    Default Calendar Not Loading Events After New MM Update
    69 Posts 8 Posters 20.1k Views 8 Watching
    • KristjanESPERANTOK
      KristjanESPERANTO Module Developer @hrt13
      @hrt13 said:
      [2026-04-02 19:59:16.671] [ERROR] [calendar] Could not expand event “Tax Day”: ical.expandRecurringEvent is not a function
      Looks like you didn’t update the dependencies after you pulled the new MM version.
      Please run node --run install-mm and check again.
      • H
        hrt13 @KristjanESPERANTO
        trying it now, it is taking a while. Will let you know.
        I used mmpm to update, I guess it doesn’t update the dependencies.
          A workaround for users still having issues with the calendar. There was a problem with the node-ical package for some events. This has just been fixed with a new node-ical release (v0.26.0).
          To use the new version, run this command in the MagicMirror directory:
          npm install node-ical@latest.
          Note that this will change your package.json and package-lock.json files, which would cause conflicts during the next MagicMirror update. Therefore, also run the following to restore them:
          git restore package*.json
          You will then have v0.26.0 installed - the package.json file say otherwise, but that doesn’t matter.
          Please give some feedback if that helps :-)
            doogy_rev
            I have just updated to the latest version and have the same issue of the Calendar not loading.
            I have tried the above suggestions but still not able to load gmail calendars
            I did use the script to update MM and all dependancies
            Any help appreciated
            DoogyRev
              sdetweil @doogy_rev
              @doogy_rev can you show me the ~/MagicMirror/installers/upgrade.log
              Maybe send it to me
              Same userid at gmail
              It is two part process, right?
                doogy_rev
                Hi Sam,
                Log sent to your gmail
                DoogyRev
                  sdetweil @doogy_rev
                  @doogy_rev it looks like you tried it manually, git pull, and the latest code was already present
                  local version 2.35.0 already same as master 2.35.0
                  The upgrade by default will not upgrade over the existing version
                  To fix, rerun and change the parm from apply to force
                    doogy_rev @sdetweil
                    ok, so I know enough to be dangerous, what is the command I should be committing?
                      sdetweil @doogy_rev
                      @doogy_rev if you copy paste the second upgrade command from my script GitHub repo, you will see the word
                      apply
                      At the end
                      Change that to
                      force
                      And hit enter
                        doogy_rev
                        @sdetweil That worked, thanks very much.
                          sdetweil @doogy_rev
                          @doogy_rev awesome… thanks for the feedback
                          • A
                            Athlon @sdetweil
                            My calendar also stopped showing events (from my Google calendar).
                            Running
                            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                            fixed it for me. It worked like ‘Magic’ - pun intended.
                            Thank you!!
                              sdetweil @Athlon
                              @Athlon ok, that means the manual upgrade failed. but pulled the new code
                              git pull && npm run install-mm
                              means the git pull encountered a problem, and the npm run didn’t happen,m
                              but there is no log…
                              can you send me the ~/MagicMirror/installers/upgrade.log so I can see what the problem might have been
                              same userid at gmail, thanks…
                              • A
                                Athlon @sdetweil
                                sent…
                                  sdetweil @Athlon
                                  @Athlon replied
                                  for others, this was a node version mismatch that cause the npm run install-mm to fail,
                                  leaving the new source installed, but the dependencies NOT installed.
                                  so, something will fail… calendar for you
                                  • A
                                    angeliKITTYx
                                    Reviving this… I’m having the same issues and got a little lost in the steps in the replies.
                                    [2026-04-27 19:39:42.912] [ERROR] [calendar] Could not expand event "CHEM 122L": ical.expandRecurringEvent is not a function
                                    [2026-04-27 19:39:42.912] [INFO]  [calendar] Broadcasting 0 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
                                    [2026-04-27 19:40:16.774] [LOG]   [electron] Shutting down server...
                                    kittypi@KITTYpi:~/MagicMirror $ git pull && npm run install-mm
                                    Already up to date.
                                    > magicmirror@2.35.0 install-mm
                                    > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                                    npm error code EBADENGINE
                                    npm error engine Unsupported engine
                                    npm error engine Not compatible with your version of node/npm: magicmirror@2.35.0
                                    npm error notsup Not compatible with your version of node/npm: magicmirror@2.35.0
                                    npm error notsup Required: {"node":">=22.21.1 <23 || >=24"}
                                    npm error notsup Actual:   {"node":"v22.19.0","npm":"11.13.0"}
                                    npm error A complete log of this run can be found in: /home/kittypi/.npm/_logs/2026-04-27T23_48_16_062Z-debug-0.log
                                      sdetweil @angeliKITTYx
                                      @angeliKITTYx you are on node 22.19, and we need 22.21.1
                                      If you use my scripted install or update then it will take care of that.
                                      Because you did part of the install (git pull), the new version code is loaded
                                      But not its dependencies, so MagicMirror won’t run correctly
                                      You could run my upgrade script with force instead of apply
                                      As it won’t let you install/upgrade over the current level.
                                      See
                                      • A
                                        angeliKITTYx @sdetweil
                                        @sdetweil thanks for the quick reply. I did the first line under the Update section and got the same results. All of the modules are working except CalEXT3 - it shows, but no events populate and I get all of those “not a function” errors.
                                        I also tried running the second command in that section and got the same results. I’m probably missing a step somewhere…
                                        kittypi@KITTYpi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                                        update log will be in /home/kittypi/MagicMirror/installers/upgrade.log
                                        Minimum Node version: v22.21.1
                                        Installed Node version: v22.19.0
                                        Node should be upgraded.
                                        Node.js upgrade defered, doing test run
                                        Minimum npm version: V10.9.4
                                        Installed npm version: V11.13.0
                                        No npm upgrade necessary.
                                        upgrading from version 2.35.0 to 2.35.0
                                        bash: line 772: pm2: command not found
                                        fetching latest revisions
                                        updating dependencies for active modules with package.json files
                                        	processing for module MMM-CalendarExt3 please wait
                                        	skipped processing for MMM-CalendarExt3, doing test run
                                        	processing complete for module MMM-CalendarExt3
                                        	processing for module MMM-Jokes please wait
                                        	skipped processing for MMM-Jokes, doing test run
                                        	processing complete for module MMM-Jokes
                                        	processing for module MMM-Todoist2 please wait
                                        	skipped processing for MMM-Todoist2, doing test run
                                        	processing complete for module MMM-Todoist2
                                        	processing for module MMM-ISS-Live please wait
                                        	skipped processing for MMM-ISS-Live, doing test run
                                        	processing complete for module MMM-ISS-Live
                                        moving css contents to config
                                          @angeliKITTYx correct. It says doing test run , no changes will be made
                                          The doc says this is a 2 part update process
                                          Test, advise any issues , no changes
                                          The second part, Do
                                          The second line to copy ends with the word
                                          apply
                                          Which I want you to change to
                                          force
                                          • A
                                            I fear I have made it even worse…
                                            kittypi@KITTYpi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                                            doing test run = false
                                            installing correct version of node and npm, please wait
                                            sudo: n: command not found
                                            Installing Node.js ...
                                            using sudo n v22.21.1
                                            force: line 446: sudo n  v22.21.1 : command not found
                                            node version is
                                            Node.js installation Done! version=v22.19.0
                                            want /var/swap=512MByte, checking existing: keeping it
                                            force: line 772: pm2: command not found
                                            npm error A complete log of this run can be found in: /home/kittypi/.npm/_logs/2026-04-28T00_48_25_147Z-debug-0.log
                                            npm warn "install" is being parsed as a normal command line argument.
                                            npm warn Unknown cli config "--audit --no-fund --no-update-notifier". This will stop working in the next major version of npm.
                                            > mmm-calendarext3@1.12.4 postinstall
                                            > git submodule update --init --recursive
                                            Submodule path 'CX3_Shared': checked out 'c097e31c073007cf16e86f695bed1c807f581aef'
                                            up to date, audited 1 package in 1s
                                            found 0 vulnerabilities
                                            npm warn deprecated har-validator@5.1.5: this library is no longer supported
                                            npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                            npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                            added 50 packages, and audited 51 packages in 6s
                                            4 packages are looking for funding
                                              run `npm fund` for details
                                            6 vulnerabilities (4 moderate, 2 critical)
                                            Some issues need review, and may require choosing
                                            a different dependency.
                                            Run `npm audit` for details.
                                            > mmm-iss-live@2.3.1 prepare
                                            > simple-git-hooks || true
                                            sh: 1: simple-git-hooks: not found
                                            up to date, audited 1 package in 967ms
                                            kittypi@KITTYpi:~/MagicMirror $ npm run start
                                            > magicmirror@2.35.0 start
                                            > node --run start:wayland
                                            /bin/sh: 1: ./node_modules/.bin/electron: not found
                                            • 2 / 4
