    HDMI turns on without movement
    9 Posts 4 Posters 1.4k Views 4 Watching
    • H Offline
      Hobbes 0
      Hi All,
      I needed to re-setup my MagicMirror, now it runs on Raspi 4 and Debian Trixie 64-bit.
      Everything works nicely as before, PIR is on PIN 22 and I use:
      module: “MMM-Universal-Pir”,
      position: “top_left”,
      gpioCommand: “/usr/bin/gpiomon -e rising -c 0 22”,
      //onCommand: “WAYLAND_DISPLAY=‘wayland-1’ wlr-randr --output HDMI-A-1 --on”,
      //offCommand: “WAYLAND_DISPLAY=‘wayland-1’ wlr-randr --output HDMI-A-1 --off”,
      onCommand: “wlr-randr --output HDMI-A-1 --on”,
      offCommand: “wlr-randr --output HDMI-A-1 --off”,
      deactivateDelay: 20 * 1000,
      As you can see I experimented already with the commands, now it works fine with “wlr-randr --output HDMI-A-1 --on”, and the monitor turns off after 20 seconds if no movement, and turns back on when moving.
      Now comes the trick: when turned off, after ca. 1 minute the monitor goes back on and the MM shows “0 sec”. I.e., the HDMI activation did not come from the MM.
      I tested the offCommand directly in the Terminal, the monitor goes off, and again after a minute or so goes back on. So this does not come from the MM.
      I looked in the settings of the NT68676.2A Controller Board if there is an AutoDetect for HDMI or so, but did not find an entry.
      Any idea what I can do? Thanks for your help!
      Hobbes
      R S 2 Replies Last reply Reply Quote 0
        rkorell Module Developer @Hobbes 0
        @Hobbes-0 I would invest in direction of GPIO…
        As I’ve experienced GPIO in bookworm was strongly different as in earlier version - may this applies to Trixie as well?
        If monitor “awakes” suddenly this seem not to be a problem of HDMI-commands ?
        Sorry cannot advice more concrete - I#m still on bookwork, not Trixie.
        Good luck!
        Ralf
          sdetweil @Hobbes 0
          @karsten13 have you had a chance to test universal pir on Trixie yet?
          • karsten13K Online
            karsten13 @sdetweil
            @sdetweil said in HDMI turns on without movement:
            I’m on it …
            @Hobbes-0 said in HDMI turns on without movement:
            @sdetweil so this problem is not related to universal pir or mm
            I tested universal pir on mmos, which is on trixie but uses the os lite version, mm and labwc/wayland are started as containers.
            I cannot reproduce the unexpected activation there.
            (I found another permission problem which I will fix later) fixed
            Other difference between trixie and bookworm is a breaking version change of gpiomon so you have to use different commands:
            bookworm: gpiomon -r -b gpiochip0 23
            trixie: gpiomon -e rising -c 0 23
            S R 2 Replies Last reply Reply Quote 2
              sdetweil @karsten13
              @karsten13 dang I hate breaking changes for no obvious value
              • H Offline
                Hobbes 0
                Thanks for the analysis so far. Anything I can test?
                  rkorell Module Developer @karsten13
                  You could try Karsten‘s suggestion…
                  Replace your configs gpioCommand with the suggested one and check what happens…
                  As I had assumed in my earlier post it‘s may related more to gpio than to HDMI …
                  Regards,
                  Ralf
                  • H Offline
                    Hobbes 0
                    Hi Ralf and Karsten,
                    Thanks for your support. I tried, but did not work unfortunately. Still the monitor goes on for no reason.
                    So I switched now to X11, and updated the config file, AND finally it works. Here my command:
                                            //onCommand: “wlr-randr --output HDMI-A-1 --on”,
                                            //offCommand: “wlr-randr --output HDMI-A-1 --off”,
                                            //onCommand: “echo on | sudo tee /sys/class/drm/card0-HDMI-A-1/status”,
                                            //offCommand: “echo off | sudo tee /sys/class/drm/card0-HDMI-A-1/status”,
                                            //onCommand: “/usr/local/bin/hdmi-on.sh”,
                                            //offCommand: “/usr/local/bin/hdmi-off.sh”,
                    //X11:
                                            onCommand: “xrandr --output HDMI-1 --mode 1920x1080 --rate 60”,
                                            offCommand: “xrandr --output HDMI-1 --off”,
                                            //onCommand: “xrandr --output HDMI-1 --on”,
                                            //offCommand: “xrandr --output HDMI-1 --off”,
                                            //onCommand: “vcgencmd display_power 1”,
                                            //offCommand: “vcgencmd display_power 0”,
                                            //onCommand: “wlr-randr --output HDMI-1 --on”,
                                            //offCommand: “wlr-randr --output HDMI-1 --off”,
                    deactivateDelay: 40 * 1000,
                    My assumption is that the auto-switch to On of the monitor comes from raspi-connect. With VNC this is not the case. But this is not thoroughly tested, just gut feel.
                    Maybe a last question you might help me with: with the now working offCommand my VNC window on the PC shrinks to tiny. Any suggestion how to avoid?
                    Best,
                    Hobbes aka Dirk
                      @Hobbes-0 Dear Dirk,
                      This is „normal“ behaviour with VNC…
                      Some other PIR modules (especially Bugsounet‘s MMM-Pir) solved this with placing a mouse-sensitive layer on the GUI and mouse click in VNV wakes the screen.
                      AFAIK this is not true for MMM-Universal-Pir.
                      Regards,
                      Ralf
                      • H Hobbes 0 has marked this topic as solved on
