    Best Bathroom Mirror with Built-in Lighting | Expert Recommendation to Choose
    3 Posts 3 Posters 2.6k Views 3 Watching
      jonson
      I researched about the best Bathroom Mirrors with built-in lighting for the past few days because I’m planning to upgrade my bathroom setup and want something that’s modern, durable, and possibly compatible with smart or DIY lighting features. I read reviews on The New York Times (Wirecutter), The Spruce, and Popular Mechanics, and they’re marking these two as some of the best options:
      USHOWER 2-Pack Black Bathroom Mirrors
      [https://www.amazon.com/USHOWER-Mirror-Bathroom-Rectangle-Mounted/dp/B0B3XPZX8B]
      LOAAO 40X32 LED Bathroom Mirror with Lights
      https://www.amazon.com/LOAAO-Bathroom-Anti-Fog-Dimmable-Waterproof/dp/B09TP75Y82
      However, I’m having trouble deciding which one would best suit my needs and would appreciate some expert advice. I’d prefer something that’s bright, anti-fog, and easy to integrate with a smart switch or LED controller if possible.
      Has anyone here tried building or modifying one of these mirrors for smart home integration or MagicMirror setups?
      Would love to hear your experiences, wiring tips, or hardware suggestions before I decide.
      Thanks in advance!
      S E 2 Replies Last reply Reply Quote 0
        sdetweil @jonson
        @jonson if you are going to smart mirror/magicmirror you need a 2 way mirror, and these are generally not finished.
        see https://twowaymirrors.com for a clearer view of the glass needed …
        a regular mirror will not work as the coating on the back is opaque, non-see thru
        • E Offline
          esmail11 @jonson
          Hey @jonson — great question!
          If you’re thinking of building your own smart mirror setup, you can actually make it look a lot cleaner and more “custom” by framing it with cut-to-size MDF panels or lightweight boards. That gives you a sleek finish and lets you easily mount LED strips or smart controllers behind the frame.
          For example, at MDF Direct, you can get MDF boards cut to your exact measurements — ideal for mirror frames, wall panels, or even bathroom cabinetry. If you want a moisture-resistant option, their moisture-resistant MDF is a solid choice for bathroom environments.
          Pairing that with a two-way mirror (as @sdetweil mentioned) and a smart LED controller gives you the perfect mix of tech and design.
          Hope that helps, and good luck with your smart mirror build!
