    installing MagicMirror on my Raspberry Pi 0 w2
    14 Posts 5 Posters 3.1k Views 5 Watching
      sdetweil @Y_Garden
      @Y_Garden interesting. I thought I pushed a fix for this a couple weeks ago
      Y 1 Reply Last reply
      • Y
        Y_Garden @sdetweil
        When I deleted the duplicated MagicMirror and ran the script again, the Raspberry Pi rebooted.
        install starting - Thu Nov 20 05:12:44 GMT 2025
        installing on aarch64 processor system
        the os is PRETTY_NAME=“Debian GNU/Linux 13 (trixie)” NAME=“Debian GNU/Linux” VERSION_ID=“13” VERSION=“13 (trixie)” VERS>
        total used free shared buff/cache available
        Mem: 416 204 101 3 166 211
        Swap: 16799 129 16670
        ^[[96mUpdating packages …^[[0m
        Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://deb.debian.org/debian trixie-updates InRelease Hit:3 h>
        apt-get update completed ok
        Reading package lists…
        Building dependency tree…
        Reading state information…
        pv is already the newest version (1.9.31-1).
        apt-get upgrade started
        Calculating upgrade…
        apt-get upgrade result =rc=0 Reading package lists…
        ^[[96mInstalling helper tools …^[[0m
        curl is already the newest version (8.14.1-2+deb13u2).
        wget is already the newest version (1.25.0-2).
        git is already the newest version (1:2.47.3-0+deb13u1).
        build-essential is already the newest version (12.12).
        unzip is already the newest version (6.0-29).
        this should be a raspberry pi 02w
        installed node version is v22.18.0
        installing on trixie
        installed node version = v22.18.0
        ^[[0mNo npm engines section specified in package.json, using default=V10.9.3 …^[[0m
        ^[[96mCheck current Node installation …^[[0m
        ^[[0mNode currently installed. Checking version number.
        ^[[0mMinimum Node version: ^[[1mv22.18.0^[[0m
        ^[[0mInstalled Node version: ^[[1mv22.18.0^[[0m
        ^[[92mNo Node.js upgrade necessary.^[[0m
        ^[[96mCheck current NPM installation …^[[0m
        ^[[0mNPM currently installed. Checking version number.
        ^[[0mMinimum npm version: ^[[1mV10.9.3^[[0m
        ^[[0mInstalled npm version: ^[[1mV10.9.3^[[0m
        ^[[92mNo npm upgrade necessary.^[[0m
        ^[[96mCloning MagicMirror …^[[0m
        ^[[92mCloning MagicMirror Done!^[[0m
        ^[[96mInstalling dependencies …^[[0m
        Ah… if you solved it a few weeks ago, I’ll take a look at what other people have posted about the same problem.
          sdetweil @Y_Garden
          @Y_Garden I solved the installing correct version of node problem.
          The reboot is happening inside npm, none of our code
          Maybe a heat or power problem?
          2w is short on ram, and trixie is bigger
          • emloweE
            emlowe Module Developer
            My experience trying to run MM on a system with 512MB of RAM is really poor. I found it pretty frustrating really.
              sdetweil @emlowe
              @emlowe yes, and the later os images are getting bigger and bigger
              emloweE 1 Reply Last reply
              • emloweE
                emlowe Module Developer @sdetweil
                @sdetweil I did find dietPi (https://dietpi.com/) to be the best distro for ease of installation, generally small, and still up to date - they keep up to date with Debian
                  RonR
                  I’m not sure you will be able to do that easily. I’m trying to get a browser to load on a PI zero 2 W because Firefox and Chrome take up too much room to fit in the tiny 512MB Ram. Even running ssh and not using the GUI it is taking close to an hour to install Midori but that may be their server because other things have worked much faster.
                  Good Luck with your project.
                  • Y
                    Y_Garden @emlowe
                    @emlowe
                    Ah… 2W is the worst… I’ll try again with dietpi and use this 2W for something else. I’ll try connecting it to a better Raspberry Pi. Thank you.
                    • Y
                      Y_Garden @RonR
                      @RonR
                      Thank you.
                      I will upgrade my Raspberry Pi model to a wallet.
                      plainbrokeP 1 Reply Last reply
                      • plainbrokeP
                        plainbroke @Y_Garden
                        @Y_Garden
                        That pi zero will run Pi-Hole pretty well on diet pi 32 bit…
