    MMM-BackgroundSlideshow remove imageInfo header
    7 Posts 3 Posters 1.4k Views 3 Watching
      mrchips83
      Using MMM-BackgroundSlideshow for a while now and trying to tweak the imageInfo box to remove the header.
      Current header: PICTURE INFO
      I’d like to remove it entirely.
      My module config is below:
      			module: 'MMM-BackgroundSlideshow',
      			position: 'fullscreen_below',
        				imagePaths: ['/mnt/nas/'],
      			recursiveSubDirectories: true,
      			transitionImages: false,
        				randomizeImageOrder: true,
      			showImageInfo:	true,
      			imageInfoLocation: "bottomRight",
      			**imageInfoTitle: "Photo Details",	//fails to change header**
      			imageInfo: "date",
      			showProgressBar: false,
      			imageInfoNoFileExt: true,
      			showAllImagesBeforeRestart: true,
      			slideshowSpeed: 600000
      Note: the bold line (imageInfoTitle) was my attempt to change it to see if that worked but it didn’t.
      Bonus points for any way to have the photo date display without the timestamp
      R S 2 Replies Last reply Reply Quote 0
        rkorell Module Developer @mrchips83
        Dear @mrchips83 ,
        as far as I can see “PICTURE INFO” including the underline seems to be the standard module header.
        You simply can get rid of it if you put a
        header: “”,
        in your modules config section.
        so
        			header: "", 	//<- this should work
        			imageInfo: "date",
        should do the trick.
        I cannot contribute to eliminating the timstamp, sorry.
        Warm regards, and good. luck,
        Ralf
          sdetweil @rkorell
          @rkorell the header: property goes outside the modules config section, as it is a MagicMirror owned property
          The module does not provide a direct config property for that
            sdetweil @mrchips83
            @mrchips83 currently the code displays the the date and time together as one entity so the time itself cannot be hidden
              mrchips83
              Thanks guys
                @sdetweil YES, you are SO right!
                Sorry!
                so
                			imageInfo: "date",
                should work…
                Ralf
                  mrchips83 @rkorell
                  @rkorell
                  Thanks Ralf, tried that but still no luck!
                  That allows me to add/remove text at the top of the module header but doesn’t allow modification of the header of the embedded ‘imageInfo box’.
                  I’ve tried:
                  imageInfoTitle: “test”,
                  and
                  imageInfoHeader: “test”,
                  with no luck either.
                  Searching here: https://github.com/darickc/MMM-BackgroundSlideshow suggests like it’s not configurable and I’ll just have to live with it
