    Default Calendar Not Loading Events After New MM Update
    69 Posts 8 Posters 20.1k Views 8 Watching
      sdetweil @angeliKITTYx
      @angeliKITTYx correct. It says doing test run , no changes will be made
      The doc says this is a 2 part update process
      Test, advise any issues , no changes
      The second part, Do
      The second line to copy ends with the word
      apply
      Which I want you to change to
      force
      A 1 Reply Last reply
      • A
        angeliKITTYx @sdetweil
        I fear I have made it even worse…
        kittypi@KITTYpi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
        update log will be in /home/kittypi/MagicMirror/installers/upgrade.log
        Minimum Node version: v22.21.1
        Installed Node version: v22.19.0
        Node should be upgraded.
        Node.js upgrade defered, doing test run
        Minimum npm version: V10.9.4
        Installed npm version: V11.13.0
        No npm upgrade necessary.
        upgrading from version 2.35.0 to 2.35.0
        bash: line 772: pm2: command not found
        fetching latest revisions
        updating dependencies for active modules with package.json files
        	processing for module MMM-CalendarExt3 please wait
        	skipped processing for MMM-CalendarExt3, doing test run
        	processing complete for module MMM-CalendarExt3
        	processing for module MMM-Jokes please wait
        	skipped processing for MMM-Jokes, doing test run
        	processing complete for module MMM-Jokes
        	processing for module MMM-Todoist2 please wait
        	skipped processing for MMM-Todoist2, doing test run
        	processing complete for module MMM-Todoist2
        	processing for module MMM-ISS-Live please wait
        	skipped processing for MMM-ISS-Live, doing test run
        	processing complete for module MMM-ISS-Live
        moving css contents to config
        kittypi@KITTYpi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
        doing test run = false
        installing correct version of node and npm, please wait
        sudo: n: command not found
        Installing Node.js ...
        using sudo n v22.21.1
        force: line 446: sudo n  v22.21.1 : command not found
        node version is
        Node.js installation Done! version=v22.19.0
        want /var/swap=512MByte, checking existing: keeping it
        force: line 772: pm2: command not found
        npm error code EBADENGINE
        npm error engine Unsupported engine
        npm error engine Not compatible with your version of node/npm: magicmirror@2.35.0
        npm error notsup Not compatible with your version of node/npm: magicmirror@2.35.0
        npm error notsup Required: {"node":">=22.21.1 <23 || >=24"}
        npm error notsup Actual:   {"node":"v22.19.0","npm":"11.13.0"}
        npm error A complete log of this run can be found in: /home/kittypi/.npm/_logs/2026-04-28T00_48_25_147Z-debug-0.log
        npm warn "install" is being parsed as a normal command line argument.
        npm warn Unknown cli config "--audit --no-fund --no-update-notifier". This will stop working in the next major version of npm.
        > mmm-calendarext3@1.12.4 postinstall
        > git submodule update --init --recursive
        Submodule path 'CX3_Shared': checked out 'c097e31c073007cf16e86f695bed1c807f581aef'
        up to date, audited 1 package in 1s
        found 0 vulnerabilities
        npm warn deprecated har-validator@5.1.5: this library is no longer supported
        npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        added 50 packages, and audited 51 packages in 6s
        4 packages are looking for funding
          run `npm fund` for details
        6 vulnerabilities (4 moderate, 2 critical)
        Some issues need review, and may require choosing
        a different dependency.
        Run `npm audit` for details.
        > mmm-iss-live@2.3.1 prepare
        > simple-git-hooks || true
        sh: 1: simple-git-hooks: not found
        up to date, audited 1 package in 967ms
        kittypi@KITTYpi:~/MagicMirror $ npm run start
        > magicmirror@2.35.0 start
        > node --run start:wayland
        /bin/sh: 1: ./node_modules/.bin/electron: not found
          @angeliKITTYx another fun time
          Do
          sudo npm install -g n
          sudo n 22.21.1
          hash -r
          node -v
          If it says 22.21.1
          Then do
          npm run install-mm
          If it says successful then
          npm run start:x11
          • A
            kittypi@KITTYpi:~/MagicMirror $ sudo npm install -g n
            sudo n 22.21.1
            hash -r
            node -v
            sudo: npm: command not found
            v22.19.0
              @angeliKITTYx ok
              sudo apt update
              sudo apt install nodejs
              If that ends ok
              node -v
              • A
                still no luck :(
                I’m logging off for the evening, but I’ll check back in tomorrow. Thank you for all the help you provide!
                kittypi@KITTYpi:~/MagicMirror $ sudo apt update
                Hit:1 http://deb.debian.org/debian bookworm InRelease
                Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                Reading package lists... Done
                Building dependency tree... Done
                All packages are up to date.
                  libbasicusageenvironment1 libgroupsock8 liblivemedia77 linux-headers-6.12.25+rpt-common-rpi linux-headers-6.12.25+rpt-rpi-2712
                  linux-headers-6.12.25+rpt-rpi-v8 linux-image-6.12.25+rpt-rpi-2712 linux-image-6.12.25+rpt-rpi-v8 linux-kbuild-6.12.25+rpt
                  python3-v4l2
                Use 'sudo apt autoremove' to remove them.
                The following additional packages will be installed:
                  libc-ares2 libnode108 libuv1 node-acorn node-busboy node-cjs-module-lexer node-undici node-xtend nodejs-doc
                Suggested packages:
                  npm
                The following NEW packages will be installed:
                  libc-ares2 libnode108 libuv1 node-acorn node-busboy node-cjs-module-lexer node-undici node-xtend nodejs nodejs-doc
                0 upgraded, 10 newly installed, 0 to remove and 0 not upgraded.
                Need to get 14.2 MB of archives.
                After this operation, 66.5 MB of additional disk space will be used.
                Do you want to continue? [Y/n] y
                Get:1 http://deb.debian.org/debian bookworm/main arm64 libc-ares2 arm64 1.18.1-3 [99.2 kB]
                Get:2 http://deb.debian.org/debian bookworm/main arm64 libuv1 arm64 1.44.2-1+deb12u1 [130 kB]
                Get:3 http://deb.debian.org/debian bookworm/main arm64 node-xtend all 4.0.2-3 [3,932 B]
                Get:4 http://deb.debian.org/debian bookworm/main arm64 nodejs arm64 18.20.4+dfsg-1~deb12u1 [319 kB]
                Get:5 http://deb.debian.org/debian bookworm/main arm64 node-acorn all 8.8.1+ds+~cs25.17.7-2 [128 kB]
                Get:6 http://deb.debian.org/debian bookworm/main arm64 node-cjs-module-lexer all 1.2.2+dfsg-5 [30.1 kB]
                Get:7 http://deb.debian.org/debian bookworm/main arm64 node-busboy all 1.6.0+~cs2.6.0-2 [16.9 kB]
                Get:8 http://deb.debian.org/debian bookworm/main arm64 node-undici all 5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4 [285 kB]
                Get:9 http://deb.debian.org/debian bookworm/main arm64 libnode108 arm64 18.20.4+dfsg-1~deb12u1 [9,565 kB]
                Get:10 http://deb.debian.org/debian bookworm/main arm64 nodejs-doc all 18.20.4+dfsg-1~deb12u1 [3,579 kB]
                Fetched 14.2 MB in 4s (3,796 kB/s)
                Selecting previously unselected package libc-ares2:arm64.
                (Reading database ... 171415 files and directories currently installed.)
                Preparing to unpack .../0-libc-ares2_1.18.1-3_arm64.deb ...
                Unpacking libc-ares2:arm64 (1.18.1-3) ...
                Selecting previously unselected package libuv1:arm64.
                Preparing to unpack .../1-libuv1_1.44.2-1+deb12u1_arm64.deb ...
                Unpacking libuv1:arm64 (1.44.2-1+deb12u1) ...
                Selecting previously unselected package node-xtend.
                Preparing to unpack .../2-node-xtend_4.0.2-3_all.deb ...
                Unpacking node-xtend (4.0.2-3) ...
                Selecting previously unselected package nodejs.
                Preparing to unpack .../3-nodejs_18.20.4+dfsg-1~deb12u1_arm64.deb ...
                Unpacking nodejs (18.20.4+dfsg-1~deb12u1) ...
                Selecting previously unselected package node-acorn.
                Preparing to unpack .../4-node-acorn_8.8.1+ds+~cs25.17.7-2_all.deb ...
                Unpacking node-acorn (8.8.1+ds+~cs25.17.7-2) ...
                Selecting previously unselected package node-cjs-module-lexer.
                Preparing to unpack .../5-node-cjs-module-lexer_1.2.2+dfsg-5_all.deb ...
                Unpacking node-cjs-module-lexer (1.2.2+dfsg-5) ...
                Selecting previously unselected package node-busboy.
                Preparing to unpack .../6-node-busboy_1.6.0+~cs2.6.0-2_all.deb ...
                Unpacking node-busboy (1.6.0+~cs2.6.0-2) ...
                Selecting previously unselected package node-undici.
                Preparing to unpack .../7-node-undici_5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4_all.deb ...
                Unpacking node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4) ...
                Selecting previously unselected package libnode108:arm64.
                Preparing to unpack .../8-libnode108_18.20.4+dfsg-1~deb12u1_arm64.deb ...
                Unpacking libnode108:arm64 (18.20.4+dfsg-1~deb12u1) ...
                Selecting previously unselected package nodejs-doc.
                Preparing to unpack .../9-nodejs-doc_18.20.4+dfsg-1~deb12u1_all.deb ...
                Unpacking nodejs-doc (18.20.4+dfsg-1~deb12u1) ...
                Setting up node-cjs-module-lexer (1.2.2+dfsg-5) ...
                Setting up libc-ares2:arm64 (1.18.1-3) ...
                Setting up libuv1:arm64 (1.44.2-1+deb12u1) ...
                Setting up nodejs-doc (18.20.4+dfsg-1~deb12u1) ...
                Setting up node-xtend (4.0.2-3) ...
                Setting up node-busboy (1.6.0+~cs2.6.0-2) ...
                Setting up node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4) ...
                Setting up node-acorn (8.8.1+ds+~cs25.17.7-2) ...
                Setting up libnode108:arm64 (18.20.4+dfsg-1~deb12u1) ...
                Setting up nodejs (18.20.4+dfsg-1~deb12u1) ...
                update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
                Processing triggers for man-db (2.11.2-2) ...
                Processing triggers for libc-bin (2.36-9+rpt2+deb12u13) ...
                kittypi@KITTYpi:~/MagicMirror $ node -v
                v22.19.0
                sudo n 22.21.1
                hash -r
                node -v
                v22.19.0
                  @angeliKITTYx so much fun. I hate when the tools only do half a job
                  sudo apt install npm
                  Then
                  npm -v
                  Then
                  sudo n 22.21.1
                  hash -r
                  node -v
                  • A
                    it is just refusing to take 22.21.1
                    Setting up node-es-abstract (1.20.4+~cs26.27.47-1) ...
                    Setting up node-webassemblyjs (1.11.4+dfsg+~cs10.11.17-2) ...
                    Setting up node-util (0.12.5+~1.0.10-1) ...
                    Setting up node-babel-plugin-lodash (3.3.4+~cs2.0.1-6) ...
                    Setting up node-jest-debbundle (29.3.1~ds1+~cs70.48.25-2) ...
                    Setting up node-assert (2.0.0+~cs3.9.8-2) ...
                    Setting up webpack (5.75.0+dfsg+~cs17.16.14-1+deb12u1) ...
                    Setting up node-parse-json (5.2.0+~cs5.1.7-1) ...
                    Setting up node-read-pkg (5.2.0-2) ...
                    Setting up node-istanbul (0.4.5+repack10+~cs97.25.57-3) ...
                    Setting up node-tape (5.6.1+~cs8.20.19-1) ...
                    Setting up node-css-loader (6.7.2+~cs14.0.11-1) ...
                    Setting up node-tap (16.3.2+ds1+~cs50.8.16-1+deb12u1) ...
                    Setting up node-deep-equal (2.1.0+~cs31.12.80-1) ...
                    Setting up npm (9.2.0~ds1-1) ...
                    kittypi@KITTYpi:~/MagicMirror $ npm -v
                    11.13.0
                    sudo n 22.21.1
                    hash -r
                    node -v
                    added 1 package in 2s
                      installing : node-v22.21.1
                           mkdir : /usr/local/n/versions/node/22.21.1
                           fetch : https://nodejs.org/dist/v22.21.1/node-v22.21.1-linux-arm64.tar.xz
                         copying : node/22.21.1
                       installed : v22.21.1 (with npm 10.9.4)
                    Note: the node command changed location and the old location may be remembered in your current shell.
                             old : /usr/bin/node
                             new : /usr/local/bin/node
                    If "node --version" shows the old version then start a new shell, or reset the location hash with:
                    hash -r  (for bash, zsh, ash, dash, and ksh)
                    rehash   (for csh and tcsh)
                    v22.19.0
                    kittypi@KITTYpi:~/MagicMirror $ node --version
                    v22.19.0
                    kittypi@KITTYpi:~/MagicMirror $ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                    bash: $: command not found
                      @angeliKITTYx
                      The last command you have an extra leading $
                      When you copy/paste you only need to hit the little rectangle button at the en
                      But you dont need all that . The code is downloaded
                      Just do
                      npm run install-mm
                      • A
                        how do i do percussive maintenance on code xD
                        kittypi@KITTYpi:~/MagicMirror $ cd ~/MagicMirror
                        npm run install-mm
                        > magicmirror@2.35.0 install-mm
                        > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                        npm error A complete log of this run can be found in: /home/kittypi/.npm/_logs/2026-04-28T20_16_16_675Z-debug-0.log
                          @angeliKITTYx the end of your prior log post says 22.21.1 is installed
                             installed : v22.21.1 (with npm 10.9.4)  <-----
                          are you in the same terminal window??
                          if so, you need
                          hash -r
                          to capture the path change
                          do
                          which node
                          so we can see where it it located…
                          @angeliKITTYx
                          • A
                            all the same terminal window. i don’t have anything else open. i know it says 22.21.1, but then node version says 19… very odd.
                            kittypi@KITTYpi:~/MagicMirror $ hash -r
                            kittypi@KITTYpi:~/MagicMirror $ which node
                            /usr/local/node/bin/node
                            v22.19.0
                              @angeliKITTYx ok, close that window and open another and
                              try the node --version again
                              • A
                                closed the terminal, opened a new terminal…
                                kittypi@KITTYpi:~ $ node --version
                                v22.19.0
                                kittypi@KITTYpi:~ $ cd MagicMirror
                                v22.19.0
                                  @angeliKITTYx weird
                                  Do
                                  which node
                                  Go to that folder
                                  sudo mv node onode
                                  hash -r
                                  which node
                                  node —version
                                  • A
                                    kittypi@KITTYpi:~/MagicMirror $ cd ..
                                    kittypi@KITTYpi:~ $ which node
                                    kittypi@KITTYpi:/ $ cd usr
                                    kittypi@KITTYpi:/usr $ cd local
                                    kittypi@KITTYpi:/usr/local $ cd node
                                    kittypi@KITTYpi:/usr/local/node $ cd bin
                                    kittypi@KITTYpi:/usr/local/node/bin $ cd node
                                    bash: cd: node: Not a directory
                                    kittypi@KITTYpi:/usr/local/node/bin $ sudo mv node onode
                                    hash -r
                                    which node
                                    node —version
                                    /usr/local/bin/node
                                    node:internal/modules/cjs/loader:1386
                                      throw err;
                                    Error: Cannot find module '/usr/local/node/bin/—version'
                                        at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                                        at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                                        at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                                        at Function._load (node:internal/modules/cjs/loader:1192:37)
                                        at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                                        at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                                        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:171:5)
                                        at node:internal/main/run_main_module:36:49 {
                                      code: 'MODULE_NOT_FOUND',
                                      requireStack: []
                                    Node.js v22.21.1
                                      @angeliKITTYx i hate this editor on my phone changing the characters
                                      do
                                      node --version
                                      it should report 22.21.1
                                      then
                                      npm run install-mm
                                      • A
                                        it’s booting now! hurray! however, now I’m getting the package lock error when i try to complete the calendarext3 update and none of my events are populating. I have a thread up on someone else’s trouble shooting but I’m out of time this morning. I be back at it this afternoon. thank you again for all your help.
                                          @angeliKITTYx awesome. Thanks for the feedback
                                          package-lock? Erase that file then do the update
                                          There is a known bug affecting modules that have functions in their config like ext3. We are discussing ways to distribute these fixes.
                                            Did you get the npm run install-mm done after verifying node version was correct?
                                            • 3 / 4
