    MMM-Universal-PIR - ‘GPIOcommand exited with error!'
    7 Posts 2 Posters 1.6k Views 2 Watching
      smegbadger
      Hi
      With no warning (I haven’t carried out any updates) MMM-Universal-Pir is now failing. It shows under the ‘PIR SENSOR’ heading on the MM screen ‘gpioCommand exited with error!’
      Config is:
                          module: "MMM-Universal-Pir",
                              position: "bottom_right",
                                  gpioCommand: "gpiomon -r -b gpiochip0 23",
                                  onCommand: "wlr-randr --output HDMI-A-1 --on --transform 90",
                                  offCommand: "wlr-randr --output HDMI-A-1 --off",
                                  deactivateDelay: 120 * 1000,
      and in a terminal gpiomon -r -b gpiochip0 23 shows events when the PIR is triggered and
      wlr-randr --output HDMI-A-1 --on --transform 90 and wlr-randr --output HDMI-A-1 --off still control the screen.
      gpiomon is v1.6.3
      What can have changed?
      Steve
      • karsten13K Online
        karsten13 @smegbadger
        @smegbadger
        I had no idea about that, but now that you’re using Docker:
        The gpiomon command is called inside the container (doesn’t work) and you call it for testing on the host (does work).
        So I assume you have the newer version of gpiomon running in the container. So update the command in config.js to the new syntax described in the module README and try again (the new command will fail on the host but should work from inside the container).
          smegbadger @smegbadger
            smegbadger
            The Docker log shows
            [2026-02-10 11:30:10.955] [ERROR] [MMM-Universal-Pir] stderr: gpiomon: invalid option -- 'r' gpiomon: try gpiomon --help
            but gpiomon -r -b gpiochip0 23 works in a terminal when pasted from the config.js file, very strange
            It’s just stopped working!
            Steve
              smegbadger
              magicm@magicmirror:/opt/mm/mounts/config $ gpiomon --help
              Usage: gpiomon [OPTIONS] <chip name/number> <offset 1> <offset 2> ...
              Wait for events on GPIO lines and print them to standard output
              Options:
                -h, --help:           display this message and exit
                -v, --version:        display the version and exit
                -l, --active-low:     set the line active state to low
                -B, --bias=[as-is|disable|pull-down|pull-up] (defaults to 'as-is'):
                              set the line bias
                -n, --num-events=NUM: exit after processing NUM events
                -s, --silent:         don't print event info
                -r, --rising-edge:    only process rising edge events
                -f, --falling-edge:   only process falling edge events
                -b, --line-buffered:  set standard output as line buffered
                -F, --format=FMT      specify custom output format
              Biases:
                as-is:        leave bias unchanged
                disable:      disable bias
                pull-up:      enable pull-up
                pull-down:    enable pull-down
              Format specifiers:
                %o:  GPIO line offset
                %e:  event type (0 - falling edge, 1 rising edge)
                %s:  seconds part of the event timestamp
                %n:  nanoseconds part of the event timestamp
              magicm@magicmirror:/opt/mm/mounts/config $ gpiomon -v
              gpiomon (libgpiod) v1.6.3
              Copyright (C) 2017-2018 Bartosz Golaszewski
              License: LGPLv2.1
              This is free software: you are free to change and redistribute it.
              There is NO WARRANTY, to the extent permitted by law.
              -r is listed in the library help for v1.6.3
              • karsten13K Online
                @smegbadger
                  smegbadger
                  @karsten13 perfect, thank you. The Docker container has gpiomon at v2.2.1. It never occurred to me the container would update things unannounced!
                  Many thanks for your help
                  Steve
                  • S smegbadger has marked this topic as solved on
                  • karsten13K Online
                    @smegbadger said in MMM-Universal-PIR - ‘GPIOcommand exited with error!':
                    the container does not update things on your host, but the container itself is running debian and (if you are using karsten13/magicmirror:latest) the debian version of the container image switched from bookworm to trixie …
