    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
    • T Offline
      thegooroo @sdetweil
      @sdetweil Awesome! Many thanks!
        almightyyoshi
        Is there a way to remove the space where a symbol would be only for calendars not using a symbol?
          sdetweil @almightyyoshi
          @almightyyoshi yes
          add
          classes:"........ some_arbitrary_string "
          //like this
          classes:"foo",
          after the module: line
          to the instance you dont want the symbols to show
          then use
          .arbitrary_string .symbol {
               display:none;
          /*like this */
          .foo .symbol {
               display:none;
            I think you can add the caledar_name selector too
            from the ext3 doc
            .event` : Every event has this selector. Each event could have these class names together by its condition.
              - `.continueFromPreviousWeek`, `.continueToNextWeek`
              - `.calendar_{calendarName}`    <-------
              S374n
              Is it possible to scroll this calendar with a button on GPIO, next month or prev month? Where can i find more details on this please, found some ideas but not this specific calendar.
              Thank you.
                sdetweil @S374n
                @S374n you can use mmm-pages, create three pages
                Three instances of ext3. One on each page,
                mode:“month”
                monthIndex: 0/1/2. For this month, next month and month after that (-1 for month before current)
                Mmm-page-indicator creates buttons you can customize look w css, and will let you Move between pages on demand , pages also rotates
                  S374n @sdetweil
                  @sdetweil Thank you for the idea. I’ll look into it.
                    bicolorbore586 @MMRIZE
                    My MagicMirror has been out of action for a few months now, mainly due to a kitchen renovation, but am looking at getting it back up and running.
                    I’d previously had MMM-CalendarExt3 working with a few different calendars, notably a birthday calendar, where it would show an icon in the cell header.
                    However since updating the MagicMirror software it no longer seems possible to do. Below is the module extract from config.js, and is what has been previously used. Now upon starting MM with this in place I’m told [ERROR] Your configuration file contains syntax errors :( ‘document’ is not defined.
                    Anyone able to assist with what the issue is and how to resolve it?
                    		module: "MMM-CalendarExt3", //https://github.com/MMRIZE/MMM-CalendarExt3
                    		position: "lower_third",
                    		//header: "FamCal",
                    			mode: "month",
                    			useWeather: false,
                    			weekIndex: 0,
                    			weeksInView: 5,
                    			instanceId: "basicCalendar",
                    			locale: "en-GB",
                    			maxEventLines: 6,
                    			firstDayOfWeek: 1,
                    			headerWeekDayOptions: {weekday: "short"},
                    			refreshInterval: 60 * 10 * 1000, // 3600000, // every hour // 60 * 10 * 1000, // too frequent refresh. 10 minutes is enough.
                    			calendarSet: ["Family Calendar", "UK Holidays", "Birthday",],
                    			manipulateDateCell: (cellDom, events) => {
                    				if (Array.isArray(events) && events.some(e => e.calendarName === 'Birthday')) {
                    					let dateIcon = document.createElement ('span')
                    					dateIcon.classList.add ('fa', 'fa-fas', 'fa-fw', 'fa-gift')
                    					dateIcon.style.color = 'cornflowerblue'
                    					let header = cellDom.querySelector ('.cellHeader')
                    					let celldate = header.querySelector ('.cellDate')
                    					header.insertBefore (dateIcon, celldate)
                    			eventTransformer: (ev) => 	{
                    				if (ev.calendarName === 'Birthday') ev.skip = true
                    				else if (ev.title.search("B -") > -1) ev.color = "brown"
                    				else if (ev.title.search("C -") > -1) ev.color = "hotpink"
                    				else if (ev.title.search("E -") > -1) ev.color = "orange"
                    				else if (ev.title.search("I -") > -1) ev.color = "green"
                    				else if (ev.title.search("G") > -1) ev.color = "white"
                    				else if (ev.title.search("Bday") > -1) ev.title = ""
                    				return ev
                    			eventPayload: (payload) => {
                    				for (let ev of payload) {
                    					if (ev.fullDayEvent) {
                    						let gap = +ev.endDate - +ev.startDate
                    						if (gap % (1000 * 60 * 60 * 24) === 0) {
                    							ev.startDate = new Date(+ev.startDate).setHours(0, 0, 0, 0)
                    							ev.endDate = new Date(+ev.startDate + gap).setMilliseconds(-1)
                    				return payload
                      sdetweil @bicolorbore586
                      @bicolorbore586 can you do
                      npm run config:check
                      does it produce the same error?
                      also do
                      node -c config/config.js
                      if it returns and displays nothing, then node did not detect any syntax errors.
                      edit: I can reproduce this
                        @bicolorbore586 add this to the top of config.js, very first line
                        var document;
                        I’ll open a bug report
                        I opened https://github.com/MagicMirrorOrg/MagicMirror/issues/3990
                          bicolorbore586 @sdetweil
                          @sdetweil config:check returns the same error
                          The node one doesn’t produce anything
                          Adding var document; to the config.js gives parsing error unexpected keyword ‘var’
                            @bicolorbore586 very first line
                            Right?
                              @sdetweil it wasn’t. Does it need to be before let config = { or the fist line after that?
                                @bicolorbore586 very first line of the file, all by itself
                                Before any comments
                                  @sdetweil that appears to have worked. Out of interest. What does that do?
                                    @bicolorbore586 the module code you have used the global variable document to examine the web page contents
                                    The syntax checker found the use, but didn’t know that this code (config.js is a JavaScript file) was loaded in a browser
                                    So it reported use of an undeclared variable
                                    The fix was to declare the variable as a global so the checker will be happy
                                      @bicolorbore586 there is a fix for this in the next release.
                                      • 31
                                      • 32
                                      • 33
                                      • 34
                                      • 35
                                      • 35 / 35
