    Help to install bluelinky
    8 Posts 3 Posters 837 Views 4 Watching
    • AssassinsA Offline
      Assassins
      The MMM-Bluelinky2 need bluelinky to work, but get this.
      But how can i fix this. ???
      npm install bluelinky
      npm ERR! code EBADENGINE
      npm ERR! engine Unsupported engine
      npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.29.0
      npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.29.0
      npm ERR! notsup Required: {“node”:“>=20.9.0 <21 || 22”}
      npm ERR! notsup Actual: {“npm”:“10.5.0”,“node”:“v21.7.3”}
        sdetweil @Assassins
        @Assassins said in Help to install bluelinky:
        bluelinky wans node up to 20.9 or 22, and NOT ANY 21
        you have node 21… oops…
        so , install node 22
        22.18 is current
        maybe this will help
        https://forum.magicmirror.builders/topic/19770/nodejs-version-update-issue/2?_=1759892047767
        note you have to do another npm install in the MM folder too after you upgrade node
        AssassinsA karsten13K 2 Replies Last reply Reply Quote 0
          Assassins @sdetweil
          @sdetweil okay, how can i update it, so i do it 100% right. ???
          S AssassinsA 2 Replies Last reply Reply Quote 0
            sdetweil @Assassins
            @Assassins see the instructions at the link I provided
            Use 22.18.0 instead of 22.14.0
            AssassinsA 1 Reply Last reply Reply Quote 0
              Assassins @sdetweil
              @sdetweil OKay, thanks, i will try it tomorrow :-)
              • karsten13K Online
                karsten13 @sdetweil
                @sdetweil said in Help to install bluelinky:
                message comes from mm, he is on an outdated version 2.29.0 …
                  Assassins @Assassins
                  @sdetweil Thanks, is work
                  • AssassinsA Assassins has marked this topic as solved on
                    sdetweil @Assassins
                    @Assassins actually this looks like a combination of problems
                    You don’t use npm install to. INSTALL a module
                    You use git clone while the current directory is
                    ~/MagicMirror/modules
                    Then change the current directory to the module folder you just cloned
                    THEN if there is a package.json in THAT folder do npm install there
                    It looks like you were in the MagicMirror folder
