    Default Calendar Not Loading Events After New MM Update
    69 Posts 8 Posters 19.0k Views 8 Watching
      angeliKITTYx @sdetweil
      how do i do percussive maintenance on code xD
      kittypi@KITTYpi:~/MagicMirror $ cd ~/MagicMirror
      npm run install-mm
      > magicmirror@2.35.0 install-mm
      > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
      npm error code EBADENGINE
      npm error engine Unsupported engine
      npm error engine Not compatible with your version of node/npm: magicmirror@2.35.0
      npm error notsup Not compatible with your version of node/npm: magicmirror@2.35.0
      npm error notsup Required: {"node":">=22.21.1 <23 || >=24"}
      npm error notsup Actual:   {"node":"v22.19.0","npm":"11.13.0"}
      npm error A complete log of this run can be found in: /home/kittypi/.npm/_logs/2026-04-28T20_16_16_675Z-debug-0.log
        sdetweil @angeliKITTYx
        @angeliKITTYx the end of your prior log post says 22.21.1 is installed
          installing : node-v22.21.1
               mkdir : /usr/local/n/versions/node/22.21.1
               fetch : https://nodejs.org/dist/v22.21.1/node-v22.21.1-linux-arm64.tar.xz
             copying : node/22.21.1
           installed : v22.21.1 (with npm 10.9.4)  <-----
        are you in the same terminal window??
        if so, you need
        hash -r
        to capture the path change
        do
        which node
        so we can see where it it located…
        @angeliKITTYx
          all the same terminal window. i don’t have anything else open. i know it says 22.21.1, but then node version says 19… very odd.
          kittypi@KITTYpi:~/MagicMirror $ hash -r
          kittypi@KITTYpi:~/MagicMirror $ which node
          /usr/local/node/bin/node
          kittypi@KITTYpi:~/MagicMirror $ node --version
          v22.19.0
            @angeliKITTYx ok, close that window and open another and
            try the node --version again
              closed the terminal, opened a new terminal…
              kittypi@KITTYpi:~ $ node --version
              v22.19.0
              kittypi@KITTYpi:~ $ cd MagicMirror
              v22.19.0
                @angeliKITTYx weird
                Do
                which node
                Go to that folder
                sudo mv node onode
                hash -r
                which node
                node —version
                  kittypi@KITTYpi:~/MagicMirror $ cd ..
                  kittypi@KITTYpi:~ $ which node
                  kittypi@KITTYpi:/ $ cd usr
                  kittypi@KITTYpi:/usr $ cd local
                  kittypi@KITTYpi:/usr/local $ cd node
                  kittypi@KITTYpi:/usr/local/node $ cd bin
                  kittypi@KITTYpi:/usr/local/node/bin $ cd node
                  bash: cd: node: Not a directory
                  kittypi@KITTYpi:/usr/local/node/bin $ sudo mv node onode
                  hash -r
                  which node
                  node —version
                  /usr/local/bin/node
                  node:internal/modules/cjs/loader:1386
                    throw err;
                  Error: Cannot find module '/usr/local/node/bin/—version'
                      at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                      at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                      at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                      at Function._load (node:internal/modules/cjs/loader:1192:37)
                      at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                      at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                      at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:171:5)
                      at node:internal/main/run_main_module:36:49 {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: []
                  Node.js v22.21.1
                    @angeliKITTYx i hate this editor on my phone changing the characters
                    do
                    node --version
                    it should report 22.21.1
                    then
                    npm run install-mm
                      it’s booting now! hurray! however, now I’m getting the package lock error when i try to complete the calendarext3 update and none of my events are populating. I have a thread up on someone else’s trouble shooting but I’m out of time this morning. I be back at it this afternoon. thank you again for all your help.
                        @angeliKITTYx awesome. Thanks for the feedback
                        package-lock? Erase that file then do the update
                        There is a known bug affecting modules that have functions in their config like ext3. We are discussing ways to distribute these fixes.
                          Did you get the npm run install-mm done after verifying node version was correct?
                            yes I did the npm run install-mm successfully.
                            i got it updated, but now it’s angry again
                            [2026-04-29 18:51:43.521] [ERROR] [calendar] Could not expand event "WD CNU": ical.expandRecurringEvent is not a function
                            [2026-04-29 18:51:43.522] [ERROR] [calendar] Could not expand event "Ortho": ical.expandRecurringEvent is not a function
                            [2026-04-29 18:51:43.522] [ERROR] [calendar] Could not expand event "WD CNU": ical.expandRecurringEvent is not a function
                            [2026-04-29 18:51:43.523] [ERROR] [calendar] Could not expand event "HVAC DUCTING FIX": ical.expandRecurringEvent is not a function
                            [2026-04-29 18:51:43.524] [ERROR] [calendar] Could not expand event "Injection appt time TBD": ical.expandRecurringEvent is not a function
                            [2026-04-29 18:51:43.524] [ERROR] [calendar] Could not expand event "Env. Regulations": ical.expandRecurringEvent is not a function
                            [2026-04-29 18:51:43.525] [ERROR] [calendar] Could not expand event "Z4 training": ical.expandRecurringEvent is not a function
                            [2026-04-29 18:51:43.526] [ERROR] [calendar] Could not expand event "Jury Duty ": ical.expandRecurringEvent is not a function
                            [2026-04-29 18:51:43.527] [ERROR] [calendar] Could not expand event "MATH 260: Linear Algebra ": ical.expandRecurringEvent is not a function
                            [2026-04-29 18:51:43.527] [INFO]  [calendar] Broadcasting 0 events from https://calendar.google.com/calendar/ical/axxxxx/basic.ics.
                            [2026-04-29 18:52:09.449] [LOG]   [electron] Shutting down server...
                            [2026-04-29 18:52:09.452] [LOG]   [node_helper] Stopping module helper: updatenotification
                            [2026-04-29 18:52:09.462] [LOG]   [node_helper] Stopping module helper: calendar
                            [2026-04-29 18:52:09.464] [LOG]   [node_helper] Stopping module helper: MMM-CalendarExt3
                            [2026-04-29 18:52:09.469] [LOG]   [node_helper] Stopping module helper: MMM-Jokes
                            [2026-04-29 18:52:09.470] [LOG]   [node_helper] Stopping module helper: weather
                            [2026-04-29 18:52:09.473] [LOG]   [node_helper] Stopping module helper: MMM-Todoist2
                            [2026-04-29 18:52:09.478] [LOG]   [app] Node_helpers stopped ...
                            v22.21.1
                              @angeliKITTYx looks like you didn’t do that in the MagicMirror folder
                              npm run install-mm
                                I did it originally in the MM folder, but I ran it again and still getting the same errors
                                I did catch this before the entire terminal filled up with “: ical.expandRecurringEvent is not a function”
                                [2026-04-29 19:59:54.445] [LOG]   [server] Starting server on port 8080 ...
                                [2026-04-29 19:59:54.499] [ERROR] [unknown] (node:58997) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                (Use `electron --trace-deprecation ...` to show where the warning was created)
                                [2026-04-29 19:59:54.855] [LOG]   [app] Server started ...
                                [2026-04-29 19:59:54.858] [LOG]   [node_helper] Connecting so```
                                  @angeliKITTYx that means the install-mm did not work
                                  Please do again and show the output
                                    kittypi@KITTYpi:~ $ cd ~/MagicMirror
                                    npm run install-mm
                                    > magicmirror@2.35.0 postinstall
                                    > git clean -df fonts vendor modules/default
                                    > magicmirror@2.35.0 prepare
                                    > [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                                    no husky installed.
                                    up to date in 3s
                                      @angeliKITTYx ok then, one more time
                                      rm package-lock.json
                                      rm -rf node_modules
                                      npm run install-mm
                                        rm -rf node_modules
                                        npm run install-mm
                                        rm: cannot remove 'package-lock.json': No such file or directory
                                        no husky installed.
                                        added 389 packages in 6m
                                          @angeliKITTYx ok, now start MagicMirror
                                            it’s booted again and no update notifs (:
                                            …but none of my calendar events are populating. this morning, it took about 20m and they eventually showed up. I’ve had it open for about 10m already and don’t see anything. I’ll keep an eye on it.
                                            update - I backed out and saw that I got all of these errors still…
                                            ssignment -July 4th [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                            [2026-04-29 21:45:07.831] [ERROR] [calendar] Could not expand event "Introductory Speech Written Submission [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                            [2026-04-29 21:45:07.832] [ERROR] [calendar] Could not expand event "PHI 100 Quiz 4": ical.expandRecurringEvent is not a function
                                            [2026-04-29 21:45:07.833] [ERROR] [calendar] Could not expand event "Persuasive Ad Analysis  [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                            [2026-04-29 21:45:07.834] [ERROR] [calendar] Could not expand event "Discussion 1  [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                            [2026-04-29 21:45:07.834] [ERROR] [calendar] Could not expand event "Final Discussion  [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                            [2026-04-29 21:45:07.835] [ERROR] [calendar] Could not expand event "Introductory Speech Video (Recorded Audio and Video)  [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                            [2026-04-29 21:45:07.836] [ERROR] [calendar] Could not expand event "Submit Persuasive Speech [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                            [2026-04-29 21:45:07.837] [ERROR] [calendar] Could not expand event "PHI 100 QUIZ 2": ical.expandRecurringEvent is not a function
                                            [2026-04-29 21:45:07.838] [ERROR] [calendar] Could not expand event "Homework [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                            [2026-04-29 21:45:07.839] [ERROR] [calendar] Could not expand event "My Listening Skills [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                            [2026-04-29 21:45:07.840] [ERROR] [calendar] Could not expand event "PHI 100 Discussion": ical.expandRecurringEvent is not a function
                                            [2026-04-29 21:45:07.841] [INFO]  [calendar] Broadcasting 0 events from https://calendar.google.com/calendar/ical/2adcc5394a749909a5fbe4e93d3673b2e0ff6fd91551d1977ecc7dfb84dde87a%40group.calendar.google.com/private-b562d8f04caac264bc19d634d4bfcee0/basic.ics.
                                            [2026-04-29 21:45:09.852] [LOG]   [electron] Shutting down server...
                                            [2026-04-29 21:45:09.853] [LOG]   [node_helper] Stopping module helper: updatenotification
                                            [2026-04-29 21:45:09.854] [LOG]   [node_helper] Stopping module helper: calendar
                                            [2026-04-29 21:45:09.854] [LOG]   [node_helper] Stopping module helper: MMM-CalendarExt3
                                            [2026-04-29 21:45:09.855] [LOG]   [node_helper] Stopping module helper: MMM-Jokes
                                            [2026-04-29 21:45:09.855] [LOG]   [node_helper] Stopping module helper: weather
                                            [2026-04-29 21:45:09.855] [LOG]   [node_helper] Stopping module helper: MMM-Todoist2
                                            [2026-04-29 21:45:09.856] [LOG]   [app] Node_helpers stopped ...
                                            S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                                            • 3 / 4
