    No flights on map.
    7 Posts 2 Posters 4.0k Views 2 Watching
      MikeTheYeti
      Re: MMM-Flights
      I got everything up and running; Map displays correctly, but there are not flights populating. I double checked from flightradar, and they are up there.
      What are some things to check?
      Thanks.
      • karsten13K Offline
        karsten13 @MikeTheYeti
        @MikeTheYeti
        you can look for errors in the logs
        a) server side
        b) in the browser (ctrl+shift+i)
        If you are willing to publish your config of the module I can test with my setup.
          MikeTheYeti @karsten13
          @karsten13
          Thanks for looking into this for me. Here is my config:
          disabled: false,
          module: “MMM-Flights”,
          position: “top_left”,
          laMin: XX.XX,
          laMax: XX.XX,
          loMin: -YY.YY,
          loMax: -YY.YY,
          My map draws correctly, but it just gives me “No flights in chosen area.” Comparison to same area on my flightradar24 app shows flights.
            @MikeTheYeti
            well, the values needed for testing are the area coordinates …
            I understand that you don’t want to publish them, if it is o.k. for you, can you send me a chat message here with the complete config?
              @karsten13 Sorry, I am sometimes wishing to be too anonymous. However, I was double checking my Min and Max values. I initially thought that because my map rendered that I had them correct; I swapped the values, and all is perfect.
              I can now see flight numbers at a glance without having to pull out my phone. So good.
              Thanks so much!
              M 1 Reply Last reply Reply Quote 2
                MikeTheYeti @MikeTheYeti
                Since I have you, and now that I have a look at a populated display. Is there a section in the MMM-Flights.js where I can modify what prints regarding flight info.
                I want to make things with a little more brevity, and maybe save some space. I would like to omit full airport names and full Airline names.
                When a long string of text displays it expands the map onto other stuff on my display.
                Thanks.
                  @MikeTheYeti
                  this is hard coded at the moment, you can change the code here
