    MMM-MyHomeWizard
    20 Posts 4 Posters 6.8k Views 4 Watching
    • V
      vansman @htilburgs
      @htilburgs Api is working. Actually i am using an older version of mmm.homewizard wich is working. I see that your version can provide more data including the watermeter. When i use config file below is see the data from mmm.homewizard but mmm.myhomewizard gives Header plus Loading…
      I changed the position to bottom_right but that doesn’t have effect. For the older version i use only right wich works in my config .
                      module: "MMM-HomeWizard",
                      position: "right",
                      header: "Electricity & Gas",
                              url: "http://192.168.178.152/api/v1/data",
                              updateInterval: 2000
        module: 'MMM-MyHomeWizard',
        position: 'bottom_right',
        header: 'HomeWizard',
        disabled: false,
      		P1_IP: "192.168.178.152",	    // IP Address HomeWizard P1 meter
      		WM_IP: "192.168.101.14",	    // IP Address HomeWizrd Water meter - Remove when not used
      		extraInfo: true, 	    // Show extra information from P1 meter
      		currentPower: true,	// Show the current Power Consumption
      		currentWater: true,	// Show the current Water Consumption
      		showGas: true,		    // Show the Gas option
      		showFooter: true,	    // Show footer (name Power Meter)
      		updateInterval: 5000,   // Update every 5 seconds
      		maxWidth: "500px",	    // Max Module width
              showLastUpdate: true,	// Show the last update for the History Data in the footer
              showDeltaPower: true,	// Show Delta between History and Current data (Power)
              showDeltaGas: true,		// Show Delta between History and Current data (Gas)
              showDeltaWater: true	// Show Delta between History and Current data (Water)
      I tried also 192.168.178.152/api/v1/data but that doesn’t work also.
      htilburgsH 1 Reply Last reply
      • htilburgsH
        htilburgs @vansman
        @vansman
        In the Homewizard app on your phone, you have to activatie the use of local api. What I think is strange is that when you go to
        that you don’t get any data. This mechanisme is the same as in MMM-Homewizard (see the config for your first app)
        Activating Local API
        Go to Settings > Meters > ‘‘Your meter’’, and enable Local API for the P1 Meter and/or the Water Meter at the botom of the page.
        The same for the Watermeter. If they are off, they don’t work.
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        • htilburgsH
          htilburgs @htilburgs
          @vansman
          Did it work?
          V 2 Replies Last reply
          • V
            vansman @htilburgs
            @htilburgs Progress! When i remove the line (IP adress) of the watermeter i see the data of the P1 meter.
            It looks like Homewizard create its own network in the 192.168.101.-- range. I also have an KWH1 meter wich also has an 192.168.101 adress. What i don’t understand how MagicMirror connects to the other ip network?
            And if i get the watermeter to work, is it also easy to add de KW1 meter also?
            • V
              vansman @htilburgs
              @htilburgs I think i found my problem. The Watermeter and the KWh1 meter are connected to the guest network. So that makes sense that they on a different network. I gonna change it and let you know.
              htilburgsH V 2 Replies Last reply
              • htilburgsH
                htilburgs @vansman
                @vansman
                Oké, sounds good. Succes!
                • V
                  vansman @vansman
                  @htilburgs P1 and Water works now. Thanks for your help and making this module.
                  I’ve also looked for the KWH enerymeter data myself but i get no data when i try to see it in the browser. Manual for the api on Homewizard site talks about V1 and V2. That for later :-)
                  I also add (Ai) current_voltage data on my screen, maybe nice to add native in your code.
                  • htilburgsH
                    htilburgs @vansman
                    @vansman said in MMM-MyHomeWizard:
                    What do you mean with current_voltage data?
                    When I look into HomeWizard, I don’t see this.
                    If you mean active_voltage, than I don’t see any use to know that my voltage is 230V, because if I’m right than this never changes (I hope ;-))
                    V 1 Reply Last reply
                    • V
                      vansman @htilburgs
                      @htilburgs Sorry i mean active voltage yes.
                      I look at it to see on a sunny day what’s the voltage.
                      Above 253V the solar panel inverter shuts down. This can happen when you have a lot of solar power in your neighbourhood. My peak was 247V.
                      • htilburgsH
                        htilburgs @vansman
                        @vansman
                        Just updated the module.
                        Since now Voltage is added, where autodetection is for 1-phase of 3-phase.
                        Don’t forget to update your config.js with
                        currentVoltage: true,     	// compact 3-fase, auto detection
                        I hope this is what you were asking for.
