    MMM-Reddit 403 error
    8 Posts 3 Posters 1.4k Views 3 Watching
    • K
      kasperb
      Hello - for some reason my mirror was throwing some errors, so I decided on a fresh install. All is working fine again, but the MMM-Reddit module is now throwing the following errror:
      1|MagicMirror | [2025-10-08 21:10:31.589] [ERROR] Error fetching Reddit data: 403 Blocked
      I did various troubleshooting steps, incl. using the original config with the default module config (see below).
      Any idea what could cause this? My Mirror is up to date, and there are no other errors currently.
                  module: "MMM-Reddit",
                  position: "bottom_left",
                  disabled: false,
                      subreddit: ['television', 'science', 'nottheonion'],
                      headerType: 'chained',
                      displayType: 'image',
                      count: 14,
                      show: 1,
                      width: 400,
                      showAll: true,
                      showScore: false,
                      showSubreddit: true,
                      colorText: false,
                      showThumbnail: false,
        sdetweil @kasperb
        @kasperb looks like Reddit has changed the api
        So I would open an issue on the module GitHub page
        I would also look thru other issues to see if other users encountered this
        • K
          kasperb @sdetweil
          Thanks. Issue created created.
          mumblebajM 2 Replies Last reply Reply Quote 0
          • mumblebajM
            mumblebaj Module Developer @kasperb
            @kasperb Hi. I will have a look this afternoon at the issue you logged. Just logging on to test first. It was working a few days ago.
            • mumblebajM
              @kasperb Just tested and it works fine for me.
              Do you mind sharing your config?
              This is my config:
                          disabled: false,
                              subreddit: ['television', 'science','nottheonion'], //'television', 'science',
                              count: 13,
                              show: 1,
                              width: 500,
                              //showAll: false,
                              showScore: false,
                              colorText: false,
                              showThumbnail: true,
              • K
                kasperb @mumblebaj
                @mumblebaj Thanks - mine is (partially) working now as well. It came back this morning, so it must have been a Reddit API glitch. I’m going to experiment a bit more over the weekend, as it’s not showing all my posts (config says 10, but it fluctuates between 1 and 4…).
                • mumblebajM
                  @kasperb Ok cool. The API changes has not affected the module. Are you showing Headlines or Image?
                  The config has a
                  count = total posts to get
                  show = number posts to show at the same time
                  So, if you have count set to 10 and you have show set to 4 and the total posts it received from the subreddit = 10 then it will show 4 then page the next 4 then the last 2 etc. All depends on how your config is set and how many posts it pulls from all the subreddits you specified.
                    sdetweil @mumblebaj
                    @mumblebaj his config is shown here
                    https://forum.magicmirror.builders/post/128513
