    Looking for a module to display logs in realtime
    14 Posts 3 Posters 1.4k Views 3 Watching
      sdetweil @MyMirror
      @MyMirror I’m not aware of a module that does this
      But it shouldn’t be hard to create
      tail /f /n:xxx filename
      Can get the data
      nodejs exec in the node_helper can launch tail and capture its stdout data
      Then use sendSocketNotification to send the data up to the browser side of the module to display, where the fontsize would be used
      The data will have to get its line ends (cr/lf) replaced by web line ends (
      I think it would be better to put the fontsize in css file to keep all the styling options in one place. Module adds a class name to the div holding the data, and specifies a provided css file that has the class defined with the styles you want
        MyMirror @sdetweil
        Hi Sam,
        I haven’t written a module yet and I’m not very familiar with Linux – and even less so with nodejs, css and all the other stuff.
        Maybe someone out there would like to try their hand at programming such a module.
          schlomm @MyMirror
          @MyMirror I’ll give this a try. Ping me again if you haven’t Heard from me until the end of the week.
          M 2 Replies Last reply Reply Quote 2
            MyMirror @schlomm
            @schlomm - great !
              MyMirror @schlomm
              @schlomm
              the requested ping :-)
                schlomm @MyMirror
                @MyMirror Well done :) I’ve implemented a module last week - to give you a preview:
                With LOG-Level Highlighting:
                Without Highlighting (because INFO, ERROR, WARN…) is not used:
                Right now I’m struggeling with the issue that multiple instances do not show different logs but all the time the second configured. Do you need more than one instance :D?
                If I have some free time, I will upload the first version tomorrow or lately on Wednesday.
                See you :)
                  sdetweil @schlomm
                  @schlomm you have to pass the instance id from the web as part of the request and send it back w the data. And the web side checks to match its id
                  sendSocketNotification from the helper is to ALL connected instances at once
                    schlomm
                    @MyMirror Nevermind - I’ve made some changes and now all is working properly :) Your’re welcome to test it. If there is anything missing or an issue, please drop me a line.
                    • You can find the module here: https://github.com/schlomm/MMM-LogfileViewer
                    • I’ve also made a small post in the ShowCase section here: https://forum.magicmirror.builders/topic/19937/mmmlogfileviewer-view-your-logs-on-your-magicmirror
                    • And I’ve already updated the 3rd Party Module list - the module will be listed here a tomorrow.
                      MyMirror @schlomm
                      @schlomm
                      That looks really good !!
                      I’ll install it tonight and test it out.
                      Thank you very much for your help!
                        schlomm @MyMirror
                        @MyMirror Your’re welcome. If there any question left, feel free to give me a hint.
                        Gutes Gelingen und schöne Grüße :)
