    installing MagicMirror on my Raspberry Pi 0 w2
    14 Posts 5 Posters 1.2k Views 5 Watching
    • Y Offline
      Y_Garden @sdetweil
      The log was deleted during the SD card formatting process. When I tried again with a clean Raspberry Pi, it wouldn’t reboot and displayed the error “Could not install dependencies!” I’ll send you the log.
      git is already the newest version (1:2.47.3-0+deb13u1).
      build-essential is already the newest version (12.12).
      unzip is already the newest version (6.0-29).
      this should be a raspberry pi 02w
      swap control file /etc/dphys-swapfile doesn’t exist
      installed node version is v22.18.0
      installing on trixie
      installed node version = v22.18.0
      ^[[0mNo npm engines section specified in package.json, using default=V10.9.3 …^[[0m
      ^[[96mCheck current Node installation …^[[0m
      ^[[0mNode currently installed. Checking version number.
      ^[[0mMinimum Node version: ^[[1mv22.18.0^[[0m
      ^[[0mInstalled Node version: ^[[1mv22.18.0^[[0m
      ^[[92mNo Node.js upgrade necessary.^[[0m
      ^[[96mCheck current NPM installation …^[[0m
      ^[[0mNPM currently installed. Checking version number.
      ^[[0mMinimum npm version: ^[[1mV10.9.3^[[0m
      ^[[0mInstalled npm version: ^[[1mV10.9.3^[[0m
      ^[[92mNo npm upgrade necessary.^[[0m
      ^[[96mCloning MagicMirror …^[[0m
      ^[[92mCloning MagicMirror Done!^[[0m
      ^[[96mInstalling dependencies …^[[0m
      ^[[91mUnable to install dependencies! ^[[0m
      • Y Offline
        Y_Garden @sdetweil
        yes
        $cat /proc/device-tree/model
        Raspberry Pi Zero 2 W Rev 1.0
        $uname -a
        Linux raspberrypi 6.12.47+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1 (2025-09-16) aarch64 GNU/Linux
        $cat /etc/issue
        Debian GNU/Linux 13 \n \l
        $cat /etc/release
        PRETTY_NAME=“Debian GNU/Linux 13 (trixie)”
        NAME=“Debian GNU/Linux”
        VERSION_ID=“13”
        VERSION=“13 (trixie)”
        VERSION_CODENAME=trixie
        DEBIAN_VERSION_FULL=13.2
        ID=debian
        HOME_URL=“https://www.debian.org/”
        SUPPORT_URL=“https://www.debian.org/support”
        BUG_REPORT_URL=“https://bugs.debian.org/”
        $getconf LONG_BIT
        64
          sdetweil @Y_Garden
          @Y_Garden interesting. I thought I pushed a fix for this a couple weeks ago
          • Y Offline
            Y_Garden @sdetweil
            When I deleted the duplicated MagicMirror and ran the script again, the Raspberry Pi rebooted.
            install starting - Thu Nov 20 05:12:44 GMT 2025
            installing on aarch64 processor system
            the os is PRETTY_NAME=“Debian GNU/Linux 13 (trixie)” NAME=“Debian GNU/Linux” VERSION_ID=“13” VERSION=“13 (trixie)” VERS>
            total used free shared buff/cache available
            Mem: 416 204 101 3 166 211
            Swap: 16799 129 16670
            ^[[96mUpdating packages …^[[0m
            Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://deb.debian.org/debian trixie-updates InRelease Hit:3 h>
            apt-get update completed ok
            Reading package lists…
            Building dependency tree…
            Reading state information…
            pv is already the newest version (1.9.31-1).
            apt-get upgrade started
            Calculating upgrade…
            apt-get upgrade result =rc=0 Reading package lists…
            ^[[96mInstalling helper tools …^[[0m
            curl is already the newest version (8.14.1-2+deb13u2).
            wget is already the newest version (1.25.0-2).
            Ah… if you solved it a few weeks ago, I’ll take a look at what other people have posted about the same problem.
              sdetweil @Y_Garden
              @Y_Garden I solved the installing correct version of node problem.
              The reboot is happening inside npm, none of our code
              Maybe a heat or power problem?
              2w is short on ram, and trixie is bigger
              • emloweE Offline
                emlowe Module Developer
                My experience trying to run MM on a system with 512MB of RAM is really poor. I found it pretty frustrating really.
                  sdetweil @emlowe
                  @emlowe yes, and the later os images are getting bigger and bigger
                  emloweE 1 Reply Last reply Reply Quote 0
                  • emloweE Offline
                    emlowe Module Developer @sdetweil
                    @sdetweil I did find dietPi (https://dietpi.com/) to be the best distro for ease of installation, generally small, and still up to date - they keep up to date with Debian
                    Y 1 Reply Last reply Reply Quote 1
                      RonR
                      I’m not sure you will be able to do that easily. I’m trying to get a browser to load on a PI zero 2 W because Firefox and Chrome take up too much room to fit in the tiny 512MB Ram. Even running ssh and not using the GUI it is taking close to an hour to install Midori but that may be their server because other things have worked much faster.
                      Good Luck with your project.
                      • Y Offline
                        Y_Garden @emlowe
                        @emlowe
                        Ah… 2W is the worst… I’ll try again with dietpi and use this 2W for something else. I’ll try connecting it to a better Raspberry Pi. Thank you.
