    Update, unable to connect.
    22 Posts 3 Posters 9.5k Views 3 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @Richard238
      @Richard238 said in Update, unable to connect.:
      0|MagicMirror | [2025-08-16 19:11:32.117] [ERROR] Your configuration file contains syntax errors :(
      0|MagicMirror | Line 99 column 21: ‘Log’ is not defined.
      This seems to indicate that there is an error in config/config.js. Run the following on the command line in the ~/MagicMirror/ directory: npm run config:check
        Richard238 @mumblebaj
        @mumblebaj said in Update, unable to connect.:
        pi@mmv2:~/MagicMirror $ npm run config:check
        > magicmirror@2.32.0 config:check
        > node js/check_config.js
        [2025-08-17 12:14:16.030] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
        [2025-08-17 12:14:16.285] [ERROR] Your configuration file contains syntax errors :(
        Line 99 column 21: 'Log' is not defined.
        Lines 97/98/99:
                        // Override start method.
                        start: function () {
                            Log.log("Starting module: " + this.name);
          sdetweil @Richard238
          @Richard238 did the
          npm install
          complete?
          do this
          pm2 stop all
          rm -rf node_modules
          npm install
          the start MagicMirror manually
          npm start
            Richard238 @sdetweil
            pi@mmv2:/ $ pm2 stop all
            [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
            [PM2] [MagicMirror](0) â
            ââââââ¬âââââââââââââââââââââ¬âââââââââââ¬âââââââ¬ââââââââââââ¬âââââââââââ¬âââââââââââ
            â id â name               â mode     â ⺠   â status    â cpu      â memory   â
            ââââââ¼âââââââââââââââââââââ¼âââââââââââ¼âââââââ¼ââââââââââââ¼âââââââââââ¼âââââââââââ¤
            â 0  â MagicMirror        â fork     â 300  â stopped   â 0%       â 0b       â
            ââââââ´âââââââââââââââââââââ´âââââââââââ´âââââââ´ââââââââââââ´âââââââââââ´âââââââââââ
            pi@mmv2:/ $ cd ~/MagicMirror
            pi@mmv2:~/MagicMirror $ rm -rf node_modules
            pi@mmv2:~/MagicMirror $ npm install
            npm error code EIO
            npm error syscall read
            npm error errno -5
            npm error EIO: i/o error, read
            npm error A complete log of this run can be found in: /home/pi/.npm/_logs/2025-08-17T11_35_16_106Z-debug-0.log
            pi@mmv2:~/MagicMirror $ npm start
            > magicmirror@2.32.0 start
            > node --run start:x11
            /bin/sh: 1: ./node_modules/.bin/electron: not found
              @Richard238 of course you dont need to do npm start if the other stuff fsiled
              rm package-lock.json
              rm -rf node_modules
              npm cache clean --force
              npm install
              let me know the results
                Pi (Pi4 in metal heat-sink case) was running really warm. Powered it off and left it for a while.
                Powered on, it has no networking and file manager does nothing.
                If I can get networking enabled, I’ll make a config and CSS backup.
                Looks like it’s going to need an OS reinstall which will have to wait until I have time to do so.
                I’ll report back when that’s done.
                  @Richard238 my backup also gets the module source url for every add on module, so that they can be reinstalled again
                  and gets files created (like access tokens etc) which may be needed to make each module work
                    I couldn’t use that as I the Pi had no network, no file manager. It was bricked :(
                    New OS, new default vanilla MM all good.
                    And then I remembered the orig MM was still on a SD Card before I swapped over to a USB drive.
                    Copied all I needed, seems to be all good so far!
                    Thanks for your help. :)
                    S 2 Replies Last reply Reply Quote 1
                      @Richard238 awesome… thanks for the feedback…
                        backup , backup, backup…
                          Hahhahaaaa! Yes, well I do make regular backups of config and CSS, it was the modules folder I was missing. Lesson learned there.
                            @Richard238 use my script
                            It will record incremental changes
                            https://github.com/sdetweil/MagicMirror-backup-restore
