    Update, unable to connect.
    22 Posts 3 Posters 9.5k Views 3 Watching
      Richard238 @sdetweil
      pi@mmv2:~/MagicMirror $ node -v
      v22.14.0
      pi@mmv2:~/MagicMirror $ pm2 stop MagicMirror
      [PM2] Applying action stopProcessId on app [MagicMirror](ids: [ 0 ])
      [PM2] [MagicMirror](0) â
      ââââââ¬âââââââââââââââââââââ¬âââââââââââ¬âââââââ¬ââââââââââââ¬âââââââââââ¬âââââââââââ
      â id â name               â mode     â ⺠   â status    â cpu      â memory   â
      ââââââ¼âââââââââââââââââââââ¼âââââââââââ¼âââââââ¼ââââââââââââ¼âââââââââââ¼âââââââââââ¤
      â 0  â MagicMirror        â fork     â 2120 â stopped   â 0%       â 0b       â
      ââââââ´âââââââââââââââââââââ´âââââââââââ´âââââââ´ââââââââââââ´âââââââââââ´âââââââââââ
      pi@mmv2:~/MagicMirror $ pm2 start MagicMirror
      [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
      [PM2] Process successfully started
      â 0  â MagicMirror        â fork     â 2120 â online    â 0%       â 2.6mb    â
        sdetweil @Richard238
        @Richard238 pm2 logs --lines=20
          @sdetweil said in Update, unable to connect.:
          pm2 logs --lines=20
          Seems to loop through this:
          0|MagicMirror  | > magicmirror@2.32.0 start
          0|MagicMirror  | > node --run start:x11
          0|MagicMirror  | [2025-08-16 19:11:31.316] [LOG]   Starting MagicMirror: v2.32.0
          0|MagicMirror  | [2025-08-16 19:11:31.359] [LOG]   Loading config ...
          0|MagicMirror  | [2025-08-16 19:11:31.363] [LOG]   config template file not exists, no envsubst
          0|MagicMirror  | [2025-08-16 19:11:31.976] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
          0|MagicMirror  | [2025-08-16 19:11:32.117] [ERROR] Your configuration file contains syntax errors :(
          0|MagicMirror  | Line 99 column 21: 'Log' is not defined.
          PM2            | App [MagicMirror:0] exited with code [1] via signal [SIGINT]
          PM2            | App [MagicMirror:0] starting in -fork mode-
          PM2            | App [MagicMirror:0] online
          0|MagicMirror  | bash: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8)
          mumblebajM S 2 Replies Last reply Reply Quote 0
          • mumblebajM Offline
            mumblebaj Module Developer @Richard238
            @Richard238 said in Update, unable to connect.:
            0|MagicMirror | Line 99 column 21: ‘Log’ is not defined.
            This seems to indicate that there is an error in config/config.js. Run the following on the command line in the ~/MagicMirror/ directory: npm run config:check
              Richard238 @mumblebaj
              @mumblebaj said in Update, unable to connect.:
              pi@mmv2:~/MagicMirror $ npm run config:check
              > magicmirror@2.32.0 config:check
              > node js/check_config.js
              [2025-08-17 12:14:16.030] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
              [2025-08-17 12:14:16.285] [ERROR] Your configuration file contains syntax errors :(
              Lines 97/98/99:
                              // Override start method.
                              start: function () {
                                  Log.log("Starting module: " + this.name);
                @Richard238 did the
                npm install
                complete?
                do this
                pm2 stop all
                rm -rf node_modules
                npm install
                the start MagicMirror manually
                npm start
                  pi@mmv2:/ $ pm2 stop all
                  [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                  â 0  â MagicMirror        â fork     â 300  â stopped   â 0%       â 0b       â
                  pi@mmv2:/ $ cd ~/MagicMirror
                  pi@mmv2:~/MagicMirror $ rm -rf node_modules
                  pi@mmv2:~/MagicMirror $ npm install
                  npm error code EIO
                  npm error syscall read
                  npm error errno -5
                  npm error EIO: i/o error, read
                  npm error A complete log of this run can be found in: /home/pi/.npm/_logs/2025-08-17T11_35_16_106Z-debug-0.log
                  pi@mmv2:~/MagicMirror $ npm start
                  /bin/sh: 1: ./node_modules/.bin/electron: not found
                    @Richard238 of course you dont need to do npm start if the other stuff fsiled
                    rm package-lock.json
                    rm -rf node_modules
                    npm cache clean --force
                    npm install
                    let me know the results
                      Pi (Pi4 in metal heat-sink case) was running really warm. Powered it off and left it for a while.
                      Powered on, it has no networking and file manager does nothing.
                      If I can get networking enabled, I’ll make a config and CSS backup.
                      Looks like it’s going to need an OS reinstall which will have to wait until I have time to do so.
                      I’ll report back when that’s done.
                        @Richard238 my backup also gets the module source url for every add on module, so that they can be reinstalled again
                        and gets files created (like access tokens etc) which may be needed to make each module work
                          I couldn’t use that as I the Pi had no network, no file manager. It was bricked :(
                          New OS, new default vanilla MM all good.
                          And then I remembered the orig MM was still on a SD Card before I swapped over to a USB drive.
                          Copied all I needed, seems to be all good so far!
                          Thanks for your help. :)
                          S 2 Replies Last reply Reply Quote 1
                            @Richard238 awesome… thanks for the feedback…
                              backup , backup, backup…
                                Hahhahaaaa! Yes, well I do make regular backups of config and CSS, it was the modules folder I was missing. Lesson learned there.
                                  @Richard238 use my script
                                  It will record incremental changes
                                  https://github.com/sdetweil/MagicMirror-backup-restore
