    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 404.9k Views 23 Watching
    • zman3Z
      zman3
      what do i have to type into the console to install this?
      J 1 Reply Last reply
        joanaz @zman3
        @zman3 it’s a MagicMirror Module, so same way to install it like any other modules. But you also need to set up Alexa, AWS IoT service, and my Alexa skill that complements it.
        • in_a_daysI
          in_a_days
          I’m very excited to test this over the weekend. I presently have AlexaPi and MM running concurrently. I’ve struggled to get MMM-AlexaPi to communicate with AlexaPi, but wow this looks a lot more expansive. I’m new to AWS IoT, but your instructions are easy to follow. Great work!
            joanaz @in_a_days
            @in_a_days Thank you!
            • zman3Z
              zman3
              do you know if it will work with this ? https://github.com/alexa/alexa-avs-sample-app
              thanks
                joanaz @zman3
                @zman3 yeah it does, it also works with https://echosim.io/welcome?next=%2F
                zman3Z 1 Reply Last reply
                • zman3Z
                  zman3 @joanaz
                  @joanaz cool so I know nothing about this stuff when I’m getting the aws-iot-device-sdk do I want the java version or javascript?
                    joanaz @zman3
                    @zman3 you just need to do “npm install”, then the package.json will install the sdk (assuming you have npm installed on ur computer). It’s the JavaScript version.
                    • schlachtkreuzer6S
                      schlachtkreuzer6
                      will it work with a echo dot? sending comands to the mirror?
                      • lucallmonL
                        lucallmon
                        @joanaz Do you have a video demo of this running? This may be pretty close to what I’m looking for on my MM.
                        Here is my module request page: https://forum.magicmirror.builders/topic/1577/alexa-responses-displayed-on-mirror/6
                        Do you have to say “Mirror, mirror, on the wall” to activate it? Does it display the words that it says on the screen along with any pictures as if you were using an Amazon Fire TV stick?
                          joanaz @schlachtkreuzer6
                          @schlachtkreuzer6 yes, but you need to install my Alexa skill
                            joanaz @lucallmon
                            @lucallmon I changed my Alexa wake word to “Mirror mirror” instead of “Alexa”, and my Skill’s invocation name is “on the wall”, but you can change them to whatever you want. It displays the text you say after the command word “say”. Look at my sample utterances for the commands you can use. It doesn’t show text for other Alexa skills or Alexa general commands. But you can change my Alexa skill to do that.
                            • zman3Z
                              zman3
                              welll I just cannot seem to get this to work she always says she doesnt understand I think it tried just once because she said there was a error with the skill that one time. :/
                              any ideas of what i can look for?
                              • zman3Z
                                zman3
                                well i guess one thing i didnt do is in your directions it says
                                open MirrorMirror.js, replace the keyPath, certPath, and host to your own
                                where am I getting the host information from?
                                lucallmonL J 2 Replies Last reply
                                • lucallmonL
                                  lucallmon @zman3
                                  @zman3 from the Lambda site maybe?
                                    joanaz @zman3
                                    @zman3 From AWS IoT, the instructions are in the readme in my repo. You also need to install my Alexa skill, by following the instructions in that repo.
                                    • zman3Z
                                      zman3
                                      I have those installed still not seeing where i would get a host to put in there .
                                      if I say alexa, on the wall. she says theres a problem with the requested skills respones the lambda cloud watch error shows the following
                                      17:21:45
                                      START RequestId: 931bbc00-e710-11e6-b7a7-b3bf469e814d Version: $LATEST
                                      17:21:45
                                      Unable to import module 'index': Error at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object. (/var/task/MirrorMirror.js:1:76) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.
                                      17:21:45
                                      END RequestId: 931bbc00-e710-11e6-b7a7-b3bf469e814d
                                      17:21:45
                                      REPORT RequestId: 931bbc00-e710-11e6-b7a7-b3bf469e814d Duration: 36.31 ms Billed Duration: 100 ms Memory Size: 128 MB Max Memory Used: 17 MB
                                      17:21:45
                                      START RequestId: 9342f35b-e710-11e6-872c-f9454aa4f261 Version: $LATEST
                                      17:21:45
                                      Unable to import module 'index': Error at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object. (/var/task/MirrorMirror.js:1:76) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.load (module.js:343:32) at Function.Module._load (modul
                                      17:21:45
                                      END RequestId: 9342f35b-e710-11e6-872c-f9454aa4f261
                                      17:21:45
                                      REPORT RequestId: 9342f35b-e710-11e6-872c-f9454aa4f261 Duration: 0.61 ms Billed Duration: 100 ms Memory Size: 128 MB Max Memory Used: 17 MB
                                      • zman3Z
                                        zman3
                                        so another thing in your skill code theres
                                        var MirrorMirror = require(‘./MirrorMirror’); does that expect the MMM-MirrorMirrorOnTheWall module folder to be called MirrorMirror because mines call MMM-MirrorMirrorOnTheWall
                                          joanaz
                                            Journeytojah
                                            I can’t get the module to work, I get this error:
                                            { Error: getaddrinfo ENOTFOUND data.iot.us-east-1.amazonaws.com data.iot.us-east-1.amazonaws.com:8883
                                                at errnoException (dns.js:28:10)
                                                at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:76:26)
                                              code: 'ENOTFOUND',
                                              errno: 'ENOTFOUND',
                                              syscall: 'getaddrinfo',
                                              hostname: 'data.iot.us-east-1.amazonaws.com',
                                              host: 'data.iot.us-east-1.amazonaws.com',
                                              port: 8883 }
                                            • 10
                                            • 1 / 10
