    Default Calendar Not Loading Events After New MM Update
    69 Posts 8 Posters 19.0k Views 8 Watching
      sdetweil @angeliKITTYx
      @angeliKITTYx ok, close that window and open another and
      try the node --version again
        angeliKITTYx @sdetweil
        closed the terminal, opened a new terminal…
        kittypi@KITTYpi:~ $ node --version
        v22.19.0
        kittypi@KITTYpi:~ $ cd MagicMirror
        kittypi@KITTYpi:~/MagicMirror $ node --version
        v22.19.0
          @angeliKITTYx weird
          Do
          which node
          Go to that folder
          sudo mv node onode
          hash -r
          which node
          node —version
            kittypi@KITTYpi:~/MagicMirror $ cd ..
            kittypi@KITTYpi:~ $ which node
            /usr/local/node/bin/node
            kittypi@KITTYpi:/ $ cd usr
            kittypi@KITTYpi:/usr $ cd local
            kittypi@KITTYpi:/usr/local $ cd node
            kittypi@KITTYpi:/usr/local/node $ cd bin
            kittypi@KITTYpi:/usr/local/node/bin $ cd node
            bash: cd: node: Not a directory
            kittypi@KITTYpi:/usr/local/node/bin $ sudo mv node onode
            hash -r
            which node
            node —version
            /usr/local/bin/node
            node:internal/modules/cjs/loader:1386
              throw err;
            Error: Cannot find module '/usr/local/node/bin/—version'
                at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                at Function._load (node:internal/modules/cjs/loader:1192:37)
                at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:171:5)
                at node:internal/main/run_main_module:36:49 {
              code: 'MODULE_NOT_FOUND',
              requireStack: []
            Node.js v22.21.1
              @angeliKITTYx i hate this editor on my phone changing the characters
              do
              node --version
              it should report 22.21.1
              then
              npm run install-mm
                it’s booting now! hurray! however, now I’m getting the package lock error when i try to complete the calendarext3 update and none of my events are populating. I have a thread up on someone else’s trouble shooting but I’m out of time this morning. I be back at it this afternoon. thank you again for all your help.
                  @angeliKITTYx awesome. Thanks for the feedback
                  package-lock? Erase that file then do the update
                  There is a known bug affecting modules that have functions in their config like ext3. We are discussing ways to distribute these fixes.
                    Did you get the npm run install-mm done after verifying node version was correct?
                      yes I did the npm run install-mm successfully.
                      i got it updated, but now it’s angry again
                      [2026-04-29 18:51:43.521] [ERROR] [calendar] Could not expand event "WD CNU": ical.expandRecurringEvent is not a function
                      [2026-04-29 18:51:43.522] [ERROR] [calendar] Could not expand event "Ortho": ical.expandRecurringEvent is not a function
                      [2026-04-29 18:51:43.522] [ERROR] [calendar] Could not expand event "WD CNU": ical.expandRecurringEvent is not a function
                      [2026-04-29 18:51:43.523] [ERROR] [calendar] Could not expand event "HVAC DUCTING FIX": ical.expandRecurringEvent is not a function
                      [2026-04-29 18:51:43.524] [ERROR] [calendar] Could not expand event "Injection appt time TBD": ical.expandRecurringEvent is not a function
                      [2026-04-29 18:51:43.524] [ERROR] [calendar] Could not expand event "Env. Regulations": ical.expandRecurringEvent is not a function
                      [2026-04-29 18:51:43.525] [ERROR] [calendar] Could not expand event "Z4 training": ical.expandRecurringEvent is not a function
                      [2026-04-29 18:51:43.526] [ERROR] [calendar] Could not expand event "Jury Duty ": ical.expandRecurringEvent is not a function
                      [2026-04-29 18:51:43.527] [ERROR] [calendar] Could not expand event "MATH 260: Linear Algebra ": ical.expandRecurringEvent is not a function
                      [2026-04-29 18:51:43.527] [INFO]  [calendar] Broadcasting 0 events from https://calendar.google.com/calendar/ical/axxxxx/basic.ics.
                      [2026-04-29 18:52:09.449] [LOG]   [electron] Shutting down server...
                      [2026-04-29 18:52:09.452] [LOG]   [node_helper] Stopping module helper: updatenotification
                      [2026-04-29 18:52:09.462] [LOG]   [node_helper] Stopping module helper: calendar
                      [2026-04-29 18:52:09.464] [LOG]   [node_helper] Stopping module helper: MMM-CalendarExt3
                      [2026-04-29 18:52:09.469] [LOG]   [node_helper] Stopping module helper: MMM-Jokes
                      [2026-04-29 18:52:09.470] [LOG]   [node_helper] Stopping module helper: weather
                      [2026-04-29 18:52:09.473] [LOG]   [node_helper] Stopping module helper: MMM-Todoist2
                      [2026-04-29 18:52:09.478] [LOG]   [app] Node_helpers stopped ...
                      v22.21.1
                        @angeliKITTYx looks like you didn’t do that in the MagicMirror folder
                        npm run install-mm
                          I did it originally in the MM folder, but I ran it again and still getting the same errors
                          I did catch this before the entire terminal filled up with “: ical.expandRecurringEvent is not a function”
                          [2026-04-29 19:59:54.445] [LOG]   [server] Starting server on port 8080 ...
                          [2026-04-29 19:59:54.499] [ERROR] [unknown] (node:58997) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                          (Use `electron --trace-deprecation ...` to show where the warning was created)
                          [2026-04-29 19:59:54.855] [LOG]   [app] Server started ...
                          [2026-04-29 19:59:54.858] [LOG]   [node_helper] Connecting so```
                            @angeliKITTYx that means the install-mm did not work
                            Please do again and show the output
                              kittypi@KITTYpi:~ $ cd ~/MagicMirror
                              npm run install-mm
                              > magicmirror@2.35.0 install-mm
                              > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                              > magicmirror@2.35.0 postinstall
                              > git clean -df fonts vendor modules/default
                              > magicmirror@2.35.0 prepare
                              > [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                              no husky installed.
                              up to date in 3s
                                @angeliKITTYx ok then, one more time
                                rm package-lock.json
                                rm -rf node_modules
                                npm run install-mm
                                  rm -rf node_modules
                                  npm run install-mm
                                  rm: cannot remove 'package-lock.json': No such file or directory
                                  no husky installed.
                                  added 389 packages in 6m
                                    @angeliKITTYx ok, now start MagicMirror
                                      it’s booted again and no update notifs (:
                                      …but none of my calendar events are populating. this morning, it took about 20m and they eventually showed up. I’ve had it open for about 10m already and don’t see anything. I’ll keep an eye on it.
                                      update - I backed out and saw that I got all of these errors still…
                                      ssignment -July 4th [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                      [2026-04-29 21:45:07.831] [ERROR] [calendar] Could not expand event "Introductory Speech Written Submission [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                      [2026-04-29 21:45:07.832] [ERROR] [calendar] Could not expand event "PHI 100 Quiz 4": ical.expandRecurringEvent is not a function
                                      [2026-04-29 21:45:07.833] [ERROR] [calendar] Could not expand event "Persuasive Ad Analysis  [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                      [2026-04-29 21:45:07.834] [ERROR] [calendar] Could not expand event "Discussion 1  [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                      [2026-04-29 21:45:07.834] [ERROR] [calendar] Could not expand event "Final Discussion  [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                      [2026-04-29 21:45:07.835] [ERROR] [calendar] Could not expand event "Introductory Speech Video (Recorded Audio and Video)  [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                      [2026-04-29 21:45:07.836] [ERROR] [calendar] Could not expand event "Submit Persuasive Speech [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                      [2026-04-29 21:45:07.837] [ERROR] [calendar] Could not expand event "PHI 100 QUIZ 2": ical.expandRecurringEvent is not a function
                                      [2026-04-29 21:45:07.838] [ERROR] [calendar] Could not expand event "Homework [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                      [2026-04-29 21:45:07.839] [ERROR] [calendar] Could not expand event "My Listening Skills [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                      [2026-04-29 21:45:07.840] [ERROR] [calendar] Could not expand event "PHI 100 Discussion": ical.expandRecurringEvent is not a function
                                      [2026-04-29 21:45:07.841] [INFO]  [calendar] Broadcasting 0 events from https://calendar.google.com/calendar/ical/2adcc5394a749909a5fbe4e93d3673b2e0ff6fd91551d1977ecc7dfb84dde87a%40group.calendar.google.com/private-b562d8f04caac264bc19d634d4bfcee0/basic.ics.
                                      [2026-04-29 21:45:09.852] [LOG]   [electron] Shutting down server...
                                      [2026-04-29 21:45:09.853] [LOG]   [node_helper] Stopping module helper: updatenotification
                                      [2026-04-29 21:45:09.854] [LOG]   [node_helper] Stopping module helper: calendar
                                      [2026-04-29 21:45:09.854] [LOG]   [node_helper] Stopping module helper: MMM-CalendarExt3
                                      [2026-04-29 21:45:09.855] [LOG]   [node_helper] Stopping module helper: MMM-Jokes
                                      [2026-04-29 21:45:09.855] [LOG]   [node_helper] Stopping module helper: weather
                                      [2026-04-29 21:45:09.855] [LOG]   [node_helper] Stopping module helper: MMM-Todoist2
                                      [2026-04-29 21:45:09.856] [LOG]   [app] Node_helpers stopped ...
                                      S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                                        @angeliKITTYx thanks
                                        @kristjanesperanto what do you think of this?
                                        We’ve made sure to erase node_modules and start fresh
                                        KristjanESPERANTOK S 2 Replies Last reply Reply Quote 1
                                        • KristjanESPERANTOK Offline
                                          Hmm… I didn’t expect something like that in the current release. But I won’t be able to take a closer look at it right away. It would be interesting to see if this also happens in the develop branch.
                                            KristjanESPERANTO Module Developer @angeliKITTYx
                                            @angeliKITTYx This shouldn’t happen with the just released new version v2.36.0. I recommend to update :)
                                            • 3 / 4
