    Update, unable to connect.
    22 Posts 3 Posters 9.9k Views 3 Watching
      Richard238 @sdetweil
      pi@magicmirror:~/MagicMirror $ node -v
      v16.1.0
      R 1 Reply Last reply
        Richard238 @Richard238
        Same issue today. Tried with force but still no MM.
        node -v = v22.14.0
          sdetweil @Richard238
          @Richard238 can you show the startup messages
            pi@mmv2:~/MagicMirror $ node -v
            v22.14.0
            pi@mmv2:~/MagicMirror $ pm2 stop MagicMirror
            [PM2] Applying action stopProcessId on app [MagicMirror](ids: [ 0 ])
            [PM2] [MagicMirror](0) â
            ââââââ¬âââââââââââââââââââââ¬âââââââââââ¬âââââââ¬ââââââââââââ¬âââââââââââ¬âââââââââââ
            â id â name               â mode     â ⺠   â status    â cpu      â memory   â
            ââââââ¼âââââââââââââââââââââ¼âââââââââââ¼âââââââ¼ââââââââââââ¼âââââââââââ¼âââââââââââ¤
            â 0  â MagicMirror        â fork     â 2120 â stopped   â 0%       â 0b       â
            ââââââ´âââââââââââââââââââââ´âââââââââââ´âââââââ´ââââââââââââ´âââââââââââ´âââââââââââ
            pi@mmv2:~/MagicMirror $ pm2 start MagicMirror
            [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
            [PM2] Process successfully started
            â 0  â MagicMirror        â fork     â 2120 â online    â 0%       â 2.6mb    â
              @Richard238 pm2 logs --lines=20
                @sdetweil said in Update, unable to connect.:
                pm2 logs --lines=20
                Seems to loop through this:
                0|MagicMirror  | > magicmirror@2.32.0 start
                0|MagicMirror  | > node --run start:x11
                0|MagicMirror  | [2025-08-16 19:11:31.316] [LOG]   Starting MagicMirror: v2.32.0
                0|MagicMirror  | [2025-08-16 19:11:31.359] [LOG]   Loading config ...
                0|MagicMirror  | [2025-08-16 19:11:31.363] [LOG]   config template file not exists, no envsubst
                0|MagicMirror  | [2025-08-16 19:11:31.976] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
                0|MagicMirror  | [2025-08-16 19:11:32.117] [ERROR] Your configuration file contains syntax errors :(
                0|MagicMirror  | Line 99 column 21: 'Log' is not defined.
                PM2            | App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                PM2            | App [MagicMirror:0] starting in -fork mode-
                PM2            | App [MagicMirror:0] online
                0|MagicMirror  | bash: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8)
                mumblebajM S 2 Replies Last reply
                • mumblebajM
                  mumblebaj Module Developer @Richard238
                  @Richard238 said in Update, unable to connect.:
                  0|MagicMirror | Line 99 column 21: ‘Log’ is not defined.
                  This seems to indicate that there is an error in config/config.js. Run the following on the command line in the ~/MagicMirror/ directory: npm run config:check
                    Richard238 @mumblebaj
                    @mumblebaj said in Update, unable to connect.:
                    pi@mmv2:~/MagicMirror $ npm run config:check
                    > magicmirror@2.32.0 config:check
                    > node js/check_config.js
                    [2025-08-17 12:14:16.030] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
                    [2025-08-17 12:14:16.285] [ERROR] Your configuration file contains syntax errors :(
                    Lines 97/98/99:
                                    // Override start method.
                                    start: function () {
                                        Log.log("Starting module: " + this.name);
                      @Richard238 did the
                      npm install
                      complete?
                      do this
                      pm2 stop all
                      rm -rf node_modules
                      npm install
                      the start MagicMirror manually
                      npm start
                        pi@mmv2:/ $ pm2 stop all
                        [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                        â 0  â MagicMirror        â fork     â 300  â stopped   â 0%       â 0b       â
                        pi@mmv2:/ $ cd ~/MagicMirror
                        pi@mmv2:~/MagicMirror $ rm -rf node_modules
                        pi@mmv2:~/MagicMirror $ npm install
                        npm error code EIO
                        npm error syscall read
                        npm error errno -5
                        npm error EIO: i/o error, read
                        npm error A complete log of this run can be found in: /home/pi/.npm/_logs/2025-08-17T11_35_16_106Z-debug-0.log
                        pi@mmv2:~/MagicMirror $ npm start
                        /bin/sh: 1: ./node_modules/.bin/electron: not found
                          @Richard238 of course you dont need to do npm start if the other stuff fsiled
                          rm package-lock.json
                          rm -rf node_modules
                          npm cache clean --force
                          npm install
                          let me know the results
                            Pi (Pi4 in metal heat-sink case) was running really warm. Powered it off and left it for a while.
                            Powered on, it has no networking and file manager does nothing.
                            If I can get networking enabled, I’ll make a config and CSS backup.
                            Looks like it’s going to need an OS reinstall which will have to wait until I have time to do so.
                            I’ll report back when that’s done.
                              @Richard238 my backup also gets the module source url for every add on module, so that they can be reinstalled again
                              and gets files created (like access tokens etc) which may be needed to make each module work
                                I couldn’t use that as I the Pi had no network, no file manager. It was bricked :(
                                New OS, new default vanilla MM all good.
                                And then I remembered the orig MM was still on a SD Card before I swapped over to a USB drive.
                                Copied all I needed, seems to be all good so far!
                                Thanks for your help. :)
                                  @Richard238 awesome… thanks for the feedback…
                                    backup , backup, backup…
                                      Hahhahaaaa! Yes, well I do make regular backups of config and CSS, it was the modules folder I was missing. Lesson learned there.
                                        @Richard238 use my script
                                        It will record incremental changes
                                        https://github.com/sdetweil/MagicMirror-backup-restore
