npm start if the other stuff fsiled
            rm package-lock.json
            rm -rf node_modules
            npm cache clean --force
            npm install
            let me know the results
              Pi (Pi4 in metal heat-sink case) was running really warm. Powered it off and left it for a while.
              Powered on, it has no networking and file manager does nothing.
              If I can get networking enabled, I’ll make a config and CSS backup.
              Looks like it’s going to need an OS reinstall which will have to wait until I have time to do so.
              I’ll report back when that’s done.
                @Richard238 my backup also gets the module source url for every add on module, so that they can be reinstalled again
                and gets files created (like access tokens etc) which may be needed to make each module work
                  I couldn’t use that as I the Pi had no network, no file manager. It was bricked :(
                  New OS, new default vanilla MM all good.
                  And then I remembered the orig MM was still on a SD Card before I swapped over to a USB drive.
                  Copied all I needed, seems to be all good so far!
                  Thanks for your help. :)
                  S 2 Replies Last reply Reply Quote 1
                    @Richard238 awesome… thanks for the feedback…
                      @Richard238 said in Update, unable to connect.:
                      backup , backup, backup…
                        Hahhahaaaa! Yes, well I do make regular backups of config and CSS, it was the modules folder I was missing. Lesson learned there.
                          @Richard238 use my script
                          It will record incremental changes
                          https://github.com/sdetweil/MagicMirror-backup-restore
