    MMM-MyGarbage
    62 Posts 28 Posters 53.2k Views 30 Watching
    • htilburgsH Offline
      htilburgs @sifuhall
      @sifuhall
      I Will have to look in it. Today I have no time.
      I come back tomorrow.
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
      • W Offline
        wwats
        Hello, i have the same problem… there is loading and loading again… thanks for Your answer
          mickecarlsson @wwats
          @wwats
          Check that ypu only have 1 (one) extra line at the end of the CSV-file, if you have more than one, the module crashes
          htilburgsH 1 Reply Last reply Reply Quote 0
            htilburgs @mickecarlsson
            Today I published an updated version (v2.0.0) with CSV and iCal support.
            Everything has been thoroughly tested, but if you encounter any issues despite this, please let me know.
            https://github.com/htilburgs/MMM-MyGarbage/issues
              mickecarlsson @htilburgs
              @htHilburgs
              Just did the upgrade, did not work until I remembered I had done some tweaking in the MMM-MyGarbage.js so that I could name the bins as per my use. I had named them Fyrfack1, Fyrfack2 and Tradgard.
              I just reversed that to the default names in the csv-file and modified my config to set up the colors I use.
              My config.js section:
                              module: 'MMM-MyGarbage',
                              position: 'top_left',
                              header: 'Sophämtning',
                                  weeksToDisplay: '3',
                                  binColors: {          // Define custom Bin Colors
                                      GreenBin: "#8B4513",
                                      PaperBin: "#0000FF",
                                      GarbageBin: "#008000",
              Now the module is just works like the old one.
              Thanks for the update.
                @mickecarlsson
                That is the risk of editing the .js file. ;-)
                I’m glad you remembered and that you have corrected it.
                Have fun!
                  htilburgs
                  Just published an update:
                  2.0.1 : Update for Streamline date parsing and allow for recurring events in ical (thx to @thepagan)
                  2.1.0 : Update for CSV file and alertThreshold (add to your config.js!)
                  2.1.1 : bugfix for the alertThreshold
                  2.1.2 : Update for rare AxiosError [AggregateError] when loading iCal
                    htilburgs @htilburgs
                    Just published an update v3.0.0
                    • Add support for flexible numbers of Bins
                    • Bin names are automaticly detected
                    • Match bin colors to bin names for csv and ical
                    • Error message instead of “Loading…” when the CSV or ICAL is in wrong format
                    • Better debug information in console and in module
                    • Clean up code
                    Enjoy this new version and if you find any issues, please report them here
                    htilburgsH 1 Reply Last reply Reply Quote 1
                      Just published an update v3.1.0
                      • Add support for combined multiple same day pickups into 1 ICS event (thanks to @PlatinumPenguin)
                      • Clean up code to prevent crashes
                        htilburgs
                        Published update to V3.1.1
                        • list itemFix weeksToDisplay For example: 2 weeks are 14 days so this could end up showing 3 weeks. Now fixed to ISO weeks.
                        • list itemNormalized all dates to ISO strings
                        • list itemImprove CSV bin filtering (avoid garbage data)
                        • 4 / 4
