    DHT22 with Debian 12 Bookworm
    11 Posts 4 Posters 1.0k Views 4 Watching
      RonR
      There are at least four modules on the list dealing with the DHT-22. J0n4e
      MMM-DHT22, ckoutavas MMM-DHT, cslev MMM-loldht22. Just do a search for dht and they will pop up.
      Good luck
        com1cedric @RonR
        @RonR thanks!
        • wishmaster270W Offline
          wishmaster270 Module Developer @com1cedric
          @com1cedric
          Hi. No problem. If I have time it try to help.
          It looks like there will installed two additional python libs in the venv in the tutorial you shared.
          Maybe one of the libs is missing in the virtual environment my script creates.
          You can add them to the venv with:
          cd ~/MagicMirror/modules/MMM-Temperature/scripts
          ./venvWrapper.py --venv-name py-venv --install-libs lgpio RPi.GPIO
            wishmaster270 Module Developer @wishmaster270
            If you change line 25 in my dht11 script from except: to finally: you should see the whole error.
            But make sure to revert the change after the problem is fixed.
            C S 2 Replies Last reply Reply Quote 0
              com1cedric @wishmaster270
              @wishmaster270 thanks, I will try this week-end and inform you. Could interest the other users.
                sdetweil @wishmaster270
                @wishmaster270 I think the gpio setup changed in bookworm
                  com1cedric @sdetweil
                  @sdetweil and @wishmaster270 : Thank you for your inputs.
                  I finally tried this one https://github.com/ryck/MMM-DHT-Sensor, not listed on https://modules.magicmirror.builders/, but it works.
