    Default Calendar Not Loading Events After New MM Update
    69 Posts 8 Posters 17.4k Views 8 Watching
      sdetweil @doogy_rev
      @doogy_rev can you show me the ~/MagicMirror/installers/upgrade.log
      Maybe send it to me
      Same userid at gmail
      It is two part process, right?
        doogy_rev
        Hi Sam,
        Log sent to your gmail
        DoogyRev
          sdetweil @doogy_rev
          @doogy_rev it looks like you tried it manually, git pull, and the latest code was already present
          local version 2.35.0 already same as master 2.35.0
          The upgrade by default will not upgrade over the existing version
          To fix, rerun and change the parm from apply to force
            doogy_rev @sdetweil
            ok, so I know enough to be dangerous, what is the command I should be committing?
              sdetweil @doogy_rev
              @doogy_rev if you copy paste the second upgrade command from my script GitHub repo, you will see the word
              apply
              At the end
              Change that to
              force
              And hit enter
                doogy_rev
                @sdetweil That worked, thanks very much.
                  sdetweil @doogy_rev
                  @doogy_rev awesome… thanks for the feedback
                    Athlon @sdetweil
                    My calendar also stopped showing events (from my Google calendar).
                    Running
                    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                    fixed it for me. It worked like ‘Magic’ - pun intended.
                    Thank you!!
                      sdetweil @Athlon
                      @Athlon ok, that means the manual upgrade failed. but pulled the new code
                      git pull && npm run install-mm
                      means the git pull encountered a problem, and the npm run didn’t happen,m
                      but there is no log…
                      can you send me the ~/MagicMirror/installers/upgrade.log so I can see what the problem might have been
                      same userid at gmail, thanks…
                        Athlon @sdetweil
                        sent…
                          sdetweil @Athlon
                          @Athlon replied
                          for others, this was a node version mismatch that cause the npm run install-mm to fail,
                          leaving the new source installed, but the dependencies NOT installed.
                          so, something will fail… calendar for you
                            angeliKITTYx
                            Reviving this… I’m having the same issues and got a little lost in the steps in the replies.
                            [2026-04-27 19:39:42.912] [ERROR] [calendar] Could not expand event "CHEM 122L": ical.expandRecurringEvent is not a function
                            [2026-04-27 19:39:42.912] [INFO]  [calendar] Broadcasting 0 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
                            [2026-04-27 19:40:16.774] [LOG]   [electron] Shutting down server...
                            kittypi@KITTYpi:~/MagicMirror $ git pull && npm run install-mm
                            Already up to date.
                            > magicmirror@2.35.0 install-mm
                            > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                            npm error code EBADENGINE
                            npm error engine Unsupported engine
                            npm error engine Not compatible with your version of node/npm: magicmirror@2.35.0
                            npm error notsup Not compatible with your version of node/npm: magicmirror@2.35.0
                            npm error notsup Required: {"node":">=22.21.1 <23 || >=24"}
                            npm error notsup Actual:   {"node":"v22.19.0","npm":"11.13.0"}
                            npm error A complete log of this run can be found in: /home/kittypi/.npm/_logs/2026-04-27T23_48_16_062Z-debug-0.log
                              sdetweil @angeliKITTYx
                              @angeliKITTYx you are on node 22.19, and we need 22.21.1
                              If you use my scripted install or update then it will take care of that.
                              Because you did part of the install (git pull), the new version code is loaded
                              But not its dependencies, so MagicMirror won’t run correctly
                              You could run my upgrade script with force instead of apply
                              As it won’t let you install/upgrade over the current level.
                              See
                                angeliKITTYx @sdetweil
                                @sdetweil thanks for the quick reply. I did the first line under the Update section and got the same results. All of the modules are working except CalEXT3 - it shows, but no events populate and I get all of those “not a function” errors.
                                I also tried running the second command in that section and got the same results. I’m probably missing a step somewhere…
                                kittypi@KITTYpi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                                update log will be in /home/kittypi/MagicMirror/installers/upgrade.log
                                Minimum Node version: v22.21.1
                                Installed Node version: v22.19.0
                                Node should be upgraded.
                                Node.js upgrade defered, doing test run
                                Minimum npm version: V10.9.4
                                Installed npm version: V11.13.0
                                No npm upgrade necessary.
                                upgrading from version 2.35.0 to 2.35.0
                                bash: line 772: pm2: command not found
                                fetching latest revisions
                                updating dependencies for active modules with package.json files
                                	processing for module MMM-CalendarExt3 please wait
                                	skipped processing for MMM-CalendarExt3, doing test run
                                	processing complete for module MMM-CalendarExt3
                                	processing for module MMM-Jokes please wait
                                	skipped processing for MMM-Jokes, doing test run
                                	processing complete for module MMM-Jokes
                                	processing for module MMM-Todoist2 please wait
                                	skipped processing for MMM-Todoist2, doing test run
                                	processing complete for module MMM-Todoist2
                                	processing for module MMM-ISS-Live please wait
                                	skipped processing for MMM-ISS-Live, doing test run
                                	processing complete for module MMM-ISS-Live
                                moving css contents to config
                                  @angeliKITTYx correct. It says doing test run , no changes will be made
                                  The doc says this is a 2 part update process
                                  Test, advise any issues , no changes
                                  The second part, Do
                                  The second line to copy ends with the word
                                  apply
                                  Which I want you to change to
                                  force
                                    I fear I have made it even worse…
                                    kittypi@KITTYpi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                                    doing test run = false
                                    installing correct version of node and npm, please wait
                                    sudo: n: command not found
                                    Installing Node.js ...
                                    using sudo n v22.21.1
                                    force: line 446: sudo n  v22.21.1 : command not found
                                    node version is
                                    Node.js installation Done! version=v22.19.0
                                    want /var/swap=512MByte, checking existing: keeping it
                                    force: line 772: pm2: command not found
                                    npm error A complete log of this run can be found in: /home/kittypi/.npm/_logs/2026-04-28T00_48_25_147Z-debug-0.log
                                    npm warn "install" is being parsed as a normal command line argument.
                                    npm warn Unknown cli config "--audit --no-fund --no-update-notifier". This will stop working in the next major version of npm.
                                    > mmm-calendarext3@1.12.4 postinstall
                                    > git submodule update --init --recursive
                                    Submodule path 'CX3_Shared': checked out 'c097e31c073007cf16e86f695bed1c807f581aef'
                                    up to date, audited 1 package in 1s
                                    found 0 vulnerabilities
                                    npm warn deprecated har-validator@5.1.5: this library is no longer supported
                                    npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                    npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                    added 50 packages, and audited 51 packages in 6s
                                    4 packages are looking for funding
                                      run `npm fund` for details
                                    6 vulnerabilities (4 moderate, 2 critical)
                                    Some issues need review, and may require choosing
                                    a different dependency.
                                    Run `npm audit` for details.
                                    > mmm-iss-live@2.3.1 prepare
                                    > simple-git-hooks || true
                                    sh: 1: simple-git-hooks: not found
                                    up to date, audited 1 package in 967ms
                                    kittypi@KITTYpi:~/MagicMirror $ npm run start
                                    > magicmirror@2.35.0 start
                                    > node --run start:wayland
                                    /bin/sh: 1: ./node_modules/.bin/electron: not found
                                      @angeliKITTYx another fun time
                                      Do
                                      sudo npm install -g n
                                      sudo n 22.21.1
                                      hash -r
                                      node -v
                                      If it says 22.21.1
                                      Then do
                                      npm run install-mm
                                      If it says successful then
                                      npm run start:x11
                                        kittypi@KITTYpi:~/MagicMirror $ sudo npm install -g n
                                        sudo n 22.21.1
                                        hash -r
                                        node -v
                                        sudo: npm: command not found
                                        v22.19.0
                                          @angeliKITTYx ok
                                          sudo apt update
                                          sudo apt install nodejs
                                          If that ends ok
                                          node -v
                                            still no luck :(
                                            I’m logging off for the evening, but I’ll check back in tomorrow. Thank you for all the help you provide!
                                            kittypi@KITTYpi:~/MagicMirror $ sudo apt update
                                            Hit:1 http://deb.debian.org/debian bookworm InRelease
                                            Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                            Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                            Reading package lists... Done
                                            Building dependency tree... Done
                                            All packages are up to date.
                                              libbasicusageenvironment1 libgroupsock8 liblivemedia77 linux-headers-6.12.25+rpt-common-rpi linux-headers-6.12.25+rpt-rpi-2712
                                              linux-headers-6.12.25+rpt-rpi-v8 linux-image-6.12.25+rpt-rpi-2712 linux-image-6.12.25+rpt-rpi-v8 linux-kbuild-6.12.25+rpt
                                              python3-v4l2
                                            Use 'sudo apt autoremove' to remove them.
                                            The following additional packages will be installed:
                                              libc-ares2 libnode108 libuv1 node-acorn node-busboy node-cjs-module-lexer node-undici node-xtend nodejs-doc
                                            Suggested packages:
                                              npm
                                            The following NEW packages will be installed:
                                              libc-ares2 libnode108 libuv1 node-acorn node-busboy node-cjs-module-lexer node-undici node-xtend nodejs nodejs-doc
                                            0 upgraded, 10 newly installed, 0 to remove and 0 not upgraded.
                                            Need to get 14.2 MB of archives.
                                            After this operation, 66.5 MB of additional disk space will be used.
                                            Do you want to continue? [Y/n] y
                                            Get:1 http://deb.debian.org/debian bookworm/main arm64 libc-ares2 arm64 1.18.1-3 [99.2 kB]
                                            Get:2 http://deb.debian.org/debian bookworm/main arm64 libuv1 arm64 1.44.2-1+deb12u1 [130 kB]
                                            Get:3 http://deb.debian.org/debian bookworm/main arm64 node-xtend all 4.0.2-3 [3,932 B]
                                            Get:4 http://deb.debian.org/debian bookworm/main arm64 nodejs arm64 18.20.4+dfsg-1~deb12u1 [319 kB]
                                            Get:5 http://deb.debian.org/debian bookworm/main arm64 node-acorn all 8.8.1+ds+~cs25.17.7-2 [128 kB]
                                            Get:6 http://deb.debian.org/debian bookworm/main arm64 node-cjs-module-lexer all 1.2.2+dfsg-5 [30.1 kB]
                                            Get:7 http://deb.debian.org/debian bookworm/main arm64 node-busboy all 1.6.0+~cs2.6.0-2 [16.9 kB]
                                            Get:8 http://deb.debian.org/debian bookworm/main arm64 node-undici all 5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4 [285 kB]
                                            Get:9 http://deb.debian.org/debian bookworm/main arm64 libnode108 arm64 18.20.4+dfsg-1~deb12u1 [9,565 kB]
                                            Get:10 http://deb.debian.org/debian bookworm/main arm64 nodejs-doc all 18.20.4+dfsg-1~deb12u1 [3,579 kB]
                                            Fetched 14.2 MB in 4s (3,796 kB/s)
                                            Selecting previously unselected package libc-ares2:arm64.
                                            (Reading database ... 171415 files and directories currently installed.)
                                            Preparing to unpack .../0-libc-ares2_1.18.1-3_arm64.deb ...
                                            Unpacking libc-ares2:arm64 (1.18.1-3) ...
                                            Selecting previously unselected package libuv1:arm64.
                                            Preparing to unpack .../1-libuv1_1.44.2-1+deb12u1_arm64.deb ...
                                            Unpacking libuv1:arm64 (1.44.2-1+deb12u1) ...
                                            Selecting previously unselected package node-xtend.
                                            Preparing to unpack .../2-node-xtend_4.0.2-3_all.deb ...
                                            Unpacking node-xtend (4.0.2-3) ...
                                            Selecting previously unselected package nodejs.
                                            Preparing to unpack .../3-nodejs_18.20.4+dfsg-1~deb12u1_arm64.deb ...
                                            Unpacking nodejs (18.20.4+dfsg-1~deb12u1) ...
                                            Selecting previously unselected package node-acorn.
                                            Preparing to unpack .../4-node-acorn_8.8.1+ds+~cs25.17.7-2_all.deb ...
                                            Unpacking node-acorn (8.8.1+ds+~cs25.17.7-2) ...
                                            Selecting previously unselected package node-cjs-module-lexer.
                                            Preparing to unpack .../5-node-cjs-module-lexer_1.2.2+dfsg-5_all.deb ...
                                            Unpacking node-cjs-module-lexer (1.2.2+dfsg-5) ...
                                            Selecting previously unselected package node-busboy.
                                            Preparing to unpack .../6-node-busboy_1.6.0+~cs2.6.0-2_all.deb ...
                                            Unpacking node-busboy (1.6.0+~cs2.6.0-2) ...
                                            Selecting previously unselected package node-undici.
                                            Preparing to unpack .../7-node-undici_5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4_all.deb ...
                                            Unpacking node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4) ...
                                            Selecting previously unselected package libnode108:arm64.
                                            Preparing to unpack .../8-libnode108_18.20.4+dfsg-1~deb12u1_arm64.deb ...
                                            Unpacking libnode108:arm64 (18.20.4+dfsg-1~deb12u1) ...
                                            Selecting previously unselected package nodejs-doc.
                                            Preparing to unpack .../9-nodejs-doc_18.20.4+dfsg-1~deb12u1_all.deb ...
                                            Unpacking nodejs-doc (18.20.4+dfsg-1~deb12u1) ...
                                            Setting up node-cjs-module-lexer (1.2.2+dfsg-5) ...
                                            Setting up libc-ares2:arm64 (1.18.1-3) ...
                                            Setting up libuv1:arm64 (1.44.2-1+deb12u1) ...
                                            Setting up nodejs-doc (18.20.4+dfsg-1~deb12u1) ...
                                            Setting up node-xtend (4.0.2-3) ...
                                            Setting up node-busboy (1.6.0+~cs2.6.0-2) ...
                                            Setting up node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4) ...
                                            Setting up node-acorn (8.8.1+ds+~cs25.17.7-2) ...
                                            Setting up libnode108:arm64 (18.20.4+dfsg-1~deb12u1) ...
                                            Setting up nodejs (18.20.4+dfsg-1~deb12u1) ...
                                            update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
                                            Processing triggers for man-db (2.11.2-2) ...
                                            Processing triggers for libc-bin (2.36-9+rpt2+deb12u13) ...
                                            kittypi@KITTYpi:~/MagicMirror $ node -v
                                            v22.19.0
                                            sudo n 22.21.1
                                            hash -r
                                            node -v
                                            v22.19.0
                                            • 2 / 4
