    MMM-MyHomeWizard
    20 Posts 4 Posters 6.5k Views 4 Watching
    • V Offline
      vansman
      I installed the module and edit the config file including the ip adressen from the P1 and the watermeter.
      When i start MagicMirror is see de header Homewizard but it says Loading…
      Any suggetions what this could be?
      htilburgsH 1 Reply Last reply Reply Quote 0
      • htilburgsH Offline
        htilburgs @vansman
        @vansman
        Good morning. This can be a lot of things. You provided no info.
        Can you pleaase post your config (without any personal info)
        When you start MM with PM2, than please stop it.
        Go to ~/MagicMirror folder and start npm start dev and look if there are any errors.
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        • V Offline
          vansman @htilburgs
          @htilburgs Good day, I don’t start MM with PM2 .
          This is a part in of my config.js
          		module: "MMM-DHT-Sensor",
          		position: "bottom_right",
          		header: "Badkamer temperatuur",
          			sensorPin: 4,
              	sensorType: 11, // 11 for DHT11 or 22 for DHT22 / AM2302
              	updateInterval: 60000, //milliseconden
            module: 'MMM-MyHomeWizard',
            position: 'right',
            header: 'HomeWizard',
            disabled: false,
          		P1_IP: "192.168.178.152",	    // IP Address HomeWizard P1 meter
          		WM_IP: "192.168.101.14",	    // IP Address HomeWizrd Water meter - Remove when not used
          		extraInfo: true, 	    // Show extra information from P1 meter
          		currentPower: true,	// Show the current Power Consumption
          		currentWater: true,	// Show the current Water Consumption
          		showGas: true,		    // Show the Gas option
          		showFooter: true,	    // Show footer (name Power Meter)
          		updateInterval: 5000,   // Update every 5 seconds
          		maxWidth: "500px",	    // Max Module width
                  showLastUpdate: true,	// Show the last update for the History Data in the footer
                  showDeltaPower: true,	// Show Delta between History and Current data (Power)
                  showDeltaGas: true,		// Show Delta between History and Current data (Gas)
                  showDeltaWater: true	// Show Delta between History and Current data (Water)
            module: 'MMM-Pir',
            position: 'top_center',
          When i run npm start dev and filter on myhomewizard i see no errors,
          Load script: modules/MMM-MyHomeWizard/MMM-MyHomeWizard.js
          module.js:483 Module registered: MMM-MyHomeWizard
          loader.js:137 Bootstrapping module: MMM-MyHomeWizard
          loader.js:141 Scripts loaded for: MMM-MyHomeWizard
          loader.js:179 Load stylesheet: modules/MMM-MyHomeWizard/MMM-MyHomeWizard.css
          loader.js:144 Styles loaded for: MMM-MyHomeWizard
          translator.js:103 MMM-MyHomeWizard - Load translation: translations/nl.json
          loader.js:147 Translations loaded for: MMM-MyHomeWizard
          MMM-MyHomeWizard.js:38 Starting module: MMM-MyHomeWizard
            htilburgs @vansman
            @vansman
            The first thing I see in your configuration is
            position: 'right'
            As far as I know, that doesn’t work in MagicMirror and you should get an error when you’re loading MagicMirror.
            [2026-02-17 18:10:22.072] [WARN]  [check_config] Module 5 ("MMM-MyHomeWizard") uses unknown position: "right"
            [2026-02-17 18:10:22.073] [WARN]  [check_config] Known positions are: fullscreen_below, top_bar, top_left, top_center, top_right, upper_third, middle_center, lower_third, bottom_bar, bottom_left, bottom_center, bottom_right, fullscreen_above
            Can you change this to top_right and try what does happens?
            Checking your IP Addresses:
            You can check if your IP Addresses give information. Put in the next URL in a browser. If the IP Address is correct, you should get something like:
            P1 Meter: http://192.168.178.152/api/v1/data/
            Water: http://192.168.101.14/api/v1/data/
            Result:
              "wifi_ssid": "WiFi Network Name",
              "wifi_strength": 100,
              "smr_version": 50,
              "meter_model": "Sagemcom T210-D ESMR5.0",
              "unique_id": "ID",
              "active_tariff": 2,
              "total_power_import_kwh": 18833.243,
              "total_power_import_t1_kwh": 10804.883,
              "total_power_import_t2_kwh": 8028.36,
              "total_power_export_kwh": 0.166,
              "total_power_export_t1_kwh": 0.166,
              "total_power_export_t2_kwh": 0,
              "active_power_w": 398,
              "active_power_l1_w": 257,
              "active_power_l2_w": 27,
              "active_power_l3_w": 113,
              "active_voltage_l1_v": 230,
              "active_voltage_l2_v": 231,
              "active_voltage_l3_v": 230,
              "active_current_a": 1.726,
              "active_current_l1_a": 1.117,
              "active_current_l2_a": 0.117,
              "active_current_l3_a": 0.491,
              "voltage_sag_l1_count": 4,
              "voltage_sag_l2_count": 4,
              "voltage_sag_l3_count": 4,
              "voltage_swell_l1_count": 0,
              "voltage_swell_l2_count": 0,
              "voltage_swell_l3_count": 0,
              "any_power_fail_count": 54,
              "long_power_fail_count": 9,
              "total_gas_m3": 5595.841,
              "gas_timestamp": 260217182000,
              "gas_unique_id": "ID",
              "external": [
                  "unique_id": "ID",
                  "type": "gas_meter",
                  "timestamp": 260217182000,
                  "value": 5595.841,
                  "unit": "m3"
              "wifi_strength": 86,
              "total_liter_m3": 19.652,
              "active_liter_lpm": 0,
              "total_liter_offset_m3": 0
            MZ-BERM V 2 Replies Last reply Reply Quote 0
            • MZ-BERM Offline
              MZ-BER @htilburgs
              @htilburgs - can you please tell me how do you measure your gas consumption? Do you use any device that monitor the Gas counter?
                htilburgs @MZ-BER
                @MZ-BER
                It is measured with the P1 meter.
                It does both.
                • V Offline
                  vansman @htilburgs
                  @htilburgs Api is working. Actually i am using an older version of mmm.homewizard wich is working. I see that your version can provide more data including the watermeter. When i use config file below is see the data from mmm.homewizard but mmm.myhomewizard gives Header plus Loading…
                  I changed the position to bottom_right but that doesn’t have effect. For the older version i use only right wich works in my config .
                                  module: "MMM-HomeWizard",
                                  position: "right",
                                  header: "Electricity & Gas",
                                          url: "http://192.168.178.152/api/v1/data",
                                          updateInterval: 2000
                    position: 'bottom_right',
                    disabled: false,
                  I tried also 192.168.178.152/api/v1/data but that doesn’t work also.
                    htilburgs @vansman
                    @vansman
                    In the Homewizard app on your phone, you have to activatie the use of local api. What I think is strange is that when you go to
                    that you don’t get any data. This mechanisme is the same as in MMM-Homewizard (see the config for your first app)
                    Activating Local API
                    Go to Settings > Meters > ‘‘Your meter’’, and enable Local API for the P1 Meter and/or the Water Meter at the botom of the page.
                    The same for the Watermeter. If they are off, they don’t work.
                      htilburgs @htilburgs
                      @vansman
                      Did it work?
                      • V Offline
                        vansman @htilburgs
                        @htilburgs Progress! When i remove the line (IP adress) of the watermeter i see the data of the P1 meter.
                        It looks like Homewizard create its own network in the 192.168.101.-- range. I also have an KWH1 meter wich also has an 192.168.101 adress. What i don’t understand how MagicMirror connects to the other ip network?
                        And if i get the watermeter to work, is it also easy to add de KW1 meter also?
                        • V Offline
                          vansman @htilburgs
                          @htilburgs I think i found my problem. The Watermeter and the KWh1 meter are connected to the guest network. So that makes sense that they on a different network. I gonna change it and let you know.
                          htilburgsH V 2 Replies Last reply Reply Quote 0
                            htilburgs @vansman
                            @vansman
                            Oké, sounds good. Succes!
                            • V Offline
                              vansman @vansman
                              @htilburgs P1 and Water works now. Thanks for your help and making this module.
                              I’ve also looked for the KWH enerymeter data myself but i get no data when i try to see it in the browser. Manual for the api on Homewizard site talks about V1 and V2. That for later :-)
                              I also add (Ai) current_voltage data on my screen, maybe nice to add native in your code.
                                htilburgs @vansman
                                @vansman said in MMM-MyHomeWizard:
                                What do you mean with current_voltage data?
                                When I look into HomeWizard, I don’t see this.
                                If you mean active_voltage, than I don’t see any use to know that my voltage is 230V, because if I’m right than this never changes (I hope ;-))
                                • V Offline
                                  vansman @htilburgs
                                  @htilburgs Sorry i mean active voltage yes.
                                  I look at it to see on a sunny day what’s the voltage.
                                  Above 253V the solar panel inverter shuts down. This can happen when you have a lot of solar power in your neighbourhood. My peak was 247V.
                                    htilburgs @vansman
                                    @vansman
                                    Just updated the module.
                                    Since now Voltage is added, where autodetection is for 1-phase of 3-phase.
                                    Don’t forget to update your config.js with
                                    currentVoltage: true,     	// compact 3-fase, auto detection
                                    I hope this is what you were asking for.
