    EBADENGINE npm error eslint/espree - MMM-EarthquakeAlerts
    5 Posts 2 Posters 190 Views 2 Watching
    • UncleRogerU Offline
      UncleRoger
      My Mirror was down for a while and when I booted it up again, I had some updates to do. These included MMM-EarthquakeAlerts and MMM-BackgroundSlideshow.
      I did a “git pull” and “npm install” for MMM-BackgroundSlideshow and it seemed fine. I did the same for MMM-Traffic and again, it seemed fine. Then I did it for MMM-EarthquakeAlerts and got a bunch of messages after the “npm install” saying “EBADENGINE”:
      npm install
      npm WARN EBADENGINE Unsupported engine {
      npm WARN EBADENGINE   package: '@eslint/config-array@0.23.2',
      npm WARN EBADENGINE   required: { node: '^20.19.0 || ^22.13.0 || >=24' },
      npm WARN EBADENGINE   current: { node: 'v20.9.0', npm: '10.1.0' }
      npm WARN EBADENGINE }
      npm WARN EBADENGINE   package: '@eslint/config-helpers@0.5.2',
      and so on. There are a total of 11 sets, all for “@eslint/something” except the last which just says "espree@11.1.1’ for the package.
      I think that I need to update node.js to at least version 20.19 but I’m not sure how to do that. I honestly have no idea how I installed it in the first place except that it was probably via Sam’s excellent scripts?
      If anyone has any suggestions on how to fix this, I’d really appreciate it. I found that I’ve really come to rely on it.
        sdetweil @UncleRoger
        @UncleRoger n stores in the /usr folder, so you have to use sudo for that
        sudo n 20.9
        UncleRogerU 1 Reply Last reply Reply Quote 0
          @UncleRoger can you check for either tool?
          n
          Or
          nvm
          See if either responds
          Or get not found
          My upgrade script would have tried to redo npm install for the modules after upgrading node
            UncleRoger @sdetweil
            nvm was not found but n was – it gave me the option to install 20.8.0 or 20.9.0 so I picked the latter and got a whole lot of “cannot remove” errors. That’s the version I have currently.
            So should I use the upgrade script or have I mucked it up too much for that?
              sudo n 20.9
                Thank you! I think that fixed it.
