    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 393.3k Views 23 Watching
      joanaz
      Should be if you could get AlexaPi and my Alexa skill to work.
        Mar @joanaz
        @joanaz Yeah i suppose i should actually have asked if Alexa pi would run well on a zero? Im assuming it would…its not really doing any processing, just sending stuff to amazon.
        • Z Offline
          zman3
          what do i have to type into the console to install this?
            joanaz @zman3
            @zman3 it’s a MagicMirror Module, so same way to install it like any other modules. But you also need to set up Alexa, AWS IoT service, and my Alexa skill that complements it.
            • I Offline
              in_a_days
              I’m very excited to test this over the weekend. I presently have AlexaPi and MM running concurrently. I’ve struggled to get MMM-AlexaPi to communicate with AlexaPi, but wow this looks a lot more expansive. I’m new to AWS IoT, but your instructions are easy to follow. Great work!
                joanaz @in_a_days
                @in_a_days Thank you!
                • Z Offline
                  zman3
                  do you know if it will work with this ? https://github.com/alexa/alexa-avs-sample-app
                  thanks
                    joanaz @zman3
                    @zman3 yeah it does, it also works with https://echosim.io/welcome?next=%2F
                    Z 1 Reply Last reply Reply Quote 0
                    • Z Offline
                      zman3 @joanaz
                      @joanaz cool so I know nothing about this stuff when I’m getting the aws-iot-device-sdk do I want the java version or javascript?
                        joanaz @zman3
                        @zman3 you just need to do “npm install”, then the package.json will install the sdk (assuming you have npm installed on ur computer). It’s the JavaScript version.
                          schlachtkreuzer6
                          will it work with a echo dot? sending comands to the mirror?
                          • L Offline
                            lucallmon
                            @joanaz Do you have a video demo of this running? This may be pretty close to what I’m looking for on my MM.
                            Here is my module request page: https://forum.magicmirror.builders/topic/1577/alexa-responses-displayed-on-mirror/6
                            Do you have to say “Mirror, mirror, on the wall” to activate it? Does it display the words that it says on the screen along with any pictures as if you were using an Amazon Fire TV stick?
                              joanaz @schlachtkreuzer6
                              @schlachtkreuzer6 yes, but you need to install my Alexa skill
                                joanaz @lucallmon
                                @lucallmon I changed my Alexa wake word to “Mirror mirror” instead of “Alexa”, and my Skill’s invocation name is “on the wall”, but you can change them to whatever you want. It displays the text you say after the command word “say”. Look at my sample utterances for the commands you can use. It doesn’t show text for other Alexa skills or Alexa general commands. But you can change my Alexa skill to do that.
                                • Z Offline
                                  zman3
                                  welll I just cannot seem to get this to work she always says she doesnt understand I think it tried just once because she said there was a error with the skill that one time. :/
                                  any ideas of what i can look for?
                                  • Z Offline
                                    zman3
                                    well i guess one thing i didnt do is in your directions it says
                                    open MirrorMirror.js, replace the keyPath, certPath, and host to your own
                                    where am I getting the host information from?
                                    L J 2 Replies Last reply Reply Quote 0
                                    • L Offline
                                      lucallmon @zman3
                                      @zman3 from the Lambda site maybe?
                                        joanaz @zman3
                                        @zman3 From AWS IoT, the instructions are in the readme in my repo. You also need to install my Alexa skill, by following the instructions in that repo.
                                        • Z Offline
                                          zman3
                                          I have those installed still not seeing where i would get a host to put in there .
                                          if I say alexa, on the wall. she says theres a problem with the requested skills respones the lambda cloud watch error shows the following
                                          17:21:45
                                          START RequestId: 931bbc00-e710-11e6-b7a7-b3bf469e814d Version: $LATEST
                                          17:21:45
                                          Unable to import module 'index': Error at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object. (/var/task/MirrorMirror.js:1:76) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.
                                          17:21:45
                                          END RequestId: 931bbc00-e710-11e6-b7a7-b3bf469e814d
                                          17:21:45
                                          REPORT RequestId: 931bbc00-e710-11e6-b7a7-b3bf469e814d Duration: 36.31 ms Billed Duration: 100 ms Memory Size: 128 MB Max Memory Used: 17 MB
                                          17:21:45
                                          START RequestId: 9342f35b-e710-11e6-872c-f9454aa4f261 Version: $LATEST
                                          17:21:45
                                          Unable to import module 'index': Error at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object. (/var/task/MirrorMirror.js:1:76) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.load (module.js:343:32) at Function.Module._load (modul
                                          17:21:45
                                          END RequestId: 9342f35b-e710-11e6-872c-f9454aa4f261
                                          17:21:45
                                          REPORT RequestId: 9342f35b-e710-11e6-872c-f9454aa4f261 Duration: 0.61 ms Billed Duration: 100 ms Memory Size: 128 MB Max Memory Used: 17 MB
                                          • Z Offline
                                            zman3
                                            so another thing in your skill code theres
                                            var MirrorMirror = require(‘./MirrorMirror’); does that expect the MMM-MirrorMirrorOnTheWall module folder to be called MirrorMirror because mines call MMM-MirrorMirrorOnTheWall
                                            • 10
                                            • 1 / 10
