    Magic Mirror Scripts - "Unable to determine upstream"
    13 Posts 2 Posters 629 Views 2 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      bkey1970@mirrorserv:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
      update log will be in /home/bkey1970/MagicMirror/installers/upgrade.log
      doing test run = false
      Minimum Node version: v22.21.1
      Installed Node version: v22.18.0
      installing correct version of node and npm, please wait
      Installed Node version: v22.21.1
      No Node.js upgrade necessary.
      Minimum npm version: V10.9.4
      Installed npm version: V10.9.4
      No npm upgrade necessary.
      want /var/swap=512MByte, checking existing: keeping it
      saving custom.css
      Unable to determine upstream git repository
      Upgrade started - Fri Jan  2 13:41:18 PST 2026
      system is Linux mirrorserv 6.12.47+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1~bookworm (2025-09-16) aarch64 GNU/Linux
      user requested to apply changes
      the os is PRETTY_NAME="Debian GNU/Linux 12 (bookworm)" NAME="Debian GNU/Linux" VERSION_ID="12" VERSION="12 (bookworm)" VERSION_CODENAME=bookworm ID=deb>
      architecture from dpkg is
      ^[[0mNode currently installed. Checking version number.^[[0m
      ^[[0mMinimum Node version: ^[[1mv22.21.1^[[0m
      ^[[0mInstalled Node version: ^[[1mv22.18.0^[[0m
      ^[[96minstalling correct version of node and npm, please wait^[[0m
        installing : node-v22.21.1
             mkdir : /usr/local/n/versions/node/22.21.1
             fetch : https://nodejs.org/dist/v22.21.1/node-v22.21.1-linux-arm64.tar.xz
           copying : node/22.21.1
         installed : v22.21.1 (with npm 10.9.4)
      ^[[0mNo npm engines section specified in package.json, using default=V10.9.4 ...^[[0m
      ^[[96mCheck current Node installation ...^[[0m
      ^[[0mInstalled Node version: ^[[1mv22.21.1^[[0m
      ^[[92mNo Node.js upgrade necessary.^[[0m
      ^[[96mCheck current NPM installation ...^[[0m
      ^[[0mNPM currently installed. Checking version number.
      ^[[0mMinimum npm version: ^[[1mV10.9.4^[[0m
      ^[[0mInstalled npm version: ^[[1mV10.9.4^[[0m
      ^[[92mNo npm upgrade necessary.^[[0m
      increasing swap space
      saving custom.css
      Upgrade ended - Fri Jan  2 13:41:45 PST 2026
      What’s going on?
        sdetweil @BKeyport
        @BKeyport can you do
        git branch
        git remote -v
        • BKeyportB Offline
          @sdetweil said in Magic Mirror Scripts - "Unable to determine upstream":
          git branch
          git remote -v
          bkey1970@mirrorserv:~ $ cd ~/MagicMirror
          git branch
          git remote -v
            _fix_clipping
          * master
          origin  git@github.com:MagicMirrorOrg/MagicMirror.git (fetch)
          origin  git@github.com:MagicMirrorOrg/MagicMirror.git (push)
            sdetweil @BKeyport
            @BKeyport said in Magic Mirror Scripts - "Unable to determine upstream":
            com:Mag
            how did that ‘:’ get between
            mine is origin
            https://github.com/MagicMirrorOrg/MagicMirror.git (fetch)
            try upgrade script again
              I gotta run to my daughters… back later
              • BKeyportB Offline
                It has to do with SSH. I’m failing out on SSH, but if I force it over to HTTPS it worked.
                BKeyportB S 2 Replies Last reply Reply Quote 0
                • BKeyportB Offline
                  $ git remote set-url  origin https://github.com/MagicMirrorOrg/MagicMirror.git
                  $ git remote set-url --push  origin https://github.com/MagicMirrorOrg/MagicMirror.git
                  For reference if seen again.
                    sdetweil @BKeyport
                    @BKeyport how /why ssh
                    • BKeyportB Offline
                      @sdetweil I think I had an error with my SSH keys and had to reset them. It’s cascading through my system. Basically, some idiot forgot he already had SSH on his system and set it up for another project. LOL
                        sdetweil @BKeyport
                        @BKeyport but nothing here is ssh??!!!
                        My script runs On the target system
                        • BKeyportB Offline
                          I must have manually installed MM originally, rather than using your scripts - cloning it via SSH rather than HTTPS.
                          • BKeyportB Offline
                            In any case, resetting the origin URL fixed it, so we have that in our toolbelt.
                              sdetweil @BKeyport
                              @BKeyport I fixed my script to handle that
