    Default Calendar Not Loading Events After New MM Update
    69 Posts 8 Posters 20.1k Views 8 Watching
      sdetweil @angeliKITTYx
      @angeliKITTYx
      The last command you have an extra leading $
      kittypi@KITTYpi:~/MagicMirror $ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
      bash: $: command not found
      When you copy/paste you only need to hit the little rectangle button at the en
      But you dont need all that . The code is downloaded
      Just do
      npm run install-mm
      A 1 Reply Last reply
      • A
        angeliKITTYx @sdetweil
        how do i do percussive maintenance on code xD
        kittypi@KITTYpi:~/MagicMirror $ cd ~/MagicMirror
        npm run install-mm
        > magicmirror@2.35.0 install-mm
        > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
        npm error code EBADENGINE
        npm error engine Unsupported engine
        npm error engine Not compatible with your version of node/npm: magicmirror@2.35.0
        npm error notsup Not compatible with your version of node/npm: magicmirror@2.35.0
        npm error notsup Required: {"node":">=22.21.1 <23 || >=24"}
        npm error notsup Actual:   {"node":"v22.19.0","npm":"11.13.0"}
        npm error A complete log of this run can be found in: /home/kittypi/.npm/_logs/2026-04-28T20_16_16_675Z-debug-0.log
          @angeliKITTYx the end of your prior log post says 22.21.1 is installed
            installing : node-v22.21.1
                 mkdir : /usr/local/n/versions/node/22.21.1
                 fetch : https://nodejs.org/dist/v22.21.1/node-v22.21.1-linux-arm64.tar.xz
               copying : node/22.21.1
             installed : v22.21.1 (with npm 10.9.4)  <-----
          are you in the same terminal window??
          if so, you need
          hash -r
          to capture the path change
          do
          which node
          so we can see where it it located…
          @angeliKITTYx
          • A
            all the same terminal window. i don’t have anything else open. i know it says 22.21.1, but then node version says 19… very odd.
            kittypi@KITTYpi:~/MagicMirror $ hash -r
            kittypi@KITTYpi:~/MagicMirror $ which node
            /usr/local/node/bin/node
            kittypi@KITTYpi:~/MagicMirror $ node --version
            v22.19.0
              @angeliKITTYx ok, close that window and open another and
              try the node --version again
              • A
                closed the terminal, opened a new terminal…
                kittypi@KITTYpi:~ $ node --version
                v22.19.0
                kittypi@KITTYpi:~ $ cd MagicMirror
                v22.19.0
                  @angeliKITTYx weird
                  Do
                  which node
                  Go to that folder
                  sudo mv node onode
                  hash -r
                  which node
                  node —version
                  • A
                    kittypi@KITTYpi:~/MagicMirror $ cd ..
                    kittypi@KITTYpi:~ $ which node
                    kittypi@KITTYpi:/ $ cd usr
                    kittypi@KITTYpi:/usr $ cd local
                    kittypi@KITTYpi:/usr/local $ cd node
                    kittypi@KITTYpi:/usr/local/node $ cd bin
                    kittypi@KITTYpi:/usr/local/node/bin $ cd node
                    bash: cd: node: Not a directory
                    kittypi@KITTYpi:/usr/local/node/bin $ sudo mv node onode
                    hash -r
                    which node
                    node —version
                    /usr/local/bin/node
                    node:internal/modules/cjs/loader:1386
                      throw err;
                    Error: Cannot find module '/usr/local/node/bin/—version'
                        at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                        at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                        at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                        at Function._load (node:internal/modules/cjs/loader:1192:37)
                        at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                        at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:171:5)
                        at node:internal/main/run_main_module:36:49 {
                      code: 'MODULE_NOT_FOUND',
                      requireStack: []
                    Node.js v22.21.1
                      @angeliKITTYx i hate this editor on my phone changing the characters
                      do
                      node --version
                      it should report 22.21.1
                      then
                      npm run install-mm
                      • A
                        it’s booting now! hurray! however, now I’m getting the package lock error when i try to complete the calendarext3 update and none of my events are populating. I have a thread up on someone else’s trouble shooting but I’m out of time this morning. I be back at it this afternoon. thank you again for all your help.
                          @angeliKITTYx awesome. Thanks for the feedback
                          package-lock? Erase that file then do the update
                          There is a known bug affecting modules that have functions in their config like ext3. We are discussing ways to distribute these fixes.
                            Did you get the npm run install-mm done after verifying node version was correct?
                            • A
                              yes I did the npm run install-mm successfully.
                              i got it updated, but now it’s angry again
                              [2026-04-29 18:51:43.521] [ERROR] [calendar] Could not expand event "WD CNU": ical.expandRecurringEvent is not a function
                              [2026-04-29 18:51:43.522] [ERROR] [calendar] Could not expand event "Ortho": ical.expandRecurringEvent is not a function
                              [2026-04-29 18:51:43.522] [ERROR] [calendar] Could not expand event "WD CNU": ical.expandRecurringEvent is not a function
                              [2026-04-29 18:51:43.523] [ERROR] [calendar] Could not expand event "HVAC DUCTING FIX": ical.expandRecurringEvent is not a function
                              [2026-04-29 18:51:43.524] [ERROR] [calendar] Could not expand event "Injection appt time TBD": ical.expandRecurringEvent is not a function
                              [2026-04-29 18:51:43.524] [ERROR] [calendar] Could not expand event "Env. Regulations": ical.expandRecurringEvent is not a function
                              [2026-04-29 18:51:43.525] [ERROR] [calendar] Could not expand event "Z4 training": ical.expandRecurringEvent is not a function
                              [2026-04-29 18:51:43.526] [ERROR] [calendar] Could not expand event "Jury Duty ": ical.expandRecurringEvent is not a function
                              [2026-04-29 18:51:43.527] [ERROR] [calendar] Could not expand event "MATH 260: Linear Algebra ": ical.expandRecurringEvent is not a function
                              [2026-04-29 18:51:43.527] [INFO]  [calendar] Broadcasting 0 events from https://calendar.google.com/calendar/ical/axxxxx/basic.ics.
                              [2026-04-29 18:52:09.449] [LOG]   [electron] Shutting down server...
                              [2026-04-29 18:52:09.452] [LOG]   [node_helper] Stopping module helper: updatenotification
                              [2026-04-29 18:52:09.462] [LOG]   [node_helper] Stopping module helper: calendar
                              [2026-04-29 18:52:09.464] [LOG]   [node_helper] Stopping module helper: MMM-CalendarExt3
                              [2026-04-29 18:52:09.469] [LOG]   [node_helper] Stopping module helper: MMM-Jokes
                              [2026-04-29 18:52:09.470] [LOG]   [node_helper] Stopping module helper: weather
                              [2026-04-29 18:52:09.473] [LOG]   [node_helper] Stopping module helper: MMM-Todoist2
                              [2026-04-29 18:52:09.478] [LOG]   [app] Node_helpers stopped ...
                              v22.21.1
                                @angeliKITTYx looks like you didn’t do that in the MagicMirror folder
                                npm run install-mm
                                • A
                                  I did it originally in the MM folder, but I ran it again and still getting the same errors
                                  I did catch this before the entire terminal filled up with “: ical.expandRecurringEvent is not a function”
                                  [2026-04-29 19:59:54.445] [LOG]   [server] Starting server on port 8080 ...
                                  [2026-04-29 19:59:54.499] [ERROR] [unknown] (node:58997) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                  (Use `electron --trace-deprecation ...` to show where the warning was created)
                                  [2026-04-29 19:59:54.855] [LOG]   [app] Server started ...
                                  [2026-04-29 19:59:54.858] [LOG]   [node_helper] Connecting so```
                                    @angeliKITTYx that means the install-mm did not work
                                    Please do again and show the output
                                    • A
                                      kittypi@KITTYpi:~ $ cd ~/MagicMirror
                                      npm run install-mm
                                      > magicmirror@2.35.0 postinstall
                                      > git clean -df fonts vendor modules/default
                                      > magicmirror@2.35.0 prepare
                                      > [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                                      no husky installed.
                                      up to date in 3s
                                        @angeliKITTYx ok then, one more time
                                        rm package-lock.json
                                        rm -rf node_modules
                                        npm run install-mm
                                        • A
                                          rm -rf node_modules
                                          npm run install-mm
                                          rm: cannot remove 'package-lock.json': No such file or directory
                                          no husky installed.
                                          added 389 packages in 6m
                                            @angeliKITTYx ok, now start MagicMirror
                                            • 3 / 4
