    MMM-BackgroundSlideShow cutting off top of pics
    12 Posts 3 Posters 879 Views 4 Watching
    • msimon360M Offline
      msimon360 @RonR
      @RonR I have the same issue. How do you “pull the window in from the side”? Can you post the module section from config.js, please?
        msimon360 @sdetweil
        @sdetweil I tried to use MMM-ImagesPhotos but could not get it to work with MMM-Carousel so I am trying MMM-BackgroundSlideShow instead.
          sdetweil @msimon360
          @msimon360 what do you mean could not get it to work?
          can you show the config for both modules?
          I use pages, and images position:fullscreen_below
          msimon360M 1 Reply Last reply Reply Quote 0
            msimon360 @sdetweil
            @sdetweil Thanks for the quick reply.
            Here are the ImagesPhotos and Carousel sections of my config.js. Running this I just get a blank screen instead of the photos. I do get photos if I use top_center without Carousel.
                module: "MMM-ImagesPhotos",
                position: "fullscreen_below",
                 opacity: 0.9,
                 animationSpeed: 5000,
                 updateInterval: 15000,
                 backgroundColor: 'grey',  // not used if fill is true
                 fill: true,   // fill around image with blurred copy of image
            	   blur: 10,   // only used if fill is true
                 sequential: false  // process the image list randomly
                module: "MMM-Carousel",
                  transitionInterval: 10000,
                  showPageIndicators: true,
                  showPageControls: false,
                  ignoreModules: ["alert", "updatenotification"],
                  mode: "slides",
                  slides: [
                    ["clock", "weather", "calendar"],
                    ["MMM-ImagesPhotos"]
              sdetweil @msimon360
              @msimon360 and how is the configured in carousel?
                RonR @msimon360
                @msimon360 To pull the window in from the sides I grabbed the right edge of the window and dragged it to the left. The pictures started to change from the wide format to their original dimensions. I was setting it up to run all day with family on Thanksgiving and that was not a viable solution for each frame.
                So I changed to MMM-ImagesPhotos. Had a problem with it to start with where it did not display anything. I am running it is ‘fullscreen-under’ it presents smaller format pictures in their actual size instead of enlarging them to full screen and cutting off heads. The problem with no pictures was when I set the path to the ‘uploads’ directory in config.js the system concatenated the string three times and could not find the path, I wonder why? :) I found that problem by going back into the logs to find the error in the module setup. I went back into config.js and deleted my entry for the path and left it with an empty string “”. Then all my pictures popped up like they were supposed to.
                Yes, Sam, I had to manually go into the config.js because MMM-Config/configure would not reset it when I cleared the entry on the form.
                I am really happy with MMM-ImagesPhotos. I was going to suggest putting an option to display the file name on the picture but I got around it by annotating the pics with names for family that has not met those in the pics. It worked much better than depending on the file name.
                  msimon360 @sdetweil
                  @sdetweil I didn’t get that by pages you ment the module pages in place of Carousel. I tried your pages module and it is displaying only the first photo. Here is my new config.js section.
                  module: “MMM-ImagesPhotos”,
                  position: “fullscreen_below”,
                  opacity: 0.9,
                  backgroundColor: ‘grey’, // not used if fill is true
                  module: “MMM-pages”,
                  rotationTime: 1000 * 10, // rotate every 20 seconds
                  [“clock”], // page 1
                  [“MMM-ImagesPhotos”], // page 2
                  fixed: [ // modules that are always shown
                  “MMM-page-indicator”
                  hiddenPages: { // modules that are only shown on specific pages
                  “screenSaver”: [
                  “clock”,
                  “MMM-SomeBackgroundImageModule”
                  “admin”: [
                  “MMM-ShowMeSystemStatsModule”,
                  “MMM-AnOnScreenMenuModule”
                    sdetweil @RonR
                    @RonR said in MMM-BackgroundSlideShow cutting off top of pics:
                    ‘fullscreen-under’
                    fullscreen_below
                    if it was under, then MM should have put out a message with ‘unknown position’ in the startup messages and that module will not be loaded
                      sdetweil @RonR
                      MMM-ImagesPhotos
                      doesn’t have a path property it is hard coded to ‘uploads’
